Results 1 to 15 of 17
Thread: How do I increase d.o.f.
07-08-2009, 08:56 AM #1
Trying to learn how to adjust things manually to get more desirable results. After all, that's why I bought a DSLR.
I'm shooting with the kit lens (18-55)
Take this photo for example, shot at 55mm in AUTO mode.
I would like more of the image to be in focus. What do I need to do? Adjust ISO and F stop?
07-08-2009 08:56 AM # ADS
07-08-2009, 09:08 AM #2
Get out of Auto mode and switch to manual or Aperture priority and open the lens up.
I am the french fry in a box of onion rings.
07-08-2009, 09:15 AM #3I spend too much of my life on TPF!
- Join Date
- Jun 2009
- Location
- north west indiana
- Posts
- 380
- My Gallery
- (0)
- My Photos Are NOT OK to Edit
- Liked
- 0 times
use a large aperture
07-08-2009, 09:16 AM #4I am Big, I am Mike Site Moderator
- Join Date
- Dec 2003
- Location
- Edmonton
- Posts
- 32,059
- My Gallery
- (111)
- Liked
- 1206 times
Yes, switch to Aperture Priority mode but you want to 'stop down' the lens...not open it up.Get out of Auto mode and switch to manual or Aperture priority and open the lens up.
The DOF is controlled main by the lens aperture. The larger the aperture, the more shallow the DOF...so the smaller the aperture, the deeper the DOF. Now keep in mind that a smaller F number is a larger aperture and thus a higher F number is a smaller aperture.
So in Aperture mode, you could choose something like F11 or F16 etc. That should give you a lot more DOF. However, when the aperture gets smaller, the shutter needs to stay open longer...and if the shutter speed is too long (slow), then you will get blurry photos unless the camera and subject are perfectly still (use a tripod).
DOF is also controlled by the focal length. A shorter focal length (zoom) will give you a deeper DOF. The distance from the camera to the subject also has an affect on DOF...the farther away you are, the deeper it gets.There's no correlation between creativity and equipment ownership. None. Zilch. Nada. Actually, as the artist gets more into his thing, and as he gets more successful, his number of tools tends to go down. He knows what works for him. Expending mental energy on stuff wastes time.
Hugh Macleod
Edmonton Wedding Photographer ==>Blog
Instructor at The Canadian Photography Learning Centre.
07-08-2009, 09:16 AM #5
07-08-2009, 09:16 AM #6I am Big, I am Mike Site Moderator
- Join Date
- Dec 2003
- Location
- Edmonton
- Posts
- 32,059
- My Gallery
- (111)
- Liked
- 1206 times
He want's more DOF...so he needs a smaller aperture (high F number)use a large apertureThere's no correlation between creativity and equipment ownership. None. Zilch. Nada. Actually, as the artist gets more into his thing, and as he gets more successful, his number of tools tends to go down. He knows what works for him. Expending mental energy on stuff wastes time.
Hugh Macleod
07-08-2009, 09:18 AM #7I spend too much of my life on TPF!
- Join Date
- Apr 2009
- Posts
- 585
- My Gallery
- (6)
- Liked
- 1 times
"Open the lens" would be using a Larger aperture. This is actually a "smaller" number, like f/3.5 or therebouts.
To get MORE DOF, you would use a smaller aperture or larger number like f/22 or greater.
http://www.dofmaster.com/dofjs.htmlDon't be surprised if I don't respond. Taking a hiatus
07-08-2009, 09:18 AM #8
07-08-2009, 09:22 AM #9I spend too much of my life on TPF!
- Join Date
- Jun 2008
- Location
- Whitstable
- Posts
- 573
- My Gallery
- (0)
- My Photos Are OK to Edit
- Liked
- 0 times
If you switch to aperture priority mode the camera will change the shutter speed to allow for the smaller aperture.
This means that unless your camera is attached to a tripod you need to be careful that the speed does not drop below around 1/125th second. If it does then you will need to either find some more light or increase the ISO so that the shutter speed is 1/125 or greater..
(It *may* be possible to hand hold the lens at 1/60th especially if you are at the wide angle end of the lens' range but 1/125th is safer.)
07-08-2009, 09:25 AM #10I spend too much of my life on TPF!
- Join Date
- Jun 2009
- Location
- Posts
- 380
- My Gallery
- (0)
- Liked
- 0 times
sorry i missed the part that said you want the image in focus my bad...smaller aperture lol. (larger number)
07-08-2009, 09:27 AM #11
My bad, I misread what he wrote as well... I guess I'm used to people asking about the other way around
07-08-2009, 09:32 AM #12TPF Junkie!
- Join Date
- May 2007
- Location
- Slapamonkey, New York
- Posts
- 7,958
- My Gallery
- (28)
- Liked
- 5 times
Yes, that is exactly what he means, that will increase the DoF. This will require a longer Shutter speed or higher ISO.....you would prolly be better off adjusting shutter speed to compensate as much as possible. When the shutter speeds get too long to handhold (roughly 1/30) then bring up the ISO.
Can't understand Deviant Art?
Click banner for PL main site click here for my PL Gallery
I shoot Film, Expect Grain and don't bother bringing it up.
07-08-2009, 05:23 PM #13TPF Junkie!
- Join Date
- Dec 2007
- Location
- Flagstaff/Az
- Posts
- 2,302
- My Gallery
- (0)
- Liked
- 13 times
You will only want to adjust your ISO to a higher setting if the shutter spees is too slow for handheld or, if you use a tripod then it doesnt matter on a static object like your subject.
My suggestion though is since it is digital, start out wide open lower numbers, then adjust one stop and, shoot it, then do the same through all of the numbers and, compare photos. It will be a good way for you to see how things affect an image. You can do the same with ISO as well.
Back in the old film days when I was learning we didnt have a delete or review button and, had to take notes for each shot to learn what works and, what doesnt.I shoot therefore Iam.
Nikon D300
07-09-2009, 09:47 AM #14TPF Junkie!
- Join Date
- Jun 2009
- Location
- Woodstock, CT
- Posts
- 1,072
- My Gallery
- (0)
- Liked
- 0 times
I would reccomend getting "Understanding Exposure" by Bryan Peterson. Understand that ISO 100 to 200 is a 1 stop change meaning that changing from ISO 100 to ISO 200 is equivelent to going from 1/100 sec to 1/200 sec or going from f/8 to f/11. They're exactly the same. (Each cuts light entering the camera by half or in the case of ISO the sensitivity of the sensor.)
The difference is the effect you get from each change. F stops add or subtract DoF. Shutter speed effects motion blur and such. ISO just adds noise (in my experience).
Hope this helps.Nikon D60 / 18-55mm f/3.5-5.6G AF-S DX VR / Nikon 70-300mm f/4.5-5.6G ED-IF AF-S VR / 35mm f/1.8G DX AF-S / Nikon SB-600
My Flickr Page
Your life is historically meaningful /
And spans a significant time. -Bad Religion
07-10-2009, 10:51 PM #15TPF Junkie!
- Join Date
- Apr 2009
- Location
- New Hampshire
- Posts
- 1,228
- My Gallery
- (0)
- Liked
- 0 times
Haha I think it's funny to read the "smaller number, no wait, the larger number, or is it..." I'm not making fun of anyone because I'm guilty of it myself so don't take it personal.
Edit: If Noyze reads this... your avatar is awesome!
Canon 50D Gripped
~ 20-70 2.8L
~ 70-300mm f/4-5.6
~ 100mm f/2.8 macro
~ 50mm f/1.4
~ Canon Speedlite 430EXII with Lumiquest Ultrasoft
http://www.coffmanimages.webs.com
Similar Threads
How to increase sharpness?
By Thaash in forum Photography Beginners' ForumReplies: 15Last Post: 10-22-2010, 11:55 PM -
How to increase saturation naturally...?
By echoyjeff222 in forum Photography Beginners' ForumReplies: 6Last Post: 08-22-2010, 03:39 PM -
Increase stored PM's?
By christopher walrath in forum Feedback and SuggestionsReplies: 3Last Post: 05-28-2008, 09:24 PM -
View Count Increase
By Ajay in forum Off Topic ChatReplies: 6Last Post: 10-30-2007, 10:04 AM -
How to increase contrast without software?
By Brieti in forum Digital Discussion & Q&AReplies: 2Last Post: 02-17-2007, 10:04 AM
how to increase depth of field 18-55
,how to increase depth of focus increase f number
,how to increase dof
,how to increase f numbers
,increase depth of field tripod shutter speed
,increase dof aperture priority
,increase dof by 18-55
LinkBack URL
About LinkBacks
