+ Reply to Thread
Results 1 to 13 of 13
  1. #1
    Join Date
    Aug 2009
    Minneapolis
    Posts
    504
    My Gallery
    (8)
    My Photos Are OK to Edit
    Liked
    12 times
    color calibration confusions
    Help,
    I've been through many inexpensive colorimeters for my laptop, all have proved useless by producing a terrible color cast. I started getting work, so I had to do some WHCC test prints with just my laptop display's default LCD profile--the results were not bad. (the images I sent them for tests were very, very colorful and punchy, but later prints I ordered from them were more subdued in hue, and clearly showed a slight cyan/green cast in the skin tones.) So I had a problem.
    The last colorimeter I tried was a Pantone Huey Pro. It produced a very small pink cast on my display, so I had initially rendered it useless. But when I loaded up that color profile and looked at my troubled prints from WHCC, they were pretty close in hue and contrast--the Huey profile showed the subtle cyan and green issues that are in the prints.
    1. Should I just use this colorimeter for now, even though it has a slight pink cast? I think my eyes adjust to it after I stare at it for a moment, but I'm not sure, and I'm not sure if it adjusts enough for me to not make other color mistakes in my prints, especially in the neutral tones.
    2. When I open some images in Photoshop, they look dramatically different than when I preview them in Bridge (spacebar) or look at them in OS X's Preview. In Bridge and in Preview they look more contrasty and warmer (redder). I'm working in sRGB. All my Adobe programs are color synced. Why is this happening?
    3. When I upload sRGB jpegs to places like Facebook, the colors end up looking washed out after their systems process them. Does anyone know why that is happening and is there anything I can do? I want to start a Fan Page for my business and I would like my images to look like they do on my website or in Photoshop.
    Thanks for reading,
    KKamin
    PS: I fully realize that color correcting on a 6-bit laptop display is borderline retarded. And that I should have a newer, more trusted colorimeter by now. But I've sunk many thousands into the business up until now and unfortunately am at a point where I need some cash flow before I can continue with my hardware purchases.
    I shoot with a disposable Dora the Explorer camera
    I have a special 18-55mm lens made from tree bark and unicorn farts
    I start uncontrollable fires for my lighting
    member of ASMP
    www.kevinkaminphoto.com
    photography blog
  2. # ADS
  3. #2
    TPF Junkie!
    Join Date
    Oct 2003
    Brisbane, Australia
    Posts
    9,072
    My Gallery
    (0)
    My Photos Are NOT OK to Edit
    Liked
    76 times
    1. Is it your display that is a wrong cast or your your colorimeter? You say you get a pink tint after calibrating. Did you by any chance have a slight green tint before calibrating? Are you basing your opinion on the fact that before things look white? Maybe you're eyes have just adjusted to that fact.
    Now that you're thinking, you're probably right. One of the downsides of colour correcting a ****ty display is that you get very mediocre results. When I use my Eye-One Display 2 to calibrate my desktop monitor the results are perfect. When I use it to calibrate it my laptop it just tends to skew the colours. One of the issues is when you're very close to a display with crap viewing angles (say like a colour sensor to a laptop) you inadvertently pick up colour casts from adjacent pixels which are way outside their normal viewing angles, which can affect calibration. Different units give different results, but I haven't seen a unit totally immune to it (I have only first hand experience with Spyder 2 and i1 Display 2 though the rest is just anecdotes).
    I'd say stick with it, it sounds like it's only a slight cast. You're running a business so see the note below*
    2. I would want to hope they look different in Photoshop. Photoshop will (should) read the colour profile created by your Huey to adapt the colours in the file so they render correctly on your display. Most applications do not do this. You can check this in photoshop by clicking edit -> colour settings. Going to the RGB working profile, clicking the drop down box to select a colour profile, and checking what "Monitor RGB" is called. Do not select the profile, just check and then quietly cancel out of the dialogue.
    If the profile is correctly loaded it should say "Monitor RGB - the_profile_created_by_your_software.icc" If it's not correctly loaded it should say "Monitor RGB - sRGB IECsomethinorother"
    3. Let's assume for a moment you are actually uploading sRGB (you'd be surprised how many people aren't actually, but think they are when they complain about this), the issue may be related to what's going on in point 2. Are the results different to Photoshop (see point 2) or are they different to OS X Preview (are you really in sRGB?).
    * You seem to say you have a slight colour cast when comparing the image to your screen. Put the image down somewhere, go outside, relax, have a cigar, and come back and look at that image again without looking at your monitor or comparing the print to the screen. Can you still tell if it has a colour cast? This is exactly what your clients would see. Sure a carefully colour managed print with a slight cast may look like pure evil next to a calibrated screen, and we then think damn how do I perfect my art if I can't 100% rely on the results. But the answer more often then not is that you don't really need to. All we really need to do is produce an image that a client thinks is fantastic, and given how I get positive feedback from the few weddings I have shot I am beginning to think that the average client is colourblind
    "I am always satisfied with the best." -Oscar Wilde
    Larger versions always on flickr
    Best photos in my gallery
    Proud Supporter of The Pact
  4. #3
    Join Date
    Aug 2009
    Minneapolis
    Posts
    504
    My Gallery
    (8)
    Liked
    12 times
    Thanks, Garbz. Your advice helped me out a lot.
    member of ASMP
    photography blog
  5. #4
    Join Date
    Aug 2009
    Minneapolis
    Posts
    504
    My Gallery
    (8)
    Liked
    12 times
    Actually I had a follow up question or two if you have time.
    Quote Originally Posted by Garbz View Post
    Yes, it is using the profile I created with the colorimeter. And thank you, I assigned that profile to the Preview program and it matches Photoshop now.
    As for jpegs that are uploaded to image galleries looking washed out- they are sRGB, I don't work in any other color space currently. But I just watched a tutorial on saving jpegs for the web, and it recommended softproofing in Monitor RGB. I didn't understand why. I thought the web was more or less in sRGB and there didn't need to be any image corrections. I understand when I want to print an image to photo paper, there will be a change because of inks and paper, and I need to adjust for that. But when staying in the digital realm and publishing to the web, I don't see why there needs to be any adjustments. Is perhaps the image gallery I'm dealing with not working in sRGB but some kind of monitor RGB profile?
    member of ASMP
    photography blog
  6. #5
    Join Date
    Nov 2009
    Seattle
    Posts
    My Gallery
    (0)
    Liked
    0 times
    I used the spyder2express on my imac glossy screen - didn't really do anything. I took a couple print outs from various semi-professional printers and just eyeballed the calibration - so it was really really close.
    I wish there was a better way.
    Some of the new monitors coming out have great calibration tools built in - can't wait to try those.
  7. #6
    Join Date
    Oct 2009
    Ottawa, Ontario
    Posts
    274
    My Gallery
    (0)
    Liked
    0 times
    The problem is that colour on laptop screens varies more than regular monitors. Try picking up a decent external monitor for your laptop and edit with that. Unless your spending thousands on a laptop, the screen isn't going to be all that great for editing.
    I use a spyder3 and my prints always come out matching the monitor. I'm using an hp 24" (they do make smaller monitors as well).
  8. #7
    TPF Junkie!
    Join Date
    Jun 2008
    Arizona
    Posts
    9,893
    My Gallery
    (3)
    Liked
    6 times
    Quote Originally Posted by bhphotography View Post
    I have an expensive laptop with a WUXGA+ monitor. Even after calibrating with a Spyder 3, it still is lousy for editing (so I bought a Dell 2209WA IPS monitor which I calibrate with the Spyder 3).
    Ian
    Canon 7D, Canon 30D, Sigma 10-20 f/4.5-5.6, Tamron 17-50 f/2.8, Canon 50 f/1.8 Mark I, Sigma 50-150 f/2.8, Canon 100 f/2.8 Macro, Sigma 100-300 f/4, Canon 400 f/5.6L, Sigma 1.4X & 2X EX TC, Canon 430EX, Bogen 3021 Tripod/Gitzo 1377M
    MY BETTERPHOTO
    MY SMUGMUG
    "If I have seen further , it is by standing on ye shoulders of giants." -- Sir Isaac Newton in a letter to Robert Hooke 15 February 1676 (... and a long telephoto doesn't hurt either ...)
  9. #8
    TPF Junkie!
    Join Date
    Oct 2003
    Brisbane, Australia
    Posts
    9,072
    My Gallery
    (0)
    Liked
    76 times
    Quote Originally Posted by kkamin View Post
    Soft proofing makes one device look like another. And there's no reason for the above. Why make your monitor profile look like your monitor profile? That's what is being displayed anyway. The only time this is ever useful is if you are using an image with a wide gamut and you want to know what it is that you can't see on your screen. So softproof to the screen and turn on out of gamut warning indicator.
    Do you have a wide gamut monitor by any chance? As I mentioned earlier the website software isn't colour managed either. You would see a similar difference between an image loaded by your webbrowser (not necessarily the gallery), as you would have between photoshop and preview before you assigned the profiles correctly.
    Firefox 3 and later supports ICC output profiles. The options are set in about:config and are fairly involved so a quick google would help set that up.
  10. #9
    Join Date
    Dec 2009
    Boise Idaho
    Posts
    350
    My Gallery
    (30)
    Liked
    0 times
    OH GOD! This thread reminds me of all the hassles I went through with this same question. I finally tossed all the fancy equipment in the closet and bought an expensive monitor and just use it as is out of the box.
    I feel for you...good luck getting it all figured out!
  11. #10
    Join Date
    Dec 2008
    Posts
    9
    My Gallery
    (0)
    Liked
    0 times
    Yep
    I've been there like many of the contributions - laptops and laptop screens struggle with calibration tools - I ended up buying a 24" Dell CRT monitor which calibrated perfectly. I now run a 24" Dell LCD screen alongside the 24" CRT and still use the CRT for all colour critical RAW adjustment & processing. You have to spend a great deal on an LCD monitor before it will match even the most humble of CRT's.
    Adam
    Commercial Photography - Portfolio - Adam Coupe Photography
  12. #11
    Join Date
    Aug 2009
    Minneapolis
    Posts
    504
    My Gallery
    (8)
    Liked
    12 times
    Quote Originally Posted by Shockey View Post
    But I would think you would still need to do the routine calibrations on the monitor, it would still be susceptible to drifting and losing brightness.
    member of ASMP
    photography blog
  13. #12
    Join Date
    Aug 2009
    Minneapolis
    Posts
    504
    My Gallery
    (8)
    Liked
    12 times
    Well, when I'm in Photoshop, my image is sitting in an sRGB color space (and goes through my monitor's calibrated profile to appear on screen), so when I softproof in Monitor RGB there is a big shift. Is Monitor RGB a 'safe' way to see how images will be viewed online? My fear is if I adjust to the Monitor RGB softproof, the people who can view sRGB accurately in their browsers will see something disgusting.
    Thanks for your time, Garbz. Always illuminating!
    member of ASMP
    photography blog
  14. #13
    TPF Junkie!
    Join Date
    Oct 2003
    Brisbane, Australia
    Posts
    9,072
    My Gallery
    (0)
    Liked
    76 times
    No. The large majority of the people in the world have sRGB monitors. Those that don't won't see your images right on the internet unless they have screwed around with their browsers and know what they are doing anyway.
    Here's the kicker. You can't magically go from a small colour space to a larger one, you can only mis-match the colour space. What I mean by that is if the working space of your file is sRGB and you have a wide gamut screen that we'll just call MonitorRGB, what photoshop will do is insure that the sRGB image appears correctly on your screen. Here's a quick example from my screen:
    We have an sRGB file with the follow pink value: sRGB(255,64,128). This file when displayed on the internet looks a somewhat standard pink. However if I just pump this value directly to my screen by disabling colour management it looks like a very very hot pink that makes me feel very uneasy to wards my fellow man. However with colour management enabled photoshop despite actually telling me that the value is sRGB(255,64,128) will display on my screen monitorRGB(221,47,129) to compensate for the fact that my screen displays far richer reds and greens than the standard sRGB colourspace.
    However this is just the data that is sent to my video card. This should all happen magically in the background and I am completely oblivious to it. Infact the first indication that windows screwed up and I lose my colour profile (which happened yesterday I might add) is that I open an image and it just doesn't look right for some unknown reason. The only way to really check this is to look what MonitorRGB has written after it in the colour settings.
    Photoshop will internally translate all colours like this, and it can be thought of as a permanent soft proof to the working profile, however it doesn't change the fact that the file I am editing is sRGB(255,64,128). Assuming your monitor profile is correct, the onus is now on the receiver of the file to make sure their equipment is up to it. In the case of the vast majority of the internet, well their screens display sRGB anyway. In the case of a printing company it's their job to ensure they correctly convert sRGB to whatever printer profile they are using, since CMYK colours will never match the sRGB gamut. In the case of printing yourself, your print driver should take care of this unless you override it.
    So in summary: There is no reason you should ever touch MonitorRGB in photoshop other than to check to see if the display profile is loaded correctly from windows colour management settings. And maybe to paste a screenshot from windows, but that's just windows being retarded
    If your monitor profile is correct, and your image working space is sRGB, with no soft-proofing, then you are ensuring that what you see is the safe way to see how images will be viewed online.
Sponsors
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Similar Threads
  1. color mixing confusions
    By kkamin in forum Beyond the Basics
    Last Post: 04-15-2010, 08:19 AM
  2. Color Calibration
    By GwagDesigns in forum Beyond the Basics
    Last Post: 02-27-2008, 11:40 AM
  3. Color Calibration
    By WDodd in forum Digital Discussion & Q&A
    Last Post: 09-27-2007, 12:28 PM
  4. color calibration
    By carolwrite in forum Digital Discussion & Q&A
    Last Post: 09-21-2007, 02:00 AM
  5. Color Calibration with film.
    By DeadEye in forum Film Discussion and Q & A
    Last Post: 07-17-2007, 02:10 PM
2209wa calibration spyder3 pro
color cast after calibration
huey pro green cast imac
huey pro green tint
huey pro pink cast
huey pro pink tint
i1 display 2 green hue
imac green cast
imac monitor pink after calibrating
laptop calibrated pink hue
monitor calibration gives green cast
monitor has pink tint afyer calibrating
pantone huey warm profile pink color
pantone+huey+green+color+cast problem
pink cast to monitor
pink tinge monitor calibration huey pro
spyder 3 elite green tint
spyder3elite green hue
whcc soft proofing pse
whcc spyder 3
