Results 1 to 10 of 10
  1. #1
    Join Date
    Oct 2008
    Tampa Bay Area
    Posts
    28
    My Gallery
    (0)
    My Photos Are NOT OK to Edit
    Liked
    0 times
    Problem with Background Wrinkles
    Hope this is the right place to post this, but anyway here goes.
    I've been gearing up to do some portrait shoots in a home studio setting and have some backgrounds that I've got to use. My problem is that the backrounds are something like 10 feet x 12 feet and aren't exactly iron friendly. I've tried using a clothes steamer and have had no luck getting the wrinkles out hence my shots are wrinkled (see the attachment in this post).
    Has anyone out there had this or a similar problem and if so what did you do to solve it? Is there some kind of professional that will press a huge canvas sheet like this?
    Attached Images Attached Images
    Matt Newby
    Nikon D700
    Nikon 70-300mm f/4.5 - 5.6G ED-IF AF-S VR
    Nikon 24-120mm f/3.5 - 5.6G ED-IF AF-S VR
    Nikon 50mm f/1.8D AF
  2. #2
    Join Date
    Apr 2008
    Michigan
    Posts
    352
    My Gallery
    (0)
    Liked
    6 times
    i think you just need a lot more light since your background is wrinkled. like with a lot more light, itll smooth out the wrinkles in the plain white background.
    plus some editing in photoshop should help if you go to image>adjustments>selective color, and bring the whites down a little, that will make the background 'whiter' without totally ruining hilights
    if you really cant stand the wrinkles, you could try hanging the sheet in the bathroom where it can get smoothed out by the steam if someone takes a shower
    heres a couple i did with a very similar problem. i have a ghetto rigged studio with a white bedsheet, worklamps, and then i just bounce my sb600 flash
    Just some broke ass Nikon, Praktica, and Yashica equipment
  3. #3
    Banned
    Join Date
    May 2007
    Madoc, Ontario Canada
    Posts
    2,107
    My Gallery
    (0)
    My Photos Are OK to Edit
    Liked
    0 times
    Quote Originally Posted by mcnewby View Post
    im sure your local dry cleaner will do this... the key to preventing it is proper storage.. roll it up nice and tight and it wont wrinkle... i use a thick material for my back drop, its the same thing that is use to make the fancy table cloths in fancy resturants.. it doesnt wrinkle.. ate least i havent been able to get it to yet
  4. #4
    Join Date
    Dec 2007
    Chicago IL
    Posts
    453
    My Gallery
    (0)
    Liked
    0 times
    Do you have PhotoShop? You can easily go in and eliminate wrinkles in photoshop.
    Sony A100
    Sony A700
    Maxxum 400si
    Maxxum 7000
    Maxxum HTSI Plus
  5. #5
    TPF Junkie!
    Join Date
    Oct 2007
    Montreal, QC, Canada
    Posts
    6,083
    My Gallery
    (0)
    Liked
    5 times
    - You could go in with photoshop and get rid of the wrinkles using layers
    - Another way is to increase your distance from the subject to the background and use a shallow DOF. This is the way I would do it, room permitting.
  6. #6
    TPF Junkie!
    Join Date
    Dec 2007
    Cincinnati
    Posts
    1,235
    My Gallery
    (0)
    Liked
    0 times
    I had the same problem with a 10X30 ft. piece of muslin that I was using. I got the wrinkles out by hanging it in the bathroom like stated above, and then rolled it tightly on a piece of pvc pipe.
    Nikon Stuff...
    www.RDphotos.com
  7. #7
    Banned
    Join Date
    May 2007
    Posts
    2,107
    My Gallery
    (0)
    Liked
    0 times
    Quote Originally Posted by jlykins View Post
    thats what i use too!
  8. #8
    I am Big, I am Mike Site Moderator
    TPF Supporter
    Join Date
    Dec 2003
    Edmonton
    Posts
    33,472
    My Gallery
    (111)
    Liked
    1672 times
    Here's a tip I learned. Gently spray the fabric with water (a misting spray bottle). As it drys, the wrinkles should release. Of course, you could just toss it into the dryer with a damp towel and then take it out and hang it up right away.
    If you think about why the wrinkles show up in the photo...what we see is actually the shadow of the wrinkle...and shadows are caused by light. So if the light hitting the background is hitting it straight on, the camera won't see the shadows. Or, you could add another light to hit the background from the other side and fill in those shadows.
    Or you could blast the background with enough light to blow it out...but you might still need to fill in the wrinkle shadows.
    Either way, a wrinkle free backdrop is the best scenario.
    As mentioned, it should help if you can move the subject away from the backdrop and use a shallow DOF to blur it. You can also use Photoshop to clean up and/or blur the backdrop. But believe me, this is one thing that is easier to fix before you shoot, rather than in Photoshop, especially if you want to use several of the photos.
  9. #9
    TPF Junkie!
    Join Date
    Oct 2008
    Chesterfield UK
    Posts
    13,002
    My Gallery
    (0)
    Liked
    2018 times
    Stretch it out and gaffer tape it
  10. #10
    Join Date
    Oct 2008
    Tampa Bay Area
    Posts
    28
    My Gallery
    (0)
    Liked
    0 times
    Thanks for all of the help in the replies. I'm keen on getting the wrinkles out before shooting since it will save time later in Photoshop. Worst case then I will move the subject out/away from the fabric and use the smaller DOF.
    Thought I had the lighting such that it would keep the wrinkles from showing up but obviously not. Had a 1000w work light on the left, and two SB800s with shoot through umbrellas, one to the right and the other in front of the subject.
    Matt Newby
    Nikon D700
Ads
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Similar Threads
  1. wrinkles :(
    By stephras07 in forum Photography Beginners' Forum
    Last Post: 11-20-2010, 07:24 AM
  2. Wrinkles years
    By عبدالله الشــبا in forum People Photography
    Last Post: 03-18-2010, 08:37 PM
  3. getting wrinkles out of backdrops!!
    By Sontizzle in forum Beyond the Basics
    Last Post: 05-13-2008, 04:01 PM
  4. Haven't quite ironed out the wrinkles...
    By Trenton Romulox in forum Off Topic Chat
    Last Post: 01-22-2008, 08:54 PM
  5. wrinkles
    By D3sh1 in forum The Black & White Gallery
    Last Post: 01-09-2008, 04:30 PM
how do i smooth the background in photoshop
how do you get rid of creases in background in pse
how to easily smooth a background in photoshop
how to remove wrinkled backdrop on photoshop
how to remove wrinkles in backdrop in photoshop elements
how to smooth background in photoshop
photoshop how to smooth wrinkler in background
quick ways to remove backdrop wrinkles from multiple photos in photoshop
Tags for this Thread
