Question for the istD folks
i've recently noticed that my istD gives really odd photo sizes. i'm starting to wonder if its something in my camera settings or if then sensor is an odd and this is something i'm going to have to just deal with. It sort of feels like i've turned on a panoramic setting or something. The measurements for my photos are about 6x10 instead of 8x10. Has anyone else had this problem and/or know how to fix it.
Canon 1D Mk II
Canon 24-70 f2.8L
Canon 70-200 f2.8L IS
04-16-2005 10:56 PM
# ADS
6x10 is about the right size, that format is based on the 35mm film formatting of 24mm x 36mm,
do the math 24/36 = 6.66/10
So yes my 10d does this too, but it is not a problem
If you're shooting RAW did you change the dpi setting in ACR? That would do it. And the normal print size for a Pentax file at the default 240 dpi at the highest resolution is 8x12 which is 3:2, or as Jeff stated 6.66x10.
Also it could be your editing software, different one may size the same file differently. I have both Corel and Photoshop, a file opened with Corel will be 28x42 @ 72dpi and with PS is 11.33 x 17 @ 2?? Dpi
I don't think i've done this, but could explain what you're talkign about because i'm not familiar with it
Canon 1D Mk II
Canon 24-70 f2.8L
In Adobe Camera RAW when you open a RAW file there's a section at the bottom of the screen where you can change the resolution (dpi) and size settings.
Changing either will change the output size of the pic.
Or... if you changed the size in Image|Image Size that would do it as well.
All that assumes you didn't change the size settings in the camera itself...
