Results 1 to 15 of 20
Thread: Getting my Sb-800 Wireless
04-10-2009, 08:07 AM #1I spend too much of my life on TPF!
- Join Date
- Jan 2009
- Location
- Iowa
- Posts
- 784
- My Gallery
- (0)
- My Photos Are NOT OK to Edit
- Liked
- 1 times
Ok here's the deal. I already know how to do this with my D90, but I had my D90 replaced and the new one I received doesn't seem to be working correctly. Here's what's going on.
I want to have have my camera trigger the flash wirelessly, so I set my flash on remote. Then I go into my flash settings on my camera, I tell the built in flash to be a commander instead of TTL. Then I go to the next screen and tell the built in flash to be (--) which means it should be inactive. Then I tell my speedlight to be manual at say 1/4 power. I should be good to go. I open my pop up flash (without doing that it wont trigger the speedlight) and I dial in my settings. I focus, compose, then shoot and strangely enough, both flashes go off. The pop up shouldn't even go off with the (--) setting. My other D90 never had this issue but I'm thinking this one might be defective. Am I missing something?
04-10-2009 08:07 AM # ADS
04-10-2009, 08:18 AM #2Watch the Birdy! Site Moderator
- Join Date
- Jul 2005
- Location
- Southern Vancouver Island, BC
- Posts
- 17,117
- My Gallery
- (25)
- My Photos Are OK to Edit
- Liked
- 2611 times
I may be missing something, but if you have your built-in flash set to Commander, then it has to go off to trigger the slave. The CLS works because the slave units sense the illumination from the commander and fire accordingly. It sounds to me like it's working exactly the way it should.
04-10-2009, 08:23 AM #3I spend too much of my life on TPF!
- Join Date
- Jan 2009
- Location
- Iowa
- Posts
- 784
- My Gallery
- (0)
- Liked
- 1 times
What you say makes sense, but if I recall my first D90 never triggered the pop up flash, it simply sent out a signal to trigger the SB-800
04-10-2009, 08:40 AM #4TPF Junkie!
- Join Date
- Oct 2007
- Location
- Montreal, QC, Canada
- Posts
- 6,081
- My Gallery
- (0)
- Liked
- 4 times
The answer is in here, I am pretty sure of it. Make sure the camera is in COMMANDER mode (if it can do this), and that the flash is up. If the camera cannot act as a commander, then the SB-800 has to be the commander.
Also, don't be afraid to reference your camera and flash manuals.
04-10-2009, 09:07 AM #5I spend too much of my life on TPF!
- Join Date
- Jan 2009
- Location
- Iowa
- Posts
- 784
- My Gallery
- (0)
- Liked
- 1 times
As I stated above, I did set the camera as a commander and the SB-800 was a remote slave. I set the camera to the mode (--) which should be off, then selected manual at 1/4 power for the SB-800. I popped the flash up so it would trigger the SB-800 and the SB-800 went off, but so did the pop-up. So basically, the pop up flash went off even when it was set at (--) which means off.
04-10-2009, 09:12 AM #6TPF Junkie!
- Join Date
- Mar 2008
- Location
- Shepherdsturd, WV / Almost, MD
- Posts
- 6,878
- My Gallery
- (0)
- Liked
- 328 times
The popup triggers the remote flash. That's how CLS works.
04-10-2009, 09:21 AM #7TPF Junkie!
- Join Date
- Jul 2007
- Location
- State of Confusion
- Posts
- 12,650
- My Gallery
- (0)
- Liked
- 1342 times
If your previous D90 did not fire the built in flash, then it had a fault. This is how the Commander mode works. Setting the built in flash to (--) will trigger the off camera flash but not contribute to the scene, unless you are up close and particularly at a reflective surface. All is good.
The Liver is Evil and Must Be Punished.
Shooter of FX, DX and MFT
I could be wrong, but I doubt it.
Two wrongs don't make a right, but three rights make a left.
You should never underestimate the predictability of stupidity. - Bullet Tooth Tony
04-10-2009, 09:42 AM #8I spend too much of my life on TPF!
- Join Date
- Jan 2009
- Location
- Iowa
- Posts
- 784
- My Gallery
- (0)
- Liked
- 1 times
(sigh of relief) thats good. I've been living on strobist for about 2 days now and finally getting the hang of using off camera flash. I went home last night to try a few things and noticed this and wanted to make sure everything was ok.
04-10-2009, 06:17 PM #9TPF Junkie!
- Join Date
- Oct 2003
- Location
- Brisbane, Australia
- Posts
- 9,636
- My Gallery
- (0)
- Liked
- 181 times
Send the signal by magic? CLS is an IR technology and the brightest source of IR on the camera is the flash.
Here's a trick. Set everything in the commander to (--) and take a photo. The CLS signal is encoded with the TTL pre-flashes. The flash fires and THEN the shutter opens. That way the flash triggers the wireless slave, but doesn't affect the image.
This is also why you can't take a photo of a cat using CLS when they are looking at the camera. The CLS flash + TTL preflashes are longer than their blink reaction so when the photo is actually taken they have their eyes closed.
04-11-2009, 07:49 AM #10TPF Junkie!
- Join Date
- Oct 2007
- Location
- Posts
- 6,081
- My Gallery
- (0)
- Liked
- 4 times
Using the remote manual mode cuts down on the # of preflashes (al TTL light measurement preflashes are removed) and this may let you get your cat before it blinks... but maybe not. Some cats are fast (lol).
04-11-2009, 09:34 AM #11TPF Junkie!
- Join Date
- Oct 2003
- Location
- Posts
- 9,636
- My Gallery
- (0)
- Liked
- 181 times
No maybe about it:
Figured it out a while ago. Shot in SU-4 mode manual 1/4 power, with camera flash set to manual 1/16th with my hand blocking the flash from hitting the cat directly.
04-14-2009, 10:41 PM #12Been spending a lot of time on here!
- Join Date
- Oct 2007
- Posts
- 101
- My Gallery
- (0)
- Liked
- 0 times
The only way to remotely fire an off camera strobe is with a PocketWizard or some equivalent. The commander mode works in IR and thus requires some form of flash from the pop-up. That is why the commander mode doesn't work when you are out of sight. If it was truly remote, as a PW is, then it wouldn't matter.
Cool shot of the cat, BTW.
04-15-2009, 07:34 AM #13TPF Junkie!
- Join Date
- Oct 2003
- Location
- Posts
- 9,636
- My Gallery
- (0)
- Liked
- 181 times
Hate to be the pedantic engineer here, but remote means exactly that. Not directly attached. Now whether the signal is sent via light, radio, microwave, or even sound, remote is still remote. Much like your infrared TV remote.
Not being able to shoot around corners makes it no less of a remote.
(esp given the price of PWs
04-16-2009, 06:34 PM #14Been spending a lot of time on here!
- Join Date
- Oct 2007
- Posts
- 101
- My Gallery
- (0)
- Liked
- 0 times
12-30-2010, 02:59 PM #15TPF Junkie!
- Join Date
- Jun 2010
- Location
- minnesota
- Posts
- 3,302
- My Gallery
- (0)
- Liked
- 576 times
Similar Threads
What is the Best Value going Wireless
By leroyneal in forum Photography Equipment & ProductsReplies: 47Last Post: 03-20-2010, 11:59 PM -
Wireless SB-600 and D40
By Applefanboy in forum Beyond the BasicsReplies: 9Last Post: 05-22-2008, 02:48 PM -
Wireless
By dtlasky in forum Photography Equipment & ProductsReplies: 1Last Post: 11-12-2007, 03:55 AM -
sb-600 wireless?
By just x joey in forum Photography Equipment & ProductsReplies: 2Last Post: 06-28-2007, 05:36 PM -
Wireless at last!
By PlasticSpanner in forum Off Topic ChatReplies: 6Last Post: 05-08-2006, 09:37 PM
d90 wireless flash wirh sb800
,does sb800 works as remote flash
,get my sb800 out of manual mode
,how to remote trigger sb800
,how to set up sb800 as slave to d40
,how to setup sb800 with wireless flash trigger
,romote sb800 with d700
,sb 800 wireless trigger
,sb 800 wirelews flash
,sb-800 fla? kablosuz kullan?m?
,sb-800 remote operation d90
,sb800 remote trigger
,shooting in manual mode with sb800
,shooting off camera flash sb800 and d700
,using a remote trigger with d700 and sb800
LinkBack URL
About LinkBacks
