"Better" Lenses (for Nikon)
Gang,
I've just sent my Nikon 18-200mm VR lense in for (under extended warranty) repair and am considering alternative lenses.
I keep returning to my hi-fi experiences where more money really does result in better equipment and after 6 years of (digital) SLR photography, I'm at a point where I'd like to consider buying better lenses.
That 18-200mm VR has proven to be extremely versatile and effectively the only lense I use, so much so that I keep it mounted at all times.
After initiatiing the repair, I immediately asked about other lenses. There's a very hefty 18-55mm VR 2.8 lense (that's about >double< the price of the 18-200mm; $1600?) that looks very promising in terms of construction and focusing speed but I don't know that I'm ready for that, especially since I'd lose so much distance. (I tend to rely on the telephoto ability and have few opportunities for portraits.)
My question is really this: Are other brands better than Nikon? For example, I thought Tamron was a "better" brand? Am I mistaken?? I only cite Tamron for the 18-270mm lense they offer, however, I've seen some unfavorable reviews of it.
Is it really simply time to make the "hyperleap" and accept the reality of the "over $1000" realm of lenses?
I appreciate that there could be several orders of magnitude of improvement in a lense, however, the cost would be equivalent. My own rule of thumb is more along the lines of a 20% cost difference that results in a >noticable< improvement. Again, using the hi-fi analogy, the difference between a $500 and $5000 component should be dramatic but the "entry level" component from that same $5000 manufacturer should distinguish itself from the $500 "top of the line" offering for an incremental cost.
Thanks in advance.
12-01-2009 05:34 AM
# ADS
Consider third party lenses. Tamron and Sigma make lots of options that would provide you a step up from the 18-200, while still keeping the budget low. The quality of most modern sigma/tamron lenses is very high.
I am Big, I am Mike
Site Moderator
You can't really compare too many lenses strictly by brand name. Nikon has plenty of great lenses...but they also have some terrible lenses as well. Same thing with Canon, Sigma, Tamron etc. You really have to compare them on a lens by lens basis.
When it comes to top end, professional level lenses...the Nikons are very good. Very likely better than a similar top end lens from Sigma or Tamron. The issue is that a top end Nikon lens is going to be twice the price of a similar top end Sigma/Tamron. As an example, I like to say that the top end Nikon (or Canon) is maybe 10% better than the top end Sigma/Tamron. So is it really worth that extra 10% in quality for double the price? To some people it is, to some people it isn't.
I would think that the hi-fi analogy fits here too.
Another thing to consider, is that top end lenses are rarely more than 3x zoom lenses. For example, some of the best Nikon lenses are the 17-55mm F2.8, the 24-70m F2.8 and the 70-200mm F2.8.
Sure, the 18-200mm lens is convenient, but to design a lens like that, there are compromises made to the image quality. So you really need to decide which is more important to you....convenience or quality.
Originally Posted by
Big Mike
Michael
I used to own 18-200 3.5-6.3 Tamron. The great thing about that lens was the focal length and outdoors it performed VERY well. I didn't mind much images being a bit soft either. But the moment I was indoors, it used to take longer for it to focus, the softness was more pronounced and overall it was just not of the best quality I could have pulled from the camera. I heard of some promising results from new Sigma 18-250 but can't say anything personal about it. I googled this interesting page, didn't read it though Juza Nature Photography comparison b/n these big guns
My primary glass now is nikon 28-105 3.5-4.5. It is an older model but its optics are amongst best of Nikon (and yes, I am subjective here
) I'd recommend looking into used/older lenses.
that obviously depends on you & your budget. Number of hobbyists-friends of mine, walk around with 3 primes and 3zooms. Personally, I don't have the budget to upgrade to a $2000 2.8 lens nor do I need to - it isn't the lens or the camera that makes an image spectacular, it is the person behind the (used to be film) LCD screen
Also a better high end lens will hold value better and can be sold easy for a good price down the road if you feel you don't need it anymore.
The hi-fi analogy isn't quite applicable, since that is a field filled with bogus claims, and otherworldly prices for rather mundane, interchangeable components that are not much better than generic, but which people willingly play thousands of dollars for; things like $5,000 gold-plated connectors on speaker cables, and so on. Mike Johnston, a former hi-fi junkie writes the daily blog The Online Photographer and just celebrated the blog's fourth anniversary--he frequently uses his longtime audiophile experiences as examples, mostly of an industry with a corrupt industry press comprised of a mere handful of reviewers who get expensive speakers and systems "on-loan" [basically at sub-market, bribe-like prices] and where the entire industry press does little more than condition customers to be ravaged by over-priced manufacturers. So, as Johnston so often writes about, the similarities to hi-fi and photographic industry offerings are not applicable.
What you'll find if you buy a higher-end lens is that instead of minute, almost imperceptible differences that you have to tell yourself you think you hear, you will get measurable, large, substantial differences in optical performance once you get into the higher-end lenses from Nikon. Sigma makes only a few lenses that are "tops" in their field--very few lenses. Here is a list of the top 16 most-frequently repaired lenses; Sigma has 7 of the 16 most-frequently repaired lenses. And the top four, meaning the worst four as far as reliability, has one Sigma lens that costs over $2,300.
LensRentals.com - Lens Repair Data 2.0
If you're happy with the 18-200 VR, you could probably keep using it after it comes back from repair. It is, or was likely when you bought it, the "top of the heap" as far as superzoom lenses go--it was not a cheapie, but an expensive, top-line superzoom. But it's also kind of like a mini office stereo system--it does not have any one single area where is is even remotely near the "top" in performance. To get the top quality performance of $5,000 hi-fi components, you'll probably find yourself spending $1,000 on photographic equipment, or more. If you want to move into high-performance lenses, you'll have to settle for more task-appropriate lenses, rather than an 18-200, so the 17-55 f/2.8 VR DX-Nikkor would cover the short to middle focal length ranges, and then from 55 on up, you'd need another lens, like a 70-200 VR. If you want good-performing lenses in zooms, Sigma and Tamron have some good-performing zoom lenses in affordable price ranges, but they also have shall we say, the reputation of Pioneer, not Harmon-Kardon. And they are priced for what they offer....80 to 90 percent of the performance of the camera-brand products in most cases.
In prime lenses, Sigma and Tamron make better quality offerings which are of extremely good optical performance--their macro lenses specifically, are excellent optical performers.
What Lens Rental's chart could also prove is that more people rent those lenses more often so they tend to get beaten around more and those lenses are also large telephotos which are heavier and could also be beaten around in shipping.
It's not a very accurate chart to use to gauge quality unless they have a chart showing how often those lenses repaired are rented. Plus it's only data from one company. Borrow Lenses could have a chart that looks completely opposite to that.
Village Idiot
The fact remains--Sigma is the most-repaired lens brand that they carry. And, counter to your comment that it might be that the large lenses get "beaten around in shipping", Lensrentals SPECIFICALLY states :
"Just because we get asked it a lot, I’ll add that the Supertelephoto primes (300 f2.8, 400 f2.8, 500f4, 600 f4 from both Canon and Nikon) are our lowest repair rate lenses. Basically we’ve only had damage repairs for any of them."
Hmmm....so Nikon and Canon supertelephotos, all larger, all bigger than the top-four Siggys, are their "lowest repair rate lenses." Kind of shoots down the theory you've put forth
I've been involved with 35mm lenses since the early 1980's,and Sigma has earned its reputation. Did you see that neat-o post from a while back where the fellow's 70-200 Sigma just snapped at the lens mounting ring? No offense to Sigma, but their lens-building reputation is known far and wide as an "affordable" brand, not as a mission-critical brand. For light-duty use, and for bang-for-buck, Sigma offers good value. And yet, out of the lenses listed above, Sigma has 7 of the 16 most-repaired lenses...
Just curious, but I'd imagine a lot more Sigma's are sold and rented due to their reduced cost. Could this factor in on the numbers?
I've had wonderful experiences with all my Sigmas.
We're lucky to have chosen such a wonderful hobby/profession, aren't we? If you question this, just remember why you have a camera in the first place.
May the magic of your first photographs spark your desire and encourage you to have fun again.
Nikon D300s + MB-D10 Grip
Nikkor 70-200mm f/2.8 VR II
Nikkor 50mm f/1.4
Nikkor 18-105 f/3.5-5.6 VR
Nikon SB-900
Nikon 1.7x Teleconverter
Sigma 70-300mm f/4-5.6 DG APO Macro
Manfrotto 190XPROB & Manfrotto 322RC2 Head
Kata Sensitivity V Bag
Wish List: AF-S VR Zoom-Nikkor 200-400mm f/4G IF-ED, AF-S NIKKOR 600mm f/4G ED VR
After spending the last couple of weeks on Ebay shopping for a couple lenses I found:
Nikon lenses hold their value and in some cases increase in value. <--One of the only items I can think of that you can use for 1-30 years and then sell it for around what you paid!
Sigma, while I can't recall seeing broken ones for sale it seems that more than a few people are selling them to get Nikons.
My two cents
Nikon D90, Nikon 70-200mm 2.8, Nikon 35-70 2.8, Nikon 50mm 1.8, Tokina 80-200 4.0-22(FOR SALE), Nikon 70-300 4.5-5.6 VR (kit)+(FOR SALE $450), Nikon 18-105 3.5-5.6(kit), . Sony A350 back-up camera, Iphone <--yeah I use it from time to time for pictures.
CWN
I think you've hit upon the issue: Sigma lenses cost less, and are designed and manufactured so that they will "cost less".
Like this two and a half month old 70-200 lens: http://www.thephotoforum.com/forum/p...e-what-do.html
All one needs to do is go to a large forum, like Fred Miranda dot com and look in the lens review section about any one particular lens, from any manufacturers-Canon,Nikon,Sigma, and the experiences of dozens and dozens of individual owners will give an astute reader a clear picture of each specific lens and its actual track record. Like the Canon 10-22 EF-S, which suffers from barrel separation at a rate of 15.8% according to the Lensrentals.com people; not too long ago a forum member here told me how that specific Canon lens ought to be considered "L-glass" quality. But then, a week later or so, he told me in PM that his lens had broken in two--aka barrel separation.
This thread's original premise was about "better lenses" for Nikon,and the perception that some third-party lenses were better lenses than the original manufacturer's lenses. As Big Mike said, going on a lens-by-lens basis is the best way to judge a lens; my comment is that the Fred Miranda forum, and the experience of the Lensrentals folks is that a LARGE cross-section of actual, real-world use will show that the camera manufacturers tend to make very good lenses, and that there are many examples where the 3rd-party lenses offer 80 to 90 percent of the optical/mechanical performance of the camera maker lenses at significantly lower initial prices. The weaker lens designs tend to have repair/calibration/breakage issues. Comparing the reviews of say the Sigma 70-200 and the Tamron 70-200 at dPreview, for example, you'll see that EACH of those two lenses has areas where the performance is seriously behind the Canon and Nikon 70-200 2.8 lenses.
Each user can draw his/her own value assessment about lenses the OP was asking about; the "hyper leap" as he put it, to lenses costing over $1,000.
The original poster seemed to be questioning the value/cost proposition of $1,000-plus lenses; again, looking a large sample sizes like at Fred Miranda's lens forum, one can see how various lenses stack up. Who expects that an $800 Sigma will perform or be built as well as an $1800 Nikon 70-200 with VR?
I have a couple of Sigma lenses: one is an 18-125mm DC,allegedly optimized for crop-frame Canon. I have a Canon 24-105-L, for full-frame.
And you know what? The Sigma zoom slides from 125 back to 18mm as soon as the camera is pointed down. It is light,small, and plasticky,and wobbly. The Canon L is solid, large, heavy, and a significantly better lens. One cost $169 or thereabouts, the other was about $900. I know which one cost more. I know which one is optically and mechanically and functionally better too. BUT, as per Big Mike's lens-by-lens basis: Sigma's 50mm f/1.4 EX is actually a slightly better optical performer than Canon's $1800 50mm f/1.2 L--higher resolution on the Sigma, better corner performance on the Sigma, and lower levels of chromatic aberration on the Sigma. For something like $1,000 less money. Yet, still, it's an "expensive" Sigma...and well worth the money! As Big Mike said, lens-by-lens. And as I said, Sigma's prime lenses can be very,very good! Sigma macro lenses are awesome.
Village Idiot
Lens rentals chart is still a hell of a lot better than anecdotal remarks in a photography forum.
I'm not on my personal system, but if I remember to I'll post some corroborating info from a different source tomorrow.
I just have to ask... why would you buy a 1600+ camera (D300s, D3x, D700, etc) and then put a third party (inexpensive...cheap) lens on it? It would acutally be smarter to buy a cheaper camera and spend the extra on the lenses. The Glass is where it's at....!!!
Which brings me to another issue... If you purchase Awesome lenses and then put a cheap "sky" filter on the end...what's the point. Anyway.... If you are thinking of doing this proffessionally save your money and go for the brand to brand match. Always get the best glass you can afford. However, if money is a huge factor (it is for me) then get what you can afford and spend more time in the field learning to take better photographs... Maybe, you could sell those images to get better lenses...
Be prepared...the lens envy never stops...ever...
