Results 1 to 6 of 6
  1. #1
    Join Date
    Apr 2009
    Arizona
    Posts
    426
    My Gallery
    (0)
    Liked
    20 times
    Off-camera Flash Setup
    Okay, I am about to purchase an off-camera flash setup but I do not know a lot about exactly what I will need.
    Currently, I have a 430EX Speedlite for my Canon, which initially I will use as a slave unit (despite it's lack of power compared to the 580 or studio strobes). I plan to get a 580EXII as my on-camera master. I decided to go with a battery flash setup since I will not have to put as much money in, plus I will need it for on-location shoots.
    So my question is basically this: I realize that I will need to purchase the Speedlite, lightstand and a softbox or umbrella but what else will I need to make this setup work? Do I need a lightstand adapter to connect the softbox (in MOST cases)? I have never used a speedlite as a slave, so are lightstands typically already capable of attaching my flash unit to?
    Any help is greatly appreciated!
    "Trying is the first step to failure” - Homer Simpson
  2. #2
    Join Date
    May 2009
    Alabama
    Posts
    64
    My Gallery
    (0)
    My Photos Are NOT OK to Edit
    Liked
    0 times
    I'm sure you are going to get a lot of advice with those questions. Here's mine.
    Check out strobist.com. Read through the 101 and 102 tutorials. Not only will you have a basic understanding of off-camera lighting, but the equipment required/desired.
    Secondly, there are several companies out there offering "Strobist Kits" which should include everything you'd need to get started. I've heard the MPEX kits are really good.
    John Bergsing Photography
    My Flickr Photostream
    My Facebook Biz Page
    Canon 40D w/ battery grip, 24-70mm f/2.8L USM, 70-200mm f/2.8 IS USM, 580EX II, and a variety of other equipment that is too long and boring to mention...
  3. #3
    Join Date
    Apr 2009
    Arizona
    Posts
    426
    My Gallery
    (0)
    Liked
    20 times
    Quote Originally Posted by johnbergsing View Post
    Thank you for the links. The Strobist tutorials (in conjunction with a few other readings) are really clearing up some of the questions/confusion I have had in regard to off-camera lighting.
    The kits in the link are surprisingly affordable! I now know exactly what I need to get the setup I want... I still plan to go with a battery flash setup since it makes more sense to have the portability and therefore flexibility that it affords.
    Thank you once more
  4. #4
    Join Date
    Jan 2009
    Iowa
    Posts
    784
    My Gallery
    (0)
    Liked
    1 times
    You need to purchase a lightstand, umbrella swivel adapter, and a cold shoe adapter (since you are firing the flash using the 580). I'm not sure about the softbox adapter, I guess the ones I'm looking at, you dont need them.
  5. #5
    Join Date
    Apr 2009
    Arizona
    Posts
    426
    My Gallery
    (0)
    Liked
    20 times
    Quote Originally Posted by bdavis View Post
    Great, thank you! By the way, what are you looking into? Is it basically the same but using an umbrella instead of a softbox? If so, I am sure that's easier (and something I should look at if I can live with the difference in directional light) since the swivel head has spot for the umbrella.
  6. #6
    Join Date
    Jan 2009
    Iowa
    Posts
    784
    My Gallery
    (0)
    Liked
    1 times
    This is what I'm leaning towards for a softbox. Its great. Even has velcro on the front that you peel back so you can get to your flash and change settings quickly.
    http://www.bhphotovideo.com/bnh/cont...u=62240&is=REG
Ads
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Similar Threads
  1. Off camera flash setup - suggestions?
    By burstintoflame81 in forum Photography Beginners' Forum
    Last Post: 02-24-2010, 08:06 PM
  2. OFF CAMERA FLASH SETUP (CANON)
    By sinjans in forum Photography Equipment & Products
    Last Post: 01-28-2010, 10:43 AM
  3. New off camera flash setup.
    By JayClark79 in forum People Photography
    Last Post: 11-13-2009, 02:15 PM
  4. flash setup
    By FDSA in forum Photography Beginners' Forum
    Last Post: 06-07-2009, 01:44 PM
  5. The ultimate in remote camera & flash setup
    By Big Mike in forum Photography Equipment & Products
    Last Post: 03-01-2008, 07:05 AM
basic off camera flash setup
best off camera flash setup
flash photography setup
flash setup
flash setups
how to set up off camera flash
off camera flash set up
