How To Create Your Own Portrait Backdrop
This is a discussion on How To Create Your Own Portrait Backdrop within the Articles of Interest forums, part of the ThePhotoForum.com category; How To Create Your Own Portrait Backdrop By Corry at Sun, 2006-01-22 22:35 What’s the point of dropping tons of money on a backdrop, when ...
Go Back   The Photo Forum - Photography Discussion Forum > ThePhotoForum.com > Articles of Interest
Articles of Interest A collection of informative articles submitted by TPF members.
Reply
LinkBack Thread Tools Display Modes
Old 12-02-2008, 09:56 AM   #1
Administrator
TPF Supporter
My Gallery: (0)
What’s the point of dropping tons of money on a backdrop, when you can make your own for a fraction of the price?
I did it…here’s how.
First, supplies. Most important, I needed the material. I bought a large 10’X20’ piece of unbleached muslin from Joanne Fabrics. There are lots of fabric dyes you can use to create your backdrops, but I chose to use Rit Dye.
I will explain the actual process later.
Next, I needed a way to hang the backdrop. At the hardware store I bought a set of curtain hangers like this:
...and a 12’ piece of banister wood (the stuff they use for stair rails) like this:
Also, for the dyeing process, I used a large un-used plastic trash can and a wooden dowel rod about 3 feet long.
Now, the process. First, I prepared the fabric. I hemmed the edges so they wouldn’t fray. The top (one of the 10’ edges), I had to sew a loop big enough to slide over the banister rail (kind of like a curtain on a curtain rod). It helps when you have a mom with a sewing machine and too much free time!
Next, on to dyeing. Prepare your solution as directed on the package. For the color and look I wanted, I chose to use one part Black dye to two parts Pearl Grey. On the directions, it says to stir constantly to achieve a solid color. I did not want a solid color, so I would stir for a minute or two, let it sit for a minute or two, stir, let sit, etc. Once it is dyed to the color you want it, the fabric must be rinsed until the water runs clear. Then, just pop it in the dryer or hang it up to air dry.
While the fabric dries, it’s time to prepare to hang it on the wall. Take your curtain hooks and screw them into the wall about 11’ apart, at a height you find appropriate. I have mine at 8’, though if ceiling clearance allows, 9’ might be better.
Slide the loop of  your muslin over the banister rail until there is about a foot of banister showing at each end. Here is how it should look.   Though more clearance is preferred to hang off the end of the hook, in my case it wasn’t possible.
And…you are done! When you are done doing your shoot, you merely roll the backdrop up onto the rail. A tip: when you unroll it again, it will be wrinkly. Keep a small spray bottle with water in it, and spray the wrinkles til they are damp. Pull the wrinkles taut a few times, and leave it to dry. Most of the time, it will dry smooth, though sometimes you have to repeat the process.
In the end, here were my results.
TPF-Admin is offline   Reply With Quote
The Following 2 Users Say Thank You to TPF-Admin For This Useful Post:: photosbybritni (07-13-2010), vtf  (04-29-2010)
Sponsored Links
ThePhotoForum.com is the premier Photography Forum & Digital Camera Resource! Registered Users do not see the above ads. Please Register - It's Free!
Reply
Lower Navigation
Visitors found this page by searching for these keywords:
how to make photo backdrops
portrait backdrops
how to make a photo backdrop
How to make your own backdrop
make your own photography backdrop
how to make a backdrop
how to make photography backdrops
how to make a backdrop for photography
how to make a photobackdrop
how to build a photo backdrop
make your own photography backdrops
create your own portrait backdrop
create a backdrop
portrait backdrop
fall portrait backgrounds
how to make your own photographic backdrop
free portrait backdrops
how to make your own photography background
building a photo backdrop
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by vBulletin® Version 3.8.5
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.3.2
Celebrity Gossip - United States Message Board - Parrot Forum - Honda Motorcycle - iPhone News - iPhone 4 Forum - Motorola Droid Forum - Nintendo Wii Forum - Apple iPad Forum
