+ Reply to Thread
Results 1 to 7 of 7
Thread: Sync lighting
  1. #1
    Join Date
    Aug 2011
    Posts
    9
    My Gallery
    (0)
    Liked
    0 times
    Sync lighting
    Ok I have a7D camera, with the wireless triggers. I need to know am I supposed to sync all the lighting of the studio such as the hair lighting background lighting main lighting and side lighting. Are all this have to be sync together to shoot at the same time or is the hair and background lighting are continuous light? Please help...
  2. # ADS
  3. #2
    TPF Junkie!
    Join Date
    Jan 2010
    Posts
    3,143
    My Gallery
    (0)
    My Photos Are NOT OK to Edit
    Liked
    194 times
    You will need to have triggers for every single flash you have OR if they have optical triggers you can sync 1 flash with your camera using 1 wireless trigger and the other one will fire with the optical triggers (most studio strobes have optical triggers built-in)
    Make sure you know what is the sync speed of your camera.
    Continuous light mixed with flash is not a good idea.
  4. #3
    Join Date
    Aug 2011
    Posts
    9
    My Gallery
    (0)
    Liked
    0 times
    Aaaahhh okay that's clear enough thank you so much. So every light has to be sync together correct. The hair background and main lighting.. Ok I got that.. Now you mention that I have to make sure I set up the lighting according to the camera set up, that I dint know and I don't understand because I blew upon of my strobe lights. So if u don t mind u think you can help me in that like give me examples. Wat to put on the cameraandon the lights. Like if it would be inside studio?
  5. #4
    TPF Junkie!
    Join Date
    Jun 2009
    An American in Europe
    Posts
    5,266
    My Gallery
    (0)
    Liked
    373 times
    Quote Originally Posted by ghache View Post
    Really? Isn't fill flash use a mix of continuous and flash light?
    To the OP: If you use strobes, they will be synced through the triggers (either built-ins or add-ons). If you want to use just the modeling light, yes you can but you will need to meter it differently. As you would if you are talking of mixing continuous lights and strobes.
    "Every child is an artist. The problem is how to remain an artist once you grow up."
    Pablo Picasso
  6. #5
    TPF Junkie!
    Join Date
    Jan 2010
    Posts
    3,143
    My Gallery
    (0)
    Liked
    194 times
    Quote Originally Posted by c.cloudwalker View Post
    I always use flash to fill.
    I use the sun sometimes
  7. #6
    TPF Junkie!
    Join Date
    Jan 2011
    New Jersey
    Posts
    1,379
    My Gallery
    (46)
    Liked
    332 times
    Hi Anthony,
    Here is a great tutorial thread. http://www.thephotoforum.com/forum/p...al-thread.html
    There is also a thread on lighting set ups: http://www.thephotoforum.com/forum/b...os-setups.html
    My first set of strobes was a 3 light Photogenic kit. Each light had a built in optical sync. So I only had to connect my camera to the main light and the other lights would sync off of the main light ( does that make sense?) Check your light manual to see if your lights do this too. If not you will need a transmitter for your camera and a receiver for each light.
    Christina S. Cericola
    www.csjstudios.com
  8. #7
    Join Date
    Aug 2011
    Posts
    9
    My Gallery
    (0)
    Liked
    0 times
    Thanks ccericola I am looking at the website right now. Let me see wats up with that and I'll return the comment right back
Sponsors
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Similar Threads
  1. sync speed wont sync
    By sbakewell0508 in forum Digital Discussion & Q&A
    Last Post: 05-01-2011, 09:58 AM
  2. x-sync
    By malbec in forum Digital Discussion & Q&A
    Last Post: 10-13-2009, 02:08 AM
  3. ASA flash sync socket - converting to PC sync port
    By Samriel in forum Medium Format & Large Format
    Last Post: 01-26-2009, 08:27 AM
  4. PC Sync Help
    By DeepSpring in forum Photography Equipment & Products
    Last Post: 08-29-2007, 08:17 PM
  5. What is 'Slow Sync', 'Rear Sync', and 'Flash Compensation'?
    By ted_smith in forum Beyond the Basics
    Last Post: 12-07-2006, 09:00 PM
can you use strobe and continuous lighting together
continous lights mixed with strobes
does strobe light sync with camera?
how to have photographic lighting all synced
how to sych 3 strobe lights at the same time
is it okay to use continuous lights and flashes together
sync my lights
syncing camera with lighting
what do i need for syncing camera lighting
what do i need to sync my camera lights
what is synch lighting
what will sync my camera to my strobes
