Results 1 to 10 of 10
  1. #1
    TPF Junkie!
    Join Date
    Apr 2008
    California, USA
    Posts
    1,661
    My Gallery
    (0)
    My Photos Are OK to Edit
    Liked
    22 times
    Opinions on workflow with lightroom and photoshop.
    I do have both photoshop and lightroom and although I dont use photoshop a whole lot anymore there are sometimes I do use it with lightroom.
    I would like some suggestions or opinions on how you do your work flow when it comes to editing in lightroom and photoshop.
    All my images are in lightroom. I particularly like "levels" in photoshop, but not the sliders in lightroom, its just not the same! On occasion I open in photoshop just to adjust the levels and use other features... Of course photoshop changes are permanent. Im assuming you keep the lightroom picture, and just save the photoshop (as a tiff i think) and it auto-imports back into lightroom, so now you have two copys of the same photo, both with different edits.
    Would you save the photoshop edit til the last step, as its not reversible?
    For another example, most people do "sharpening" as a final step, if you normally do it in lightroom, do you instead do it in photoshop?
    What file do you normally save your final photos in? Tiff? jpeg?
    Canon EOS 7D
    Canon EF 70-200mm F/2.8L USM
    Canon EF 50mm F/1.4 USM
    Canon Speedlite 480EX II
    Manfrotto 293 Tripod w/ QR ballhead *NEW*
  2. # ADS
    Ads
    Google Advertisement
    Join Date
    Always
    Advertising world
    Posts
    Many
  3. #2
    TPF Junkie!
    Join Date
    Jul 2009
    NYC
    Posts
    2,649
    My Gallery
    (0)
    My Photos Are NOT OK to Edit
    Liked
    43 times
    After I do the job i import it with ACDsee renaming to yyyy-mm-dd hh-mm-ss. Since most often I shoot w/ two bodies and a lot of the time have a 2nd photographer, this allows me to load all 3-4 cameras. I use ACDsee for basic stuff - rename, resize and imports and nothing really else.
    Then I load the job into LR and go through the 1st RUN: delete the junk, rotate/crop, create virtual copy and add a filter to it... and again DELETE the junk.
    Run2 - i go through LR and scrutinize images more thoroughly. THEN I export them out and use PS on specifics that need be. On some jobs, I don't even come close to PS as LR does what I need it to do.
  4. #3
    TPF Junkie!
    Join Date
    Jul 2009
    NYC
    Posts
    2,649
    My Gallery
    (0)
    Liked
    43 times
  5. #4
    Join Date
    Sep 2010
    Carthage, NY
    Posts
    210
    My Gallery
    (0)
    Liked
    0 times
    i've been using lightroom for a long time, i do most of my adjustments in there including shapening and noise reduction i'm using version 3.0 then if it needs more i move to photoshop.. there are alot more specific adjustments in photoshop to allow you to really fine tune certain areas and colors.. i'd say lightroom is good for 90% of the work, but there are many things in photoshop you just can't do in lightroom... but i'd say they are advanced photoshop techniques.. for example.. you can dodge and burn, but then there are the variables of feathering, intensity, type of brush, ability to select only one area to work on and ignore the rest even if your hand slips... and i'm sure there are other variables that i don't use on that tool too
    if photoshop had the easy to use interface that lightroom does then i'd probably use it alot more.. maybe that's how bridge is but i've never gotten into bridge so i don't know
    Mike Leggero
    http://www.michaelleggero.com
  6. #5
    I am Big, I am Mike Site Moderator
    TPF Supporter
    Join Date
    Dec 2003
    Edmonton
    Posts
    32,045
    My Gallery
    (111)
    Liked
    1202 times
    I try to do as much as I can in LR. Saving my Photoshop edits, if any are required, to later in the workflow. I also like the levels in Photoshop, more than the sliders in LR, but with the combination of a few sliders and the tone curve, I don't really need to use Levels in PS.
    I just use the 'Edit in', from within LR and then Photoshop spits it back out to LR as a Tiff, I'm fine with that.
    I almost always use collections for my images in LR. For example, when I do a shoot, I pick out the best ones and create a new collection for them. Then I just use that collection when I go to the Develop module. (or print, web etc.). So when Photoshop gives me back the ####-edit.tiff file, I keep that one in the collection and just select the original file and remove it from the collection.
    There's no correlation between creativity and equipment ownership. None. Zilch. Nada. Actually, as the artist gets more into his thing, and as he gets more successful, his number of tools tends to go down. He knows what works for him. Expending mental energy on stuff wastes time.
    Hugh Macleod
    Edmonton Wedding Photographer ==>Blog
    Instructor at The Canadian Photography Learning Centre.
  7. #6
    TPF Junkie!
    Join Date
    Jan 2010
    Philadelphia
    Posts
    3,228
    My Gallery
    (0)
    Liked
    423 times
    Everything in PS is reversible and non-destructive if you do it using layers, typically adjustment layers for curves, levels, brightness, color mods, etc. To me, the ability to paint on adjustment layer masks to make alterations limited to specific areas of the image, and to do it reversibly, is the key feature of PS. You can save all the layers as part of a .psd file. If you need to flatten and convert the .psd to a tiff or jpeg to use in another application, you still have the .psd file to go back to.
  8. #7
    Join Date
    Jun 2008
    CA
    Posts
    275
    My Gallery
    (0)
    Liked
    0 times
    I do general edits in lightroom. If it needs more work I take it into Photoshop. I'm more familiar with Photoshop as that is what I was taught in school.
    I too like the levels in Photoshop better, plus the cloning tools etc. Also I have a lot of actions in Photoshop.
  9. #8
    Join Date
    Jan 2010
    USA
    Posts
    171
    My Gallery
    (0)
    Liked
    0 times
    ____
    Robert Grant
    LearnMyShot.com - learn how to shoot anything
  10. #9
    TPF Supporter
    Join Date
    Dec 2003
    Edmonton
    Posts
    32,045
    My Gallery
    (111)
    Liked
    1202 times
    That's true...you can have a Photoshop workflow that is 'non-destructive'...but you are saving copies and creating files that can get huge.
    Hugh Macleod
  11. #10
    TPF Junkie!
    Join Date
    Jan 2010
    Posts
    3,523
    My Gallery
    (0)
    Liked
    280 times
    I generaly import everything is lightroom, work the basic raw thing in lightroom
    rightclick edit a copy in cs5 and do all the changes i want in there. (blemishes removal, removing shadows, skin smoothing, sharpening, eyes and whatever. Save it and then go back in light room to export as a jpegs, add watermark and all the stuff.
    i like to keep 1 copy unedited for future work. However, the copy created by cs5 will be somewere between 50 to 400mb depending on the work, number of layers you create into that workfile. like mike said, files can get big but if you know photoshop and put a certain amount of work into your pictures, why not.
Ads
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Similar Threads
  1. RAW and Photoshop Workflow
    By RegRoy in forum Digital Discussion & Q&A
    Last Post: 07-10-2010, 09:47 PM
  2. A full photoshop workflow
    By Overread in forum Graphics Programs and Photo Gallery
    Last Post: 04-07-2010, 09:44 PM
  3. Lightroom, CS4, Photomatix workflow
    By Jon_Are in forum Graphics Programs and Photo Gallery
    Last Post: 06-23-2009, 07:38 PM
  4. Your PP 'Workflow'(Lightroom 2)
    By tenlientl in forum Photography Beginners' Forum
    Last Post: 10-14-2008, 06:41 AM
  5. Lightroom? How does it help your workflow?
    By BuZzZeRkEr in forum General Shop Talk
    Last Post: 08-07-2008, 07:22 PM
best lightroom to photoshop workflow
best workflow from lightroom to photoshop
better workflow photoshop lightroom
export between lightroom and photoshop
lightroom adjustments flatten psd
lightroom edit in photoshop back workflow
lightroom export preserving layers in photoshop
lightroom photoshop editing workflow
lightroom photoshop workflow edit copy
lightroom raw workflow editing in photoshop
lightroom, photoshop, editing workflow
wedding workflow photoshop
workflow adjustments in photoshop but not in lightroom
workflow for lightroom to photoshop
