Results 1 to 10 of 10
  1. #1
    Join Date
    Sep 2004
    Wisconsin
    Posts
    594
    My Gallery
    (0)
    Liked
    6 times
    Changing Pixel Dimensions
    I want to print an 11X14 picture at a local camera store. The digital file has a pixel dimension of 3072 by 2048. The store says for an 11X14 I need a minimum of 2800 X 2200, so I am short on the one end. I start looking around in Photoshop and find the Image Size menu where I can change the pixels to anything I want. Hell I could make it 9000 by 6000 and have a 154MB sized file. Now my question is, will that allow me to make larger prints, or is there a draw back for doing this? Will I lack in quality if the pixel dimensions are messed with?
    Thanks,
    Doug
    http://www.wxnut.net
  2. #2
    TPF Junkie!
    Join Date
    Jun 2004
    Austria, heart in Poland -->
    Posts
    2,240
    My Gallery
    (0)
    Liked
    0 times
    depends on the dpi (dots per inch).
    "Parsley, Sage, Rosemary and Thyme"
    Unknown
    http://www.artofart.com ... keep it real
    Hasselblad 500 C/M
    Pentacon Six TL
    Leningrad (Heliar 15mm)
  3. #3
    Join Date
    Sep 2004
    Wisconsin
    Posts
    594
    My Gallery
    (0)
    Liked
    6 times
    OK. In the same Image Size window in photoshop, it has a 72 for the DPI. Should I change that as well? Will that affect quality?
    Doug
  4. #4
    TPF Junkie!
    Join Date
    Jun 2004
    Posts
    2,240
    My Gallery
    (0)
    Liked
    0 times
    it will. 72 dpi is not enough to change a 2800 X 2200 pic into a 9000 X 6000 pic. If you had for example 600 dpi you could without any loss of quality. 72 dpi is "real size", you can't enlarge the pic, it's highest quality is at it's actuall size.
    Unknown
    Hasselblad 500 C/M
    Pentacon Six TL
  5. #5
    alter ego: Analog Matt
    Join Date
    Jan 2004
    Santa Barbara, CA
    Posts
    5,346
    My Gallery
    (0)
    My Photos Are NOT OK to Edit
    Liked
    2 times
    What you should do is this. Change the dpi to 300. Uncheck resample before you do it. Now re-check resample, and change the pixel dimensions. Sounds like you have a 6mp image. You can get an 11x14 no problem, but you will have to crop. If you change your small dimension to 11, that leaves you with 16.5 on your other dimension. Do this, and then make a new document that is 11x14 @ 300 DPI. Copy the photo from the other document and paste it in, and then move it around with the move tool until you find a suitable crop.
    Make sense?
  6. #6
    Join Date
    Sep 2004
    Wisconsin
    Posts
    594
    My Gallery
    (0)
    Liked
    6 times
    I think I understand, but may have an easier way to do it.
    Open photo. Select the crop tool. Then in toolbar, select 300dpi and change dimensions to 11X14 then when you make the crop, it will be done. Doing this turned my 3072 by 2048 72 dpi picture into a 4200 X3300 300 dpi file.
    Ill post when I get the prints back to see if they look good.
    Doug
  7. #7
    hOtLiPs!
    Join Date
    Feb 2004
    Here....there....everywhere
    Posts
    3,849
    My Gallery
    (0)
    Liked
    0 times
    Something about that doesnt sound right. Arent you adding more information into it thans already there?
    Kara
    Ramblings of a slightly insane, displaced chicky.
    SHUTTERvisions - a photoblog.
    Mark von Nagy says:
    Upload this, baby
    Kia mau te wehi!
  8. #8
    Join Date
    Jan 2004
    Santa Barbara, CA
    Posts
    5,346
    My Gallery
    (0)
    Liked
    2 times
    That works too. Whatever way you like. I prefer doing it the way I mentioned because You don't see the parts of the photo that are being cropped. It's easier for me to see what the final composition will look like.
  9. #9
    Join Date
    Jan 2004
    Santa Barbara, CA
    Posts
    5,346
    My Gallery
    (0)
    Liked
    2 times
    Kara, you have to do that to get an enlargement. There is an acceptable limit to which you can "stretch" an image before quality loss is too great. It's the similar for film.
    I've stretched prints from my 6.3mp camera to 16x24 @ 300dpi, and had prints up to 20x30 at 220 dpi with excellent results. If you view the document at "print size" in photoshop you will get an approximate proof of how it will look in print. The quality of the printer has a lot to do with the final result as well.
  10. #10
    Join Date
    Nov 2004
    San Diego, CA USA
    Posts
    4
    My Gallery
    (0)
    Liked
    0 times
    try this for enlarging digital pictures. i have used one photo enlargement program with great success called imagener. you can find it here: http://www.imagener.com. hope this helps! -dh
    Quote Originally Posted by santino
Ads
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Similar Threads
  1. Dimensions for a photo book?
    By Restomage in forum Photographic Discussions
    Last Post: 05-11-2010, 02:18 PM
  2. Insufficient image dimensions
    By hdukphotographs in forum Photography Beginners' Forum
    Last Post: 05-20-2008, 11:19 AM
  3. printing dimensions
    By SBlanca in forum Beyond the Basics
    Last Post: 05-10-2008, 03:25 PM
  4. Photo dimensions?
    By ~Stella~ in forum Photography Beginners' Forum
    Last Post: 09-04-2007, 12:47 PM
  5. 1 pixel camera....not 1 mega pixel
    By darich in forum Digital Discussion & Q&A
    Last Post: 02-02-2007, 11:11 AM
11x14 in pixels
11x14 inch print is what pixel
11x14 print pixel size
11x14in pixel dimension
height and width of 11x14 for printing
how many pixels to print 11x14
photo dimensions 11x14
pixel size for 11x14
pixels for 11x14
what is an 11x14 picture in pixels?
