Results 1 to 8 of 8
02-20-2008, 05:09 PM #1No longer a newbie, moving up!
- Join Date
- Oct 2007
- Location
- Vancouver, Canada
- Posts
- 50
- My Gallery
- (0)
- Liked
- 0 times
Autofocus: not using shutter release
This is for users who own cameras that allow them to separate autofocusing from their shutter release. In other words, when you press the shutter release button halfway down - this doesn't autofocus, but instead, autofocus is set elsewhere on your camera.
On my D2X, there's an AF-ON button and you can set it so that the camera only focuses when you press AF-ON, instead of allowing the camera to autofocus with the shutter release button (or both).
My question is: what are the advantages/disadvantages to this setup? I'd like to hear why people disable AF on their shutter release button when taking photographs.
02-20-2008 05:09 PM # ADS
02-20-2008, 06:18 PM #2TPF Junkie!
- Join Date
- Oct 2003
- Location
- Brisbane, Australia
- Posts
- 9,640
- My Gallery
- (0)
- My Photos Are NOT OK to Edit
- Liked
- 191 times
I have a profile on my D200 which I called "night" the reason being is that while AF works with a tripod I may be forced to focus on something first and then take the photo after recomposing. It may also be too dark for manual focus too but if there is a light on in the distance I can AF onto that.
So I point my camera at that light and hit the AF-ON button. Then I can recompose and snap away without having to worry about flicking the focus switch around.
It's not a matter of disbelieve but a case of when depressing the shutter would hunt for focus when the focus was originally set, and a case of not wanting to constantly flick the focus switch from M to S and back to M.
02-20-2008, 08:33 PM #3TPF Junkie!
- Join Date
- Sep 2006
- Location
- Wichita, Kansas, USA
- Posts
- 4,600
- My Gallery
- (0)
- My Photos Are OK to Edit
- Liked
- 371 times
One of the biggest advantages I have with having my auto focus on a different button is for shooting sports. Fast action allows you to constantly focus with out A. accidentaly taking a shot you did not want and B. It allows constant focus thru the triggering of the shutter. When you use the shutter release for focus and shutter release there is are a few split miliseconds where the focus stops and the shutter triggers. This is time is reduced when using a secondary focus control. Basicly it is mechanical multi-tasking. It may not be much of a difference but enough to help capture a sharper image in tough conditions. This does however need to be used in what Canon calls AI-Servo mode. I believe Nikon calls it continous focus mode or something like that.
One down side is it eats batteries. You tend to focus through more of the action anticipating the shots that you want. Focus time increases dramatically. That is why I always have a second set of batteries for both my bodies and grips when ever I shoot sports. It does take a little getting used to, but with practice it becomes second nature and you learn to lightly trip the shutter rather than stab at it. Something I have seen a lot of new sports shooters do.
Amateurs worry about equipment, professionals worry about time, masters worry about light.
I can honestly say that there are two most remarkable men in the world today. Michio Kaku is one, and I am the other. Between us we cover all knowledge.
Kaku knows all that can be known....And I know the rest.
"Yesterday is history, tomorrow is a mystery. Today?
Today is a gift. That is why we call it the present."
Master Wugui from Kung Fu Panda
02-20-2008, 09:09 PM #4TPF Junkie!
- Join Date
- Feb 2007
- Location
- Atlanta, GA
- Posts
- 1,527
- My Gallery
- (0)
- Liked
- 3 times
I have my 20D setup to use a button that normally meters flash "*" ( I don't use flash anyway) to be my AF button. IT helps because you can point the camera at something, press the shutter halfway, meter, then point it at your subject(still holding the shutter 1/2way from the metering) and focus with my * buttron, then take the shot. I combine this with partial metering
An example of using this, (I use it daily, I'll give an example of what I did today). I was taking pictures of people wearing black shirts. And, due to the partial metering and them being in the center of some frames, the meter would overexpose because it thought the room was darker than it was, I would look at the wall to their left or right (this is called metering for ambient lighting) then I pointed the camera at them, focused, and took the picture.KEEP THIS IN MIND IF I CRITIQUE YOUR PHOTO
This was an open minded opinion and I tried to make it more meaningful than just tearing the photo apart. I simply highlight what I find to be a strength or a weakness that enhances or degrades the quality of an image. I want it to be clear that I respect your right to agree or disagree with my viewpoints, but hope that they may have given you some insight or further understanding when you compared and contrasted my views with your own.
02-20-2008, 09:26 PM #5No longer a newbie, moving up!
- Join Date
- Oct 2007
- Location
- Vancouver, Canada
- Posts
- 50
- My Gallery
- (0)
- Liked
- 0 times
Thanks for the input! I was able to find out much more extensively about this topic, thanks to another member on the board here who nicely sent a link to me.
Thanks again, all!
02-20-2008, 11:09 PM #6TPF Junkie!
- Join Date
- Mar 2007
- Location
- Minnesota
- Posts
- 1,906
- My Gallery
- (0)
- Liked
- 1 times
i was just shooting the eclipse tonight, and once i got a focus on the moon, i needed to reframe the shot and change a couple settings that i didnt realize were off. i used my mf/af button (just disables the autofocus while pressed, enables it when you let off on it) to hold the focus so i didnt have to refocus when i pressed the shutter button... same sorta thing, that button was just closer to my thumb than the custom AF button i have, so i went fo it first since it was about -1 degree F here...
Be sure to visit my flickr
Sony Alpha A700,
Minolta 50mm f/1.7, ROKKOR f/1.4
Sigma 70-200mm f/2.8
Sigma 24-70mm f/2.8
Sigma 10-20mm f/4-5.6
02-22-2008, 12:39 AM #7I spend too much of my life on TPF!
- Join Date
- Feb 2008
- Location
- Michigan
- Posts
- 272
- My Gallery
- (0)
- Liked
- 0 times
I put my Nikon on AF-C for sports, unfortunately I don't a separate button, so I hold the shutter button halfway down and hit it when I need to. Battery life is a problem, as is the fact that sometimes your lens spazzes out since it is constantly refocusing. AF-C lets you hit the shutter when the subject isn't in focus (AF-S won't let you do that), so you end up with some blurry images, especially if you aren't using the best lens.
02-23-2008, 01:58 AM #8No longer a newbie, moving up!
- Join Date
- Oct 2007
- Location
- Vancouver, Canada
- Posts
- 50
- My Gallery
- (0)
- Liked
- 0 times
If you meant "unfortunately I don't HAVE a separate button" meaning the AF-ON... you should, if you own the D80 - the button just may not be called "AF-ON".
I've got a D70s as my backup body and it has the AF-ON Only function in my custom settings menu. Half-pressing shutter will not autofocus. Instead, it is solely done by the AF-ON button (on my D70s, this button is coupled with AE-L/AF-L button and isn't called AF-ON, like it is on my D2X).
Just a heads up, if you're ever wanting to rid the AF when you half-press the shutter
Similar Threads
Shutter Release
By BuS_RiDeR in forum Photography Beginners' ForumReplies: 6Last Post: 11-11-2009, 03:51 PM -
Need help with the shutter release button...
By Acrylic Snow in forum Film Discussion and Q & AReplies: 4Last Post: 10-02-2009, 05:43 PM -
Shutter release
By julie32 in forum Photography Beginners' ForumReplies: 12Last Post: 05-30-2008, 06:34 PM -
Shutter Release Cable for D40?
By BuZzZeRkEr in forum Photography Beginners' ForumReplies: 10Last Post: 12-21-2007, 08:19 PM -
Canon 5D Shutter Release
By vonDrehle in forum Photography Equipment & ProductsReplies: 10Last Post: 12-08-2006, 12:48 PM
auto focus shutter not releasing
,auto focus shutter release, photography
,autofocus shutter release
,canon autofocus after shutter release
,canon separate focus and shutter release
,how use autofocus shutter release
,like to hear the shutter when taking pictures
,saparating autofocus from shatter release
,separate autofocus shutter release
,seperate auto focus from shutter release canon
,shutter release cable autofocus forum
,shutter release with auto focus
LinkBack URL
About LinkBacks
