+ Reply to Thread
Results 1 to 13 of 13
Like Tree1Likes
  • 1 Post By SlickSalmon
Thread: Tips for shooting apartment interiors?
  1. #1
    Join Date
    May 2010
    UK
    Posts
    12
    My Gallery
    (0)
    Liked
    0 times
    Hi everyone!
    I'm taking shots of several apartments tomorrow to be used in a portfolio to sell them. I will be using a Nikon D90 with an 18-200mm lens. I've never done this type of photography before so can anyone give me any advice if they have experience please. Any help, greatly appreciated!
    Couple things I wasn't sure on were firstly, is this lens adequate? preferably I would have rather had a wider lens.
    Also, Obviously I want to get as much in focus as possible so I was planning on putting the camera in aperture priority mode to get as much in as I can in focus. Is this the right way to go about it.
    Does anyone have a rough idea on what sort of aperture I should be working with?
    Any other bits of advice you can give would be great too.
    also, should i use a tripod or is handheld accaptable?
    Thanks! x
  2. # ADS
  3. #2
    Join Date
    Feb 2011
    greece
    Posts
    15
    My Gallery
    (0)
    My Photos Are NOT OK to Edit
    Liked
    0 times
    why don't you ask an advice from an interior decorator? i don't know if you can understand my english.... they know tips to make their life easy
  4. #3
    TPF Junkie!
    Join Date
    Oct 2008
    Chesterfield UK
    Posts
    7,956
    My Gallery
    (0)
    My Photos Are OK to Edit
    Liked
    677 times
    A tripod is a must because with that lens you will have to use slower shutter speeds (probably 2 seconds or more), look out for unique details if there is a nice fire light it, a nice lamp turn it on because it can give a nice warm feel to the shot (take a custom white balance) place books on tables. Avoid objects close to your lens when shooting wide they will look unnaturally large or deformed, avoid shooting directly towards windows you will max out your exposure if using flash only use it to fill boucing off walls, and if possible (when there is a nice veiw) try and capture the veiw taking in the chairs to give an idea of the veiw from sitting position
  5. #4
    TPF Junkie!
    Join Date
    May 2008
    Seattle, WA
    Posts
    2,511
    My Gallery
    (15)
    Liked
    77 times
    That lens is not ideal, but it should work for you. Typically you'd want a 14mm or wider lens on a crop sensor camera like yours.
    What you could really use is a flash that you can bounce off the walls/ceiling. Indoor lighting can look a bit harsh and unattractive without a little fill flash.
    The key to using the flash is to aim it up and away from the subject, so it is diffused off the walls. Also shoot in manual adjusting for more or less exposure which will control how much the flash adds to the final image. You don't want all flash, just a little boost.
  6. #5
    TPF Junkie!
    Join Date
    May 2007
    Canada
    Posts
    3,992
    My Gallery
    (36)
    Liked
    59 times
    10 to 20mm lens on a crop body camera.
    tripod
    auxiliary lighting
    fstop around f.8 to f11
    Camera angles are really important to avoid distortion.
    High ISO with low noise to avoid or reduce window blow-out.
    skieur
  7. #6
    Join Date
    Oct 2010
    Philadelphia, PA
    Posts
    154
    My Gallery
    (0)
    Liked
    1 times
    Get an sb600 speedflash. Bounce flash from ceiling. You do not need a tripod if your using flash. Plus, the VR works GREAT on that lens.
    Use an F stop of f11.
    --Nikon D300s and Nikon D7000--
    18-200mm f/3.5 Nikkor, 50mm f/1.8 Nikkor, 75-300mm Nikkor AF, 150mm-500mm Sigma, SB-600 & SB-700 Speedflash
  8. #7
    Join Date
    Jan 2011
    Posts
    284
    My Gallery
    (0)
    Liked
    13 times
    I'm seeing HDR technique increasingly and very effectively used for interiors. You can use ambient lighting, which makes rooms look more natural than bounce flash...at least in my opinion...and you can create very rich images. It also handles the light-out-the-window problem.
    OrionsByte likes this.
  9. #8
    Join Date
    Dec 2010
    Greensboro, NC
    Posts
    9
    My Gallery
    (0)
    Liked
    0 times
    Make sure adjacent rooms are lit well, and keep the camera under 4 feet to reduce distortion.
    As a side note, if this is for a client, you might want to ask about how much distortion is acceptable because using a wide lens is a must...14mm or less. You might find yourself correcting vertical lines in Photoshop.
  10. #9
    Join Date
    Aug 2009
    Bay Shore, NY
    Posts
    232
    My Gallery
    (0)
    Liked
    0 times
    This thread was quite helpful, I just got a job shooting the interior of a large "mansion" and wanted to check my facts. Thanks!
    "I work from awkwardness.
    By that I mean I don't like to arrange things.
    If I stand in front of something,
    instead of arranging it,
    I arrange myself."
    - Diane Arbus -
    ** The Photo Forum Pact **
  11. #10
    Join Date
    Dec 2007
    Ft. Thomas, KY
    Posts
    465
    My Gallery
    (0)
    Liked
    0 times
    Some thoughts....
    I've shot quite a few interiors for a couple of local listing agents. Of course these are my opinions so take them for what they're worth to you.
    I NEVER use flash. Even bouncing flash gives you harsh shadows that to me are not natural. I shoot with my full-frame 5DMII and a 12-24mm lens. I try to stick in the f16 range. I bracket the hell out of every setup because as mentioned when shooting in the daytime, the windows are going to blow out. I will not HDR these images, but use some parts of various images on top of each other using layer masking. Say I have an image that's quite dark inside the room, but the windows are good. I'll take that and paste it into a layer behind the well-lit interior shot. Erase the windows on that layer revealing the well-exposed windows in the layer below. Since 95% of the shots are viewed on the web I don't have to be super-critical on the edits between layers, not to say they're crap. I'm just not as critical as a shot going to print.
    Color balance can be a pain as well. You've got interior lamps and daylight exteriors. I usually do a custom white balance for the room's interior, and when the windows and incoming light goes blue I adjust for it in post.
    I'm sure there's a gazillion opinions out there, this works for me..... and my clients.
    Good luck!
    Canon 5D MarkII
    Canon 70-200 f2.8
    Canon 28-135 f3.5 IS
    Canon 16-35 f2.8
    Sigma 12-24 f4.5-5.6
    Tons of LensBaby Stuff
    BlueGrassPhotography.Net
    My Zenfolio
  12. #11
    TPF Junkie!
    Join Date
    Apr 2011
    Vermont
    Posts
    1,923
    My Gallery
    (0)
    Liked
    326 times
    Really focus on the lighting, can be flash or continuous, but the lighting totally sets the mood for an interior shot. Definitely use a tripod, and watch for distortions/converging verticals etc.... I'll correct some perspective distortion in post, but try to compose around it as best you can (keep the camera close to horizontal).
    Did I mention pay attention to the lighting?
    60d, Tokina 11-16 2.8, Canon 24 1.4L II, Zeiss 35 1.4 Distagon, Zeiss 50 2.0 Makro-Planar, Canon 85 1.8, Yashica DX 135 2.8, flashy stuff, filtery stuff
  13. #12
    TPF Junkie!
    TPF Supporter
    Join Date
    Jul 2010
    N. California
    Posts
    1,288
    My Gallery
    (0)
    Liked
    186 times
    Since this thread is 5 months old and just got resurrected today, I'd love to see the OP drop by to show us how the shots turned out. However, since they haven't been on the site since March, I guess I shouldn't hold my breath.
    -Brian
    Nikon D7000 · 18-55mm f/3.5-5.6 DX VR · 55-200mm f/4-5.6 DX VR IF ED · 50mm f/1.4D · SB-600
    Amateurs practice until they get it right.
    Professionals practice until they can't get it wrong.
    PLAY TODAY!
    TPF FIGHT CLUB
  14. #13
    TPF Junkie!
    Join Date
    Apr 2011
    Vermont
    Posts
    1,923
    My Gallery
    (0)
    Liked
    326 times
    Quote Originally Posted by OrionsByte View Post
    lol, nice
Sponsors
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Similar Threads
  1. Shooting interiors of buildings...(recording studio)
    By Ub3rdoRK in forum Beyond the Basics
    Last Post: 11-25-2010, 12:47 AM
  2. Need tips for shooting in a gym
    By Boz Mon in forum Photography Beginners' Forum
    Last Post: 02-06-2009, 10:05 AM
  3. Tips for shooting B&W
    By darkpbstar in forum Photography Beginners' Forum
    Last Post: 05-31-2008, 07:12 PM
  4. Need advice on shooting interiors (arch work)
    By dpolston in forum Commercial/Product photography
    Last Post: 02-28-2008, 01:56 PM
  5. Replies: 1
    Last Post: 07-17-2005, 02:40 PM
apartment photography tips
appartment photographer ips
best camera for apartment photography
best lens for interior photography
best lens for interiors
best lens for shooting interiors
best type of lens to photograph interior of apartment
digital photography of apartments
how to photograph apartment
nikon d90 set up for interior shooting
photographing an appartment
photographing apartments
photographing condominium interiors
photographing interiors equipment
photographs interior apt
Tags for this Thread
