Results 1 to 14 of 14
  1. #1
    Join Date
    Oct 2010
    Seattle, WA
    Posts
    7
    My Gallery
    (5)
    Liked
    0 times
    Getting a blurry background?
    I'm shooting for a conference and I love the shots with the subject in focus and a heavy blurred background behind the subject. I have a Nikon D5000 with a 18-55mm and a 55-200mm lense. Is it a certain lense that helps with the background or is it stictly settings like aperture priority that will give me the blur?
  2. # ADS
    Ads
    Google Advertisement
    Join Date
    Always
    Advertising world
    Posts
    Many
  3. #2
    Join Date
    Oct 2010
    Isle of Man
    Posts
    211
    My Gallery
    (0)
    My Photos Are NOT OK to Edit
    Liked
    5 times
    Well both really. With aperture priority you set the aperture so a larger aperture (smaller number) will blur the background and sharpen the subject and a smaller aperture (bigger number) will bring everything into focus, play around a little and you'll understand. But certain lenses can reach certain apertures look on the lens and you'll see a number that looks like '3.5-5.6' that is the largest aperture my lens can get yours may say something different. I'm sorry about the long discription.
    I reject your Nikon/Canon and substitute my Sony
  4. #3
    Join Date
    Oct 2010
    Seattle, WA
    Posts
    7
    My Gallery
    (5)
    Liked
    0 times
    My lenses are the same, but the light is so low, I bump up the shutter speed, but then the subjects move so fast, they turn out blurry. On top of that, I have it at f5.6 but the background isn't blurred enough...
  5. #4
    TPF Junkie!
    Join Date
    Jun 2009
    SW Florida
    Posts
    1,199
    My Gallery
    (0)
    Liked
    132 times
    DOF will depend on your lens magnification, aperature setting, distance to subject and distance between subject and background. Ideally you want to use the shallowest (small number like f/2.8) DOF possible to seperate subject from background. Many consumer level lenses dont go that low so getting blurry bg's becomes more difficult. You will probably be better off with your 200mm if you have the working distance. Also the farther you can put your subject from the background the better as this increases the blur effect (or bokeh).
    Quote Originally Posted by Breezy Smeezy View Post
    Dont be afraid to use a higher ISO to keep shutter speeds fast. And another option you have is blurring in your post processing via Photoshop. Very easy to do these days.
  6. #5
    Join Date
    Oct 2010
    Isle of Man
    Posts
    211
    My Gallery
    (0)
    Liked
    5 times
    Ok in low light situations use the ISO and choose a high ISO depending on the light intensity. The situation of the background not being blurry enough is that the biggest aperture you can set?
  7. #6
    Keeper of the Padlocks Site Moderator
    TPF Supporter
    Join Date
    May 2008
    UK - England
    Posts
    17,886
    My Gallery
    (0)
    My Photos Are OK to Edit
    Liked
    1723 times
    The best book for reference on this subject is "Understanding Exposure" by Bryan Peterson and I strongly recommend you read a copy of this book for a fuller grounding in the overall topic of exposures and controlling them.
    As for the subject of blurry backgrounds there are several factors that come into play here:
    1) Aperture - the larger the aperture (smaller the f number) the smaller the depth of field you will have in a shot. This is the area of the shot that is in focus - thus for a more blurred background having less depth of field helps to isolate the subject from the background
    2) Separation between subject and background - generally speaking the further away the subject of your shot is from the background to the shot the greater the blur will be on those background areas. So shooting someone leaning against a wall will be hard/impossible to get a wellblurred background on the wall - but place them a few meters or more away from that wall and the blurring increases (the wall/background is essentially further outside of the depth of field and thus blurs)
    3) Focal length of the lens - for the same framed shot (ie the same content and composition) using a longer focal length will result in a greater overall degree of separation of subject and background
    There are some other factors, but I don't think I'm going to do justice to the descriptions at this time of night - so again I recommend reading the book mentioned above. It will also go a long way to helping you understand how to select settings to use for different situations and for different shot types.
  8. #7
    TPF Junkie!
    Join Date
    Oct 2008
    Montreal
    Posts
    4,728
    My Gallery
    (0)
    Liked
    228 times
    Thats why shooting low light and freezing action requires good gear, well, better gear than what you have. Constant f/2.8 aperture lenses or fast primes (f/1.8 and wider) are essential as is a camera that can do a clean ISO 1600 and up.
    The three things that affect the blurryness of the background:
    1- wide aperture. Wider = more blurry
    2- focal lenght. Longer focal lenght = more blurry (ie 50mm vs 200mm, 200 will give more blurry)
    3- distance of subject to background. More distance = more blurry
    --Pierre
    Website
    Facebook
    Twitter
    "If your picture isn't good enough, you're not close enough."
    - Robert Capa
  9. #8
    Join Date
    Aug 2010
    Covington
    Posts
    209
    My Gallery
    (0)
    Liked
    0 times
    Since this thread has been answered with a wealth of information, shall we turn this thread into how to correctly pronounce Bokeh? It's commonly pronounced incorrectly, so to fit in, I do.
  10. #9
    Join Date
    Oct 2010
    Seattle, WA
    Posts
    7
    My Gallery
    (5)
    Liked
    0 times
    I'd sincerely like to thank everyone who is helping me out. All of it is very useful information.
    I've tried everything from setting the ISO up to 3200, setting the aperature to the lowest setting I can (which is only 5.6 :/), I put the 200mm lens on it, but with that lens, it's too close and my angle isnt wide enough. There are a lot of people at the convention, and so the intention of the blurred background is to not have any other people as distractions in the shot... that's my problem.
    Another question, if 200mm optomizes blurriness, are 35mm with f1.8 not okay?
  11. #10
    Join Date
    Sep 2010
    Posts
    473
    My Gallery
    (0)
    Liked
    28 times
    35 1.8 is good but it doesnt give u a a great blurred background because it is essentially a wide angle lens (altho standard on ur d5000) the best thing to do is get as close as possible to the subject with the 35 and leave it at 1.8, use a bounce flash (if u have one). Pretty much everyone has hit the nail on the head of what ur supposed to do, so get out there do it!!! maybe rent a lens for the occasion? a 70-210 will give u AWESOME results
  12. #11
    TPF Junkie!
    Join Date
    Sep 2006
    Wichita, Kansas, USA
    Posts
    4,602
    My Gallery
    (0)
    Liked
    371 times
    Amateurs worry about equipment, professionals worry about time, masters worry about light.
    I can honestly say that there are two most remarkable men in the world today.
    Michio Kaku is one, and I am the other. Between us we cover all knowledge.
    Kaku knows all that can be known....And I know the rest.
    "Yesterday is history, tomorrow is a mystery. Today?
    Today is a gift. That is why we call it the present."
    Master Wugui from Kung Fu Panda
  13. #12
    TPF Junkie!
    Join Date
    May 2008
    Seattle, WA
    Posts
    2,768
    My Gallery
    (15)
    Liked
    110 times
    A lens that only goes down to f5.6 is not likely to blur the background as much as you want, not unless it's a very long telephoto (400mm or more).
    This is why people spend all the extra $$ to buy lenses that can go down to f2.8 or even f1.4
  14. #13
    KmH
    KmH is offline
    Helping photographers learn to fish
    TPF Supporter
    Join Date
    Apr 2009
    Iowa
    Posts
    28,796
    My Gallery
    (1)
    Liked
    2812 times
    Quote Originally Posted by SageMark View Post
    Well no, because a blurred background and bokeh are not the same thing.
    Bokeh is mostly a function of how a lens is corrected for spherical aberration, by the number of aperture blades, and the shape of their edges, because that defines the shape of the lens aperture and that lenses circle of confusion. Circle of confusion - Wikipedia, the free encyclopedia
  15. #14
    Join Date
    Jan 2011
    Canada
    Posts
    192
    My Gallery
    (0)
    Liked
    0 times
    Oh wow.
Ads
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Similar Threads
  1. Blurry Background
    By Tamster in forum Photography Beginners' Forum
    Last Post: 02-12-2011, 09:32 PM
  2. Getting a blurry background?
    By Breezy Smeezy in forum Photography Beginners' Forum
    Last Post: 10-19-2010, 04:53 PM
  3. Blurry Background
    By Garcia in forum Photography Beginners' Forum
    Last Post: 09-03-2007, 09:50 AM
  4. Blurry background, focused subject - is my lens ok?
    By lilmorecowbell in forum Photography Beginners' Forum
    Last Post: 08-27-2007, 11:29 PM
  5. Blurry subject, clear background.
    By RoffleWoffle in forum Beyond the Basics
    Last Post: 06-19-2006, 04:37 AM
18-55mm lens blur background
get blurred background at 200mm
how to blur background with 18-55mm lens
how to blur the background with iso
is f5.6 enough to blurr a background
iso blurry background
what do you call a light that is blerd
what do you call it when photo blur
what do you call someone who get in the photo background
what do you call the background blurring in photography
what do you call the blur in the background
what do you call things that are blurry
what is blurry background in picture called
what is it called when the background of a picture is blurred
what is the angle when the background is blurred
