Results 1 to 6 of 6
  1. #1
    Join Date
    Nov 2009
    USA
    Posts
    598
    My Gallery
    (0)
    My Photos Are NOT OK to Edit
    Liked
    1 times
    Question Manual Power on my Flash
    How do I control the power output on my SB600 when I'm shooting in commander mode using Nikon's CLS??
    It doesn't seem to give me the option when I shoot in that mode.
    Last edited by burnws6; 11-30-2009 at 05:15 PM. Reason: Besides using my camera. I want to know if there's just a way to manually select it on the flash without going to the camera.
  2. # ADS
    Ads
    Google Advertisement
    Join Date
    Always
    Advertising world
    Posts
    Many
  3. #2
    KmH
    KmH is offline
    Helping photographers learn to fish
    TPF Supporter
    Join Date
    Apr 2009
    Iowa
    Posts
    28,727
    My Gallery
    (1)
    My Photos Are OK to Edit
    Liked
    2795 times
    Put your SB-600 into remote mode:
    • Power up the Speedlight.
    • At the same time press ZOOM and the - button for 2 seconds or more.
    • Press the + button till you see the sharp curve symbol with the arrow head on the bottom and pointing right (#2 on pg. 14 of the manual).
    • Press the MODE button till you see ON.
    • Press the ON/OFF button.
    • Press the MODE button to navigate to CHANNEL
    • Press + or - to select the same channel you have set in the Commander mode of the camera. If the SB-600 is the only speedlight you're wanting to control, use Channel 1, group A.
    • Press the MODE button to navigate to GROUP.
    • Press the + or - button to select the GROUP the cameras Commander is set to.
    • Make sure the light sensor window for wireless remote flash on the SB-600 is visible from the camera position.
    • Make the Image.
    Have another look at your SB-600 users manuals "Advanced Operations" section beginning on page 58.
    There are several books available that describe the Nikon Creative Lighting System in a more palatable way than the manual does. Look for the one written by Mike Hagen. It's pretty good.
  4. #3
    TPF Junkie!
    Join Date
    Jul 2009
    NYC
    Posts
    2,649
    My Gallery
    (0)
    Liked
    43 times
    • Make the Image.
    FURTHERMORE,
    In the camera - flash settings, you'll have an option to set of your sb600 in TTL, A and M modes. If you aren't familiar with Manual controls, keep it in ttl or auto.
  5. #4
    Join Date
    Nov 2009
    USA
    Posts
    598
    My Gallery
    (0)
    Liked
    1 times
    Quote Originally Posted by KmH View Post
    • Make the Image.
    Quote Originally Posted by IgsEMT View Post
    • Make the Image.
    FURTHERMORE,
    Yes, lol, I know this. I guess I didn't explain myself enough. Once I do the before mentioned, I then have to select at what power my flash is going to fire off at. I can do that in commander mode, and decide if I want it at full, 1/4 ; 1/8 and so on.... but is there a way to do it on the flash itself.
    Just like when you're using your pocket wizards and you can set the power manually on the flash itself. I'm trying to figure out if its just a feature the sb600 doesn't have, or if it's the commander mode itself that doesn't allow it to be changed except from the camera.
    Thanks for the post though anyways guys.
  6. #5
    TPF Junkie!
    Join Date
    Jul 2009
    NYC
    Posts
    2,649
    My Gallery
    (0)
    Liked
    43 times
    when in CLS, you can't select on-flash the amount of power coming out. you can only adjust the zoom of the flash.
    What I like about M is that it eats less juice but then it would be ideal for subject NOT moving around much. Othertimes, I just TTL or A the flashes and add/subtract compensation.
  7. #6
    Join Date
    Nov 2009
    USA
    Posts
    598
    My Gallery
    (0)
    Liked
    1 times
    There we go, that's what I wanted to know. Thanks man.
Ads
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Similar Threads
  1. Flash batteries and other power options
    By Overread in forum Photography Equipment & Products
    Last Post: 01-09-2009, 05:18 PM
  2. DIY mod to Nikon SD-8a for more flash power
    By jstuedle in forum Photography Equipment & Products
    Last Post: 10-21-2008, 10:36 AM
  3. Options for flash power?
    By William Petruzzo in forum Photography Equipment & Products
    Last Post: 09-29-2008, 04:58 AM
  4. flash and power winder
    By wil in forum Buy and Sell
    Last Post: 11-10-2005, 08:28 PM
  5. How To: Fill flash with a manual off camera flash
    By GerryDavid in forum Beyond the Basics
    Last Post: 10-11-2004, 08:36 PM
adjusting power output on sb600
how do i use my flash in manual
how to adjust power on sb600
how to set flash power manually
how to set flashes on manual
how to set the right manual flash power
sb600 diy power mod
using my flash in manual
