+ Reply to Thread
Results 1 to 13 of 13
  1. #1
    Join Date
    Nov 2010
    Bahrain
    Posts
    24
    My Gallery
    (0)
    My Photos Are NOT OK to Edit
    Liked
    0 times
    White balance (grey card? white card? or color passport?)
    Hi all,
    When I do photo-shoot with strobes I use the in camera flash white balance.
    I get fairly good results then I edit one photo in lightroom and apply the setting to the others.
    I know it is not very smart to do this.
    So what is your best way in setting up the white balance?
    and what is the different between the grey card and the white card?
    I tried the custom white balance in my canon camera and I took an Image of a white board under the same light condition for the original photo but it always fails.. it gives me strange colors.
    Thank you,
  2. # ADS
  3. #2
    Watch the Birdy! Site Moderator
    TPF Supporter
    Join Date
    Jul 2005
    Southern Vancouver Island, BC
    Posts
    11,682
    My Gallery
    (23)
    My Photos Are OK to Edit
    Liked
    1051 times
    99.9% of the time I shoot WB in 'Auto' and adjust in post to achieve the look I want. When true colours are absolutely critical, then I use an Expo Disc and shoot a custom WB.
  4. #3
    It's all about - Light Site Moderator
    TPF Supporter
    Join Date
    Apr 2009
    Iowa
    Posts
    22,032
    My Gallery
    (1)
    Liked
    1736 times
    Quote Originally Posted by Balwazer View Post
    Thank you,
    No doubt. Your brain makes adjustments to meet your expectations of what white is supposed to look like in the available light.
    But, that is not accurate, as you have now discoverd.
    To a digital camera there is only one white - R = 255, G = 255, B = 255, anything else has a color cast.
    The advantage of using a quality gray card is an accurate custom white balance.
    The X-RITE ColorChecker Passport is very helpful when you have people in an image, so you can accurately set skin tones. I also use a Whibal card when I don't need the ColorChecker.
    Michael Tapes Design - LensAlign - WhiBal - IJFR - WhiBal Certified Gray Card for White Balance
    X-Rite: Get exactly the color you need, every time, anywhere in the world.
    . . . . . . Keith . . . . . . .How Do I Use My Digital SLR?...
    "Even the easy things are tough, if you do them half-heartedly"
    FOR SALE : Stay Tuned!
  5. #4
    Join Date
    Nov 2010
    Bahrain
    Posts
    24
    My Gallery
    (0)
    Liked
    0 times
    Tiredirone: I liked the expo disc.. Does it really work?
    Kmh: how to use this small grey card?
  6. #5
    TPF Supporter
    Join Date
    Apr 2009
    Iowa
    Posts
    22,032
    My Gallery
    (1)
    Liked
    1736 times
    You make a photo with the gray card in it. In post processing you use the gray card to set the white balance.
  7. #6
    TPF Supporter
    Join Date
    Jul 2005
    Posts
    11,682
    My Gallery
    (23)
    Liked
    1051 times
    It works very well, BUT it is expensive ($100+ in 77mm) and getting a custom WB in dim light can be difficult, especially if you don't have a fast lens.
  8. #7
    TPF Junkie!
    Join Date
    Oct 2003
    Brisbane, Australia
    Posts
    9,238
    My Gallery
    (0)
    Liked
    107 times
    I say the passport. Benefits of being able to carefully adjust the calibration of your camera if you are so inclined / technically able. It really is an invaluable tool.
    "I am always satisfied with the best." -Oscar Wilde
    Larger versions always on flickr
    Best photos in my gallery
    Proud Supporter of The Pact
  9. #8
    Join Date
    Jan 2011
    Ohio
    Posts
    341
    My Gallery
    (0)
    Liked
    9 times
    It varies with me I guess just depending on whats going on. If ive got one light source I will use a preset and tune it as needed. But if its mixed I will use my gray card, which I use whitebal kinda over priced but it works well.
    But there is no best way, its really what is easier for you. I don't like post processing so I try and get everything as close as possible then and there. Using Auto in sunlight, cloudy in shade works pretty well. The reason the white board isn't working for you is because your camera is seeking a completely neutral color, not white. White cards are used for post processing as a reference, so you can select that as perfect white in photoshop or whatever, and it automatically removes the color cast.
  10. #9
    Join Date
    Nov 2010
    Bahrain
    Posts
    24
    My Gallery
    (0)
    Liked
    0 times
    Quote Originally Posted by xjoewhitex View Post
    Which whitebal do you recommend? I saw many types and sizes in their website
  11. #10
    Join Date
    Jan 2011
    Newfoundland
    Posts
    My Gallery
    (0)
    Liked
    0 times
    First post here!
    I recently bought a 18% grey/pure white double side card. So now I'm trying to figure out exactly how to use it. Is the grey side for exposure and the white side for white balance? We just got a big snowfall and I understand that all the white snow will overcome the powers of the sensor to figure out exposure and WB. If I'm outside, how exactly can I use this card to set the custom WB and exposure? Any detailed tips?
    Thanks!!
  12. #11
    Join Date
    Apr 2008
    Posts
    448
    My Gallery
    (0)
    Liked
    3 times
    For color accurate work, I shoot a Kodak Q13 (google is your friend) in the scene, white balance on a middle gray and then verify the entire tonal range for neutrality, making adjustments globally if needed. With practice, it only takes a few minutes and as long as lighting and exposure doesn't change, valid for the entire shooting session.
    Nikon F, F2 Photomic, 3-F3/MD4, F4, Nikon D2X, Nikon D2hs, Fuji S2, Kodak SLR/N, more glass than a person should own, 2-RB67/lotsa glass, Hassy 500EL/m 40/50/80/150/250, Megavision S3 back, Sinar 4x5 F, 4x5/8x10 P, 16x20, 20x24 cameras, Dicomed FieldPro scanback, more LF lenses than I can keep track of, Broncolor Lighting, Custom HMI lighting
  13. #12
    Join Date
    Jan 2011
    Ohio
    Posts
    341
    My Gallery
    (0)
    Liked
    9 times
    Well honestly, they are all the same thing just different sizes so whatever you think will work for you. I went with the medium format with the holder so I could sit it up on a table if I needed. I believe the smallest one would work well, its about the size of a business card I believe.
  14. #13
    Join Date
    Jan 2011
    Scranton, PA
    Posts
    6
    My Gallery
    (0)
    Liked
    0 times
    I use the Digital Calibration Target from Ed Pierce. It's great in the studio for white balance and exposure. Even though I use a calibrated light meter, the target really lets me dial in the exposure so that I rarely have to touch white balance and exposure on my RAW files.
    I also carry a knockoff of a WhiBal in my bag for quick shooting when I don't want to tote a target around. Basically, anything you can do to help you zero in on your white balance will end up saving you time in the long run.
    Any 'standard' you can use for white balance reference in your photos will help you work faster. In my opinion, getting the exposure and white balance right is what saves you LOADS of time when processing images.
Sponsors
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Similar Threads
  1. Grey Card or White Card or Black Card??
    By memento in forum Beyond the Basics
    Last Post: 02-10-2011, 12:00 PM
  2. 6 Color Temperature and White Balance Card Photography
    By Link Delight Online Shop in forum Linkdelight Photography Accessories
    Last Post: 10-17-2010, 08:47 PM
  3. White balance card??
    By realitycheck3907 in forum Photography Beginners' Forum
    Last Post: 10-04-2008, 10:37 AM
  4. White Balance Card
    By mikemizza in forum Beyond the Basics
    Last Post: 02-11-2008, 09:42 AM
  5. 18% grey or white card for white balance setting
    By shingfan in forum Photography Beginners' Forum
    Last Post: 01-26-2007, 02:51 PM
best grey card white balance
best white balance card
calibrate camera with white balance card
custom white balance grey card
difference between white balance grey card
digital grey card vs passport
how does white card work photography
how to use a white card for white balance
passport for white balance
small grey card
use a white bard canon
white balance color card
white balance passport
white balance with white card
white card white balance
