Results 1 to 6 of 6
  1. #1
    Join Date
    Nov 2008
    North Nottinghamshire (UK)
    Posts
    9
    My Gallery
    (0)
    My Photos Are NOT OK to Edit
    Liked
    0 times
    Afew questions about flash units
    Hi all, wondering if anyone could answer these questions, im new in photography and im currently using a fuji finepix s5800, I'm wanting to upgrade to a DSLR camera shortly but i couldn't justify spending that ammount of money on a camera then realising photography isnt for me.
    anyway, I'm wanting to know if any external flash units work with the s5800?
    if so which ones do? im looking to buy 2 if they work with my camera as some of the places i take photos in (car shows mainly, alot of which are indoor or have poor light outside)
    Thanks for any help, Danny
  2. # ADS
    Ads
    Google Advertisement
    Join Date
    Always
    Advertising world
    Posts
    Many
  3. #2
    I am Big, I am Mike Site Moderator
    TPF Supporter
    Join Date
    Dec 2003
    Edmonton
    Posts
    32,076
    My Gallery
    (111)
    Liked
    1213 times
    Does your camera have a hot shoe? I just found a photo if it, and it looks like it does not have a hotshoe....I'm guessing it doesn't have a PC port either, so the only option for triggering an external flash will be optically. An 'optical slave' is something that triggers a flash when it detects that another flash has been fired. These can be very inexpensive and fairly easy to use. EXAMPLE
    The problem with these (and your camera) is that your camera's built-in flash probably uses a pre-flash for metering. So when you try to trigger a remote flash, the pre-flash will set of the optical trigger and the remote flash will not be able to fire again quickly enough for the actual exposure.
    For this reason, there are optical triggers that can be set to ignore the pre-flash. EXAMPLE
    These optical triggers can fire pretty much any 'hot shoe' type flash unit.
    One problem with a set up like this, is that other flashes can also trigger your lights. So at a car show, for example, they might be impractical because a lot of people may be snapping photos.
    There's no correlation between creativity and equipment ownership. None. Zilch. Nada. Actually, as the artist gets more into his thing, and as he gets more successful, his number of tools tends to go down. He knows what works for him. Expending mental energy on stuff wastes time.
    Hugh Macleod
    Edmonton Wedding Photographer ==>Blog
    Instructor at The Canadian Photography Learning Centre.
  4. #3
    Join Date
    Jun 2008
    Litchfield Park, AZ
    Posts
    505
    My Gallery
    (0)
    My Photos Are OK to Edit
    Liked
    0 times
    I looked at the camera at dpreview, and it looks like you don't have a hot shoe or sync chord hook up but you might be able to fire an external flash with your pop up flash. It's not as reliable as other methods but it can be done. Learn everything about external strobes at strobist.
  5. #4
    Join Date
    Nov 2008
    Posts
    9
    My Gallery
    (0)
    Liked
    0 times
    no it doesnt have a hot shoe, and the only ports are an av out and a dc input, will have to look into the flash triggers
    I had a quick search on ebay and found afew that say they work with the s5800 and various other finepix cameras
    Bower SLAVE Flash for FUJI S5800 S5700 S7000 S800 S700 on eBay, also, Flash Units, Flashes, Cameras Photo (end time 16-Feb-09 02:54:33 GMT)
    and
    Digital Slave Flash for FUJI S700 S800 S5700 S5800 S2 on eBay, also, Flash Units, Flashes, Cameras Photo (end time 06-Feb-09 00:18:33 GMT)
    are these any good?
    Thanks again for the help
    Danny
  6. #5
    TPF Supporter
    Join Date
    Dec 2003
    Edmonton
    Posts
    32,076
    My Gallery
    (111)
    Liked
    1213 times
    The page says it will work with your camera...I guess it does.
    Hugh Macleod
  7. #6
    Join Date
    Nov 2008
    Posts
    9
    My Gallery
    (0)
    Liked
    0 times
    will give the cheaper one a try when i get some spare cash
    thanks for the help guys
Ads
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Similar Threads
  1. Using old (film) flash units with DSLRs?
    By iolair in forum Photography Beginners' Forum
    Last Post: 02-07-2012, 05:53 PM
  2. Flashguns & Flash Units
    By SBlanca in forum Buy and Sell
    Last Post: 11-04-2008, 04:35 PM
  3. What to do with my great old flash units
    By carusoswi in forum Beyond the Basics
    Last Post: 08-23-2007, 09:22 PM
  4. Flash units for Pocket Wizards
    By uberben in forum Beyond the Basics
    Last Post: 03-18-2007, 11:29 PM
  5. Flash units?
    By mattvillano in forum Photography Equipment & Products
    Last Post: 04-01-2004, 04:13 PM
