Results 1 to 11 of 11
07-01-2009, 07:57 PM #1I spend too much of my life on TPF!
- Join Date
- May 2007
- Posts
- 633
- My Gallery
- (0)
- My Photos Are NOT OK to Edit
- Liked
- 0 times
Graduated Neutral Density Filters
I'm considering getting one of these, but one aspect of it doesn't make sense to me.
Looking at the filters, the gradient ends virtually halfway down the filter. This means, in order to use it most effectively, I would have to shoot my landscape so the horizon is dead center. If I adjust the composition in either direction, the ND effect would be off.
What, do these filter makers follow the rule of halves?
What am I missing?
Thanks,
JonNikon D80
Nikkor 18-70mm f/3.5 - 4.5
Nikkor 50mm f/1.8
Sigma 10-20mm f/4 - 5.6
Nikon SB-600 Speedlight
Nikon SB-80 Speedlight x 3
Lens cap
One time, this guy handed me a picture of him, he said, "Here's a picture of me when I was younger." Dude, every picture is of you when you were younger.
- Mitch Hedberg
07-01-2009 07:57 PM # ADS
07-01-2009, 09:45 PM #2TPF Noob!
- Join Date
- Jul 2009
- Location
- Atlanta, GA
- Posts
- 12
- My Gallery
- (0)
- My Photos Are OK to Edit
- Liked
- 0 times
You'll want to get a Cokin Filter holder (I use the P-series) and adapter for your lens. The holder allows you to slide and/or rotate the GND filter to align the gradient with your subject.
Cokin Filter System
07-02-2009, 07:55 AM #3TPF Junkie!
- Join Date
- Sep 2007
- Location
- Missouri
- Posts
- 2,716
- My Gallery
- (0)
- Liked
- 16 times
Your Grad ND should fade out....i.e. get lighter the farther down it goes. If this is the type of Grad ND filter you have then you should be able to shoot normal (say 1/3 land and 2/3 sky) and the Grad ND will fade out throughout the sky portion. So basically it will darken the top the most and gradually dissapear so that there's no prevalent line.
No there are Grad ND's that basically have a hard line where the transition is, but I wouldn't want to use one of those anyway for the reason's you are stating.Last edited by NateS; 07-02-2009 at 08:42 AM.
www.sidersphoto.com
Bodies: Nikon D90+MB-D80, Nikon D5000, Canon A620
Lenses:Tamron 17-50 f2.8, Tamron 180mm f3.5 Macro, Nikon 50mm f1.8
Lens Acc: Full Kenko Extension Tube Set (68mm), Kenko Pro 300 1.4TC
Flashes: SB-600, SB-400 umbrella/stand/diffuser/softbox/mini-softbox, sync cord, etc...
07-02-2009, 08:17 AM #4I am Big, I am Mike Site Moderator
- Join Date
- Dec 2003
- Location
- Edmonton
- Posts
- 32,074
- My Gallery
- (111)
- Liked
- 1213 times
If you are looking at circular grad filters...they don't make sense to me either. I wouldn't bother with them.
If you want to use grad filters, get the rectangular ones (Cokin for example), that way you can place the split where you want it in your composition. There are filter holders that attach to the lens but I've also seen some pretty good photographers who just hold them in front of the lens for the shot.
There's no correlation between creativity and equipment ownership. None. Zilch. Nada. Actually, as the artist gets more into his thing, and as he gets more successful, his number of tools tends to go down. He knows what works for him. Expending mental energy on stuff wastes time.
Hugh Macleod
Edmonton Wedding Photographer ==>Blog
Instructor at The Canadian Photography Learning Centre.
07-07-2009, 09:59 AM #5I spend too much of my life on TPF!
- Join Date
- Jan 2009
- Location
- Germany, Bonn
- Posts
- 660
- My Gallery
- (0)
- Liked
- 0 times
Here is the same scene with and without a powerfull ND8 Filter. I bought one by accident , but still find it useful:
Without ND:
With ND:
07-07-2009, 10:02 AM #6TPF Junkie!
- Join Date
- Jun 2008
- Location
- Arizona
- Posts
- 9,893
- My Gallery
- (3)
- Liked
- 8 times
On this topic ... I just got LR2 and I know there is a Grad ND function in it. Does this really work? Can I get rid of my Grad ND filters?
Ian
Canon 7D, Canon 30D, Sigma 10-20 f/4.5-5.6, Tamron 17-50 f/2.8, Canon 50 f/1.8 Mark I, Sigma 50-150 f/2.8, Canon 100 f/2.8 Macro, Sigma 100-300 f/4, Canon 400 f/5.6L, Sigma 1.4X & 2X EX TC, Canon 430EX, Bogen 3021 Tripod/Gitzo 1377M
MY BETTERPHOTO
MY SMUGMUG
"If I have seen further , it is by standing on ye shoulders of giants." -- Sir Isaac Newton in a letter to Robert Hooke 15 February 1676 (... and a long telephoto doesn't hurt either ...)
07-07-2009, 10:24 AM #7I spend too much of my life on TPF!
- Join Date
- Jun 2008
- Location
- Whitstable
- Posts
- 573
- My Gallery
- (0)
- Liked
- 0 times
07-07-2009, 11:05 AM #8TPF Junkie!
- Join Date
- Jun 2008
- Location
- Arizona
- Posts
- 9,893
- My Gallery
- (3)
- Liked
- 8 times
Ian
MY BETTERPHOTO
MY SMUGMUG
07-07-2009, 11:52 AM #9I spend too much of my life on TPF!
- Join Date
- Jun 2008
- Location
- Whitstable
- Posts
- 573
- My Gallery
- (0)
- Liked
- 0 times
(I should have specified this only applies to RAW - obviously ND emulation is a bad idea if your shots are saved as JPEG's)
When you take a picture and store it in raw there is a 'lattitude' that you can access when you 'develop' the RAW image to TIFF or JPG. A sort of after the event exposure compensation.
If you are relying on using post processing to give you the effect of a graduated ND filter you will no longer be able to use some or all that lattitude because it will be used to perform the ND filter emulation.
So, if you expose perfectly (and the degree of ND is within the RAW lattitude) everything should be OK but if you are out what would have been recoverable may no longer be completely recoverable because the ND emulation is using some or all of the available lattitude.
07-07-2009, 11:53 AM #10TPF Junkie!
- Join Date
- Jun 2008
- Location
- Arizona
- Posts
- 9,893
- My Gallery
- (3)
- Liked
- 8 times
Ian
MY BETTERPHOTO
MY SMUGMUG
07-08-2009, 04:07 AM #11TPF Junkie!
- Join Date
- Oct 2003
- Location
- Brisbane, Australia
- Posts
- 9,640
- My Gallery
- (0)
- Liked
- 191 times
On that note it works exceptionally well in cases where the highlights have only just been rebuilt. As lightroom works directly with the linear RAW data, and invokes highlight recovery algorithms every time you take the exposure slider into negative, it's amazing how much detail is actually still available in a photo, which is visually lost when it is adapted via a gamma curve to be displayed on a screen or processed in a camera.
Bear in mind though this works only on RAWs, and in Nikon's case works far better with RAW compression disabled. But then it also only works up to a point. If your scene is simply way too bright and the odd highlight is clipped in only 2 channels it'll work well. If you have actually completely clipped the sky it will do nothing for you.
Similar Threads
Graduated neutral density filter
By CJThePhotographer in forum Photography Beginners' ForumReplies: 4Last Post: 02-22-2010, 12:08 PM -
Graduated Neutral Density Filters and "macro kit" questions
By Abby Rose in forum Photography Beginners' ForumReplies: 4Last Post: 02-17-2010, 06:58 PM -
Smaller graduated neutral density filter?
By 150mph in forum Beyond the BasicsReplies: 4Last Post: 07-28-2009, 01:02 PM -
By Iron Flatline in forum Beyond the BasicsReplies: 20Last Post: 09-08-2006, 08:13 PM -
Graduated Neutral Density filter
By mattvillano in forum Beyond the BasicsReplies: 4Last Post: 12-16-2004, 09:09 AM
aligning nd filter
,best graduated neutral density filter for nikon d5000
,filters for nikon d90
,gnd filter for nikon d90
,gradient filter, 68mm
,graduated nd filters for nikon d90
,graduated neutral density filter for nikon d5000
,how to expose for neutral density
,how to expouse with gnd filter
,nd filter 68 mm
,nd grad filter for sigma 10-20
,neutral density filter d80
,neutral density filter nikon 50mm
,nikon d90 with neutral density
,nikon gnd filter
LinkBack URL
About LinkBacks
