Results 1 to 10 of 10
  1. #1
    TPF Junkie!
    Join Date
    Aug 2009
    Arkansas
    Posts
    1,856
    My Gallery
    (0)
    My Photos Are OK to Edit
    Liked
    48 times
    Explain this to me about cropping and dpi...
    My photo lab has this printed on their website. I don't understand the reasoning for leaving the dpi blank. I just always put in 300.
    Oh Crop... So your camera files are a 4x6 format (or you could say 6x9 or 8x12) and you need an 8x10? Well, you either squish that file by changing the dimensions of it to 8x10, and yes this will make your picture look really distorted and funny looking, or you decide what part of the file you are willing to part with and set the crop because obviously, somethingís gotta give. If you crop in Photoshop instead of the ordering software, always, always, always, leave the resolution blank. Donít put 250, or 300, or 600. That will just make the file bigger (not better) and will compromise quality and waste your time. Not cropping at all means that you are confident that our automatic "center" cropping will work for the print size(s) you want.
  2. #2
    I am Big, I am Mike Site Moderator
    TPF Supporter
    Join Date
    Dec 2003
    Edmonton
    Posts
    33,468
    My Gallery
    (111)
    My Photos Are NOT OK to Edit
    Liked
    1672 times
    They are talking about the PPI, not DPI....and the PPI doesn't matter. As long as the file has a sufficient number of pixels, the print should be OK.
  3. #3
    TPF Junkie!
    Join Date
    Oct 2003
    Brisbane, Australia
    Posts
    9,712
    My Gallery
    (0)
    Liked
    204 times
    The above is half good advice. But the radius of the halo depends entirely on the image size being printed and the resolution of the original. If you create a 1px halo on a 16mpx image that is printed at 6x4 it wouldn't be visible at all. That said if you create a 1px halo on a 5mpx image printed 30x20 then it would look ugly as sin.
    This is why it's important to get proofs at the original crop size.
    Anyway back to the OP. When you print something the PPI (not DPI as incorrectly used by a lot of people) along with the resolution determines the print size. This is how some printing companies do things. Others will take the opposite approach. They will take any resolution and you tell them what size you wanted it printed and they'll work out the PPI for you.
    "I am always satisfied with the best." -Oscar Wilde
    Larger versions always on flickr
    Best photos in my gallery
    Proud Supporter of The Pact
  4. #4
    TPF Junkie!
    Join Date
    Oct 2003
    Brisbane, Australia
    Posts
    9,712
    My Gallery
    (0)
    Liked
    204 times
    I know how it works, I was just saying it needs to be tailored to suit the image. I'm not sure about others here but I find I rarely dictate my print sizes by DPI, rather I dictate the PPI by print size.
    You take two images with different resolutions (result of cropping or whatever) unless you resize them to a common standard PPI value every time you need to go in and adjust the sharpening method. I think most people here will let the resultion define their PPI value and i.e. print a 6x4 uncropped at 648PPI and a cropped image at 6x4 at maybe 320PPI or something non-uniform. I don't know anyone who goes and resizes all their images for a constant PPI value when they print, actually from what I've seen of discussions there's a consensus that resizing shouldn't be done unless you need to upscale to meet a minimum PPI value.
    Not saying your sharpening is a bad thing or not needed, quite the opposite, I fully agree it's a great idea. Just that you shouldn't always zoom in and make the halo 1-2px since a pixel on the image changes on the print based on your PPI.
  5. #5
    TPF Junkie!
    Join Date
    Mar 2009
    Key West FL
    Posts
    1,261
    My Gallery
    (11)
    Liked
    0 times
    Quote Originally Posted by Garbz View Post
    ...Just that you shouldn't always zoom in and make the halo 1-2px since a pixel on the image changes on the print based on your PPI.
    It doesn't when you use the work flow Graystar describes.
    With that workflow you create a resampled image sized to the exact print size you are going to print at the optimal PPI for your printer (600ppi in his example). You then, and only then, do the final sharpening. When working that way the 1-2px sharpening halo he describes is appropriate for that print.
    This work flow requires that you save a master copy of the image before the resampling and final sharpening. This master image would then be used to create a different resized & resampled image anytime you wanted to make a different sized print or use a different printing device since the final sharpening requires that the image be resampled specifically for the desired print size and printing device before the final sharpening is done.
    Dwig
    happythursday.com
  6. #6
    TPF Junkie!
    Join Date
    Oct 2003
    Brisbane, Australia
    Posts
    9,712
    My Gallery
    (0)
    Liked
    204 times
    Yeah I get that. I was pointing out that the sharpening is important, and can be done to fit in with anyone's workflows too. Not everyone goes out and resizes all their images to exactly 600PPI.
    I'm discussing options here and not saying any one way is better than any other.
    By the way the word you're looking for is "acutance" The measure of a distinctiveness of a line. Haloing created due to sharpening improves this acutance.
    I agree that Nik Sharpener is a good tool for that job. I use it myself.
  7. #7
    TPF Junkie!
    Join Date
    Mar 2008
    Boulder, CO
    Posts
    1,106
    My Gallery
    (0)
    Liked
    18 times
    Lots of good info here for someone who is about to print a bunch of stuff for an art gallery... Keep arguing!
    Life's an adventure. Shoot it! Fullerton Images - Blog - FaceBook
  8. #8
    TPF Junkie!
    Join Date
    Apr 2009
    Dallas
    Posts
    1,173
    My Gallery
    (0)
    Liked
    35 times
    So is something that you do if you only print your own images? I ask because 99.9% of my printed photos come from Mpix. I do not have my own photo printer. So should I be looking into doing this before sending to Mipix?
  9. #9
    TPF Junkie!
    Join Date
    Oct 2003
    Brisbane, Australia
    Posts
    9,712
    My Gallery
    (0)
    Liked
    204 times
    I just too would like to add that the effect not only depends on the printer, but also on the person doing the printing.
    I had a situation like that one day when I got a proof back, gave it the OK and then received an image which looked nasty. They bumped the sharpness and contrast. When I took it back and showed them how it didn't look at all like the proof they explained the just had a new person start and he was different from the person who sent the proof (their excuse anyway, but just watch out for people fiddling with your stuff).
  10. #10
    TPF Junkie!
    Join Date
    Apr 2009
    Dallas
    Posts
    1,173
    My Gallery
    (0)
    Liked
    35 times
    Thanks Guys! So far Ive had no problems with Mpix.
Ads
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Similar Threads
  1. How do you explain cropping to customers?
    By eric-holmes in forum General Shop Talk
    Last Post: 07-21-2010, 09:30 PM
  2. Explain ISO
    By LarryMartin830 in forum Digital Discussion & Q&A
    Last Post: 03-15-2009, 10:49 PM
  3. Explain this to me...
    By LuckySo-n-So in forum Photography Beginners' Forum
    Last Post: 02-12-2009, 02:21 PM
  4. Could someone explain ISO?
    By brookie418 in forum Photography Beginners' Forum
    Last Post: 02-11-2009, 06:45 PM
  5. Please explain MF to me
    By Iron Flatline in forum Medium Format & Large Format
    Last Post: 02-26-2007, 08:18 AM
76 dpi
76dpi
cropping and dpi
cropping dpi
cropping printing and dpi
how does cropping affect dpi
what is 76 dpi
when cropping how do you save dpi
