Full frame camera
Hi.
I have a quick question. Do I need a special lens for full frame digital camera?
Thanks
Marek
"Best wide-angle lens? Two steps backward, look for the 'ah-ha'.."
Ernst Haas
03-20-2008 07:12 PM
# ADS
Originally Posted by
plastii
Hi.
Thanks
Marek
Kinda. You do NOT want to use the special lenses designed for use with DX sensors. A "full frame" camera requires the same lenses that are used with 35mm film. The reference to "full frame" is the 24X36 frame on 35mm film.
Socrates
I've noticed a lot of people who call all APS-C-sized sensors "DX sensors". The DX designation only applies to Nikon as far as I understand.
Is this another proprietary eponym, similar to Kleenex instead of tissue or Band-Aid instead of bandage?
Canon EOS 300D
18-55 mm kit lens
50mm f/1.4 USM
Speedlite 430EX
These walls are paper-thin
Where everyone hears every little sound...
Everyone's a voyeur as they're watching me watch them watch me right now...
-Modest Mouse
My Photography:
http://marcusmayo.blogspot.com
1.20.09
MarcusM
Yeah, DX is a Nikon term but the Canon APS-C sensor is almost as large. I suspect that the terms are proprietary but, personally, I don't care.
Socrates
Oh, ok. Well I just know that for myself it's already hard enough to learn and understand all the technical jargon of photography, so I like to know the correct terminology.
Canon EOS 300D
18-55 mm kit lens
50mm f/1.4 USM
Speedlite 430EX
-Modest Mouse
My Photography:
1.20.09
I am Big, I am Mike
Site Moderator
APS-S comes from 'Advanced Photo System'...remember those 35mm film cameras that could take normal or wide 'panoramic' photos? Basically APS was smaller than 35mm film...about the size of modern 'crop' sensors.
I think that's how it goes...
Back to the original question...lenses designed for 35mm SLR film cameras will be OK for 'full frame' digital. (Any Canon "EF" lens...but not "EF-S" lens)
Thanks for the info guys.
Ernst Haas
Socrates
But the term describes lens mounts as well.
Canon's 1.6 sensor uses EF S mount lenses while their 1.3 FF and some older 1.6 cameras use the EF mount. It really helps because most people considering a FF camera are considering a Canon.
Village Idiot
"DX" does not describe a lens mount. I don't use Canon gear but I never heard anyone use the term "APC-C" to describe a lens mount. My understanding is that Canon lens mounts are described as "EF" and "EF-S" but I could be wrong.
Socrates
Maybe I should have phrased that differently. But there are DX designated lenses but not APS-C designated lenses. Canon uses EF and EF S to describe which mounts are for what cameras and since you can't use an EF S mount lens on an EF mount camera without breaking things, then it is important when talking about FF cameras.
Village Idiot
But there are DX designated lenses..
That has absolutely nothing to do with the lens mount. The "DX designated lenses" WILL mount on Nikon film cameras and Nikon FX sensor cameras without any problem. Of course, the lenses won't properly illuminate the film or sensor frame but that's an entirely different issue.
Village Idiot
Obviously, "APS-C" is NOT a designator for a Canon lens mount.
Socrates
Which is stil semi-relevant to the OP's question. If he is talking about the D3(correct model yes?) he really does need a "special" lens or else he won't be utilizing the full capacity of the camera.
Village Idiot
I responded to the OP many post ago. However, too many newbies get needlessly confused when incorrect semantics are used. The point that I was making to you is that DX and APS-C are NOT, in any manner, shape or form, lens mount designators.
You can use the lenses, the camera will automatically crop down the image though. at least with Nikon, a D3 with a DX lens attatched will crop the image down to 5.5MP from 12MP
Nikon, D80,
AF Nikkor 50mm f/1.8D,
AF-S Nikkor 70-300mm f/4.5-5.6 VR,
Promaster XR EDO 17-50mm f/2.8,
Nikon Speedlight SB-600,
Manfrotto 727B Tripod, Lowepro Camera Slingbag
Come see, share, comment, and critique!!!
"The monthly Photo Challenge" cutting room floor
