+ Reply to Thread
Results 1 to 10 of 10
  1. #1
    Join Date
    May 2007
    Posts
    633
    My Gallery
    (0)
    My Photos Are NOT OK to Edit
    Liked
    0 times
    Questions about setting white balance in LR2
    When setting quite balance in LR, is the 'as shot' option considered pretty accurate? Do most of you just leave it at that?
    Also, when using the dropper tool, I know you should select a white/gray area, but this give varying results. Is there a way to set the WB with the dropper tool utilizing the RBG percentages near the bottom of the dropper window? Should you aim for them to be as close together as possible, and would that necessarily indicate a correct WB?
    Thanks,
    Jon
    Nikon D80
    Nikkor 18-70mm f/3.5 - 4.5
    Nikkor 50mm f/1.8
    Sigma 10-20mm f/4 - 5.6
    Nikon SB-600 Speedlight
    Nikon SB-80 Speedlight x 3
    Lens cap
    One time, this guy handed me a picture of him, he said, "Here's a picture of me when I was younger." Dude, every picture is of you when you were younger.
    - Mitch Hedberg
  2. # ADS
  3. #2
    TPF Junkie!
    Join Date
    Jul 2009
    Austin/Houston, TX
    Posts
    1,275
    My Gallery
    (0)
    My Photos Are OK to Edit
    Liked
    1 times
    Personally, I leave LR in "as shot" and my camera set to Auto-WB. If a shot needs the WB adjusted, I adjust it in LR (either auto, one of the presets or manually with the slider/value). I should note that I shoot in RAW.
    -Kevin
  4. #3
    TPF Junkie!
    Join Date
    Oct 2003
    Brisbane, Australia
    Posts
    9,238
    My Gallery
    (0)
    Liked
    107 times
    Accurate to what?
    Accurate to the camera's guess of what white balance should be? Because it really is just that.
    How about accurate to the camera's setting of "Daylight"? Do you know the lighting on your subject is exactly 5500k? It may well be outside with no trees on a clear blue sky in the middle of the day, but that's a stretch.
    If you're asking if it is at all accurate to whatever the camera recorded white balance is then the answer is no. RAW files are reverse engineered thanks to no open spec being utilised by the main companies. During this process there is usually some form of calibration done, but there's always a slight difference between the camera settings and the Lightroom rendering of the image. If you need this to be accurate (and I can't think of why you would) then you would want to use CaptureNX to convert Nikon RAW files.
    But really the solution to the problem has been known for a long time. This is exactly what grey cards are for. They may be a bit expensive for what amounts to ... a coloured card (or more accurately an uncoloured card), but this is the way to indicate the correct white balance. Hold your grey card to the subject, take a picture, then remove and take another picture. Use the dropper tool on the grey card, then do a happy dance.
    "I am always satisfied with the best." -Oscar Wilde
    Larger versions always on flickr
    Best photos in my gallery
    Proud Supporter of The Pact
  5. #4
    TPF Junkie!
    Join Date
    Jul 2009
    NYC
    Posts
    2,554
    My Gallery
    (0)
    Liked
    29 times
    Generally,
    My WB is set to daylight or 5560K. In LR if from JPG, I might adjust it here/there, in RAWs, just put in the values - IF needs be.
  6. #5
    I am Big, I am Mike Site Moderator
    TPF Supporter
    Join Date
    Dec 2003
    Edmonton
    Posts
    30,306
    My Gallery
    (111)
    Liked
    802 times
    Yes, I think so.
    The camera makes everyone a tourist in other people's reality, and eventually in one's own. - Susan Sontag
    Edmonton Wedding Photographer ==>Blog
    Instructor at The Canadian Photography Learning Centre.
  7. #6
    Join Date
    May 2007
    Posts
    633
    My Gallery
    (0)
    Liked
    0 times
    Would it be OK if I skip the dance step, or is that highly recommended?
    Yes, I think so.
    Anyone else have a thought on this? Should I be satisfied if the three numbers are nearly identical, regardless of what the numbers actually are?
    Jon
    Nikon D80
    Nikkor 50mm f/1.8
    Lens cap
    - Mitch Hedberg
  8. #7
    TPF Junkie!
    Join Date
    Oct 2007
    Greenville, Texas
    Posts
    11,741
    My Gallery
    (4)
    Liked
    567 times
    Quote Originally Posted by Jon_Are View Post
    As shot is just that - the way it came out of the camera.
    Even on a grey card or a WhiBal, they're not usually going to be identical (damn close though). If for whatever reason, I didn't take a WhiBal shot and I have to fix the WB later - I use the dropper on something neutral. Neutral does not necessarily mean white (many people assume that you have to use something white to white balance...).
    I try to pick a spot where the RGB values are relatively close - within a few points of each other.
    A WhiBal is hard to beat though...
    What the numbers say shouldn't be a factor in your satisfaction - base that on what the photo looks like.
    "Right" isn't always right.
    -Josh
    Flickr
  9. #8
    It's all about - Light Site Moderator
    TPF Supporter
    Join Date
    Apr 2009
    Iowa
    Posts
    22,032
    My Gallery
    (1)
    Liked
    1736 times
    For finding neutral gray in an image:
    • Open the image in the photoshop workspace.
    • Click on the 'Create a New Layer' icon at the bottom of the Layers panel to create a new blank layer.
    • Go into the Edit menu and click on 'Fill'.
    • In the Fill dialog box's 'Content' section click on the down arrow button and select 50% gray
    • Make sure the 'Preserve Transparency' box is not checked and click ok.
    • Layer 1 is now filled with 50% gray
    • Make sure layer 1 is selected (highlighted)
    • Change the Layer pallette blending mode to 'difference'.
    • Click on the 'Create new fill or adjustment icon at the bottom of the Layers panel.
    • In the pop-up select 'threshold'.
    • You're now looking at a totally black image.
    • In the Threshold adjustment panel move the slider under the histogram panel all the way to the left
    • Now your image is most or completely white.
    • Any areas that are not white are neutral gray.
    • If it's all white move the slider back to the left slowly until some areas begin to show. Those are also neutral gray.
    • Note where at least one of those areas are in the image. I usually just use my finger and turn off Layer 1 and the Threshold layer.
    It sounds like a drawn out process, but after you've done it a couple of times it just takes a few seconds to do and you now know where to sample for white balance and neutral gray for color corrections.
    This method was developed by Dave Cross, one of the experts at the National Association of Photoshop Professionals (NAPP). Consider becoming a member. It's well worth the $99 a year membership. There is a referral link in my siggy.
    . . . . . . Keith . . . . . . .How Do I Use My Digital SLR?...
    "Even the easy things are tough, if you do them half-heartedly"
    FOR SALE : Stay Tuned!
  10. #9
    TPF Supporter
    Join Date
    Apr 2009
    Iowa
    Posts
    22,032
    My Gallery
    (1)
    Liked
    1736 times
    • Make sure Layer 1 is selected (highlighted)
    • If it's all white move the slider back to the left slowly till some areas begin to show. Those are also neutral gray.
  11. #10
    TPF Junkie!
    Join Date
    Oct 2003
    Brisbane, Australia
    Posts
    9,238
    My Gallery
    (0)
    Liked
    107 times
    Wait how does this work? This assumes the image is already grey doesn't it? You wouldn't need to white balance after the fact in that case, or am I missing something?
Sponsors
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Similar Threads
  1. White Balance Questions
    By ilovemy50d in forum Beyond the Basics
    Last Post: 04-12-2010, 12:02 AM
  2. Setting White balance
    By UUilliam in forum Beyond the Basics
    Last Post: 07-20-2009, 09:28 AM
  3. Setting white balance correctly for weddings and portraits
    By NJMAN in forum The Professional Gallery
    Last Post: 05-16-2007, 09:15 AM
  4. 18% grey or white card for white balance setting
    By shingfan in forum Photography Beginners' Forum
    Last Post: 01-26-2007, 02:51 PM
  5. Lighting and white balance questions (Panny FZ5)
    By damian5000 in forum Beyond the Basics
    Last Post: 09-14-2005, 08:16 AM
dave cross and white balance
dave cross correct white balance
dave cross white balance
lr2 white balance
selecting white balance on lr2
white balance in lr
