+ Reply to Thread
Page 1 of 4 1 2 3 ... LastLast
Results 1 to 15 of 51
Like Tree11Likes
Thread: Exposing to minimize noise (when using high ISO)
  1. #1
    Learner driver
    TPF Supporter
    Join Date
    Feb 2011
    Cork Ireland
    Posts
    732
    My Gallery
    (0)
    My Photos Are OK to Edit
    Liked
    63 times
    If I am in a situation where my only option to get a shot is at extremely high ISO it obviously would be nice to keep the noise as low as possible. Reading a few posts here I think it seems better to slightly overexpose the shot and bring it back in post. Is this correct, and if so what level is a ballpark recommended overexpose level? Thanks
    ​IF YOUR NOT IN, YOU CAN'T LOSE
  2. # ADS
  3. #2
    TPF Junkie!
    TPF Supporter
    Join Date
    May 2011
    Montana
    Posts
    2,239
    My Gallery
    (0)
    Liked
    357 times
    There are a few different philosophies here, and I think both are valid, it just depends on approach.
    I personally believe that this is the best approach at high ISO or otherwise, the problem becomes what is the best method to compensate the shadows. The way I expose is to meter the brightest region in the scene and then increase exposure to the outer limits of the camera's latitude without clipping, I then allow the shadows to fall wherever they will and compensate using a curve adjustment.
    EchoingWhisper likes this.
    everything is new and nothing has ever been done before - richard rorty
  4. #3
    TPF Junkie!
    TPF Supporter
    Join Date
    Nov 2011
    Nashville, TN
    Posts
    1,337
    My Gallery
    (0)
    My Photos Are NOT OK to Edit
    Liked
    256 times
    That is the Expose To The Right philosophy and by what I have read it makes sense and seems to work quite well. Read This Article.
    WhiskeyTango likes this.
    Scott Craig - Nashville, TN - Nikon D7000, D90, D60
    Photography Pages on My Web Site and My Under Construction Site
  5. #4
    TPF Junkie!
    Join Date
    Apr 2011
    Vermont
    Posts
    1,923
    My Gallery
    (0)
    Liked
    326 times
    Yeah, I usually just expose so the valuable highlights are just short of clipping. (meaning some areas I will actually let blow depending on the situation, background elements, whatever). Then mess with the curves when I do the RAW conversion to pull the shadows (and the noise) back down.
    60d, Tokina 11-16 2.8, Canon 24 1.4L II, Zeiss 35 1.4 Distagon, Zeiss 50 2.0 Makro-Planar, Canon 85 1.8, Yashica DX 135 2.8, flashy stuff, filtery stuff
  6. #5
    TPF Junkie!
    Join Date
    Jul 2009
    San Diego, CA (RB)
    Posts
    2,941
    My Gallery
    (0)
    Liked
    130 times
    How are you going to expose to the right if you're already raising your ISO pretty high?If you are going to raise the ISO like that then we can assume you have reached your handheld shutter speed and aperture limit. Are you going to just max out ISO to "expose to the right"? If so, I find that counter productive.
  7. #6
    TPF Junkie!
    TPF Supporter
    Join Date
    Nov 2011
    Nashville, TN
    Posts
    1,337
    My Gallery
    (0)
    Liked
    256 times
    Quote Originally Posted by Dominantly View Post
    Read the article I linked to in post #3. It isn't very long and it will answer that question for you much better than I could in a couple of paragraphs. It really is worth the read.
  8. #7
    TPF Supporter
    Join Date
    Jan 2012
    Michigan (Detroit Metro)
    Posts
    231
    My Gallery
    (0)
    Liked
    41 times
    Quote Originally Posted by SCraig View Post
    I've been researching this pretty heavy over the last couple of weeks trying to figure out how to improve my indoor sports shots. That article is about the most succinct and helpful thing I've found so far. Thanks for the pointer!
    To follow up and flesh this out: I'm shooting with a Nikon D7000 and a Sigma 70-200 f/2.8 (non OS version). Up until now, I've been shooting in shutter priority mode with ISO fixed at 3200. I've also been leaving Active D Lighting (ADL) set to Auto. AF-C with spot focus. Matrix metering. No exposure compensation.
    My shots are always under exposed by at least a full stop, and raising the exposure in LR3 yields horrible results. Very excessive noise and very flat looking images. From my reading, it looks like ADL is partly to blame.
    This weekend, I'm planning to make the following changes: Shoot in program auto mode with shutter speed and f/stop both forced. ADL off. Auto ISO on and capped at 12,800. Exposure compensation +0.7. Center weighted metering. AF-C and 21 point dynamic area focusing.
    Any comments/criticisms of my thinking here?
    WhiskeyTango
    WhiskeyTango
    Nikon D7000 | Nikon 24-70 f/2.8G | Nikon 18-200mm f/3.5-5.6G VR II | Nikon 50mm f/1.8 G | Sigma 70-200 f/2.8 II
    • "All good things come to those who wait." -Abraham Lincoln
    • "I hate waiting." -Inigo Montoya
  9. #8
    TPF Junkie!
    Join Date
    Jul 2009
    San Diego, CA (RB)
    Posts
    2,941
    My Gallery
    (0)
    Liked
    130 times
    Yeah I understand what it's about, I just don't agree with using Super high ISO to expose to the right.
  10. #9
    TPF Junkie!
    Join Date
    Oct 2011
    NY
    Posts
    2,976
    My Gallery
    (24)
    Liked
    616 times
    Quote Originally Posted by WhiskeyTango View Post
    WhiskeyTango
    You will have much better results this weekend. If you are in controlled lighting-arena where nothing changes it's actually much easier to shoot in manual. You set your shutter to what your minimum is, set your aperture to your desired (mine is f/4 on the Sigma) and then raise your ISO to the point just before your highlights would blow. If you are shooting white jerseys or similar remember that the highlight warnings are warning you that you are blowing at least one color channel. If you are still able to see the folds around the highlight warning you are probably exposed well.
    Your lighting is never going to change in a controlled situation. If you use manual you have no changes in exposure to sort through in post because your spot hit something dark or light.
    You never want to shoot with more than one focus point. When you do that the camera gets to choose where your focus falls-any one of those points. If you are using one focus point you are in control. For different sports I use different focus points because of how the players naturally fall in the image.
    Big Mike and WhiskeyTango like this.
    Canon FanGirl Extraordinaire
  11. #10
    TPF Supporter
    Join Date
    Jan 2012
    Posts
    231
    My Gallery
    (0)
    Liked
    41 times
    That's a great idea. The games I'm interested in are Sunday, but I think I'll sneak in there on Saturday and play around a bit...
    WhiskeyTango
  12. #11
    TPF Junkie!
    Join Date
    Oct 2011
    NY
    Posts
    2,976
    My Gallery
    (24)
    Liked
    616 times
    I added a note up there on your focus points too!
  13. #12
    TPF Supporter
    Join Date
    Jan 2012
    Posts
    231
    My Gallery
    (0)
    Liked
    41 times
    Quote Originally Posted by MLeeK View Post
    Yeah, I'm torn on the focus points. I've been using single point, and am getting better at getting it where I want. I stumbled across several recommendations, though, for the 21 point dynamic area mode. One of them came from a pro-site.
    In addition to the light problem, I'm having issues trying to shoot through a net. (It's either that or shoot through glass). With single point, I occasionally get jumping from my intended target back to the net. Not sure if the dynamic area mode will do any better or not.
    I think I'll do some playing with both modes on Saturday and see what I get.
    WhiskeyTango
  14. #13
    TPF Junkie!
    TPF Supporter
    Join Date
    May 2011
    Montana
    Posts
    2,239
    My Gallery
    (0)
    Liked
    357 times
    I am not quite sure what the issue would be. If at ISO 100 your exposure is +4ev @ 1/15, at ISO 12800 it would be about 1/2000 and still +4ev. Whether you'd still have +4ev latitude at that ISO is another issue.
  15. #14
    TPF Junkie!
    Join Date
    Jul 2009
    San Diego, CA (RB)
    Posts
    2,941
    My Gallery
    (0)
    Liked
    130 times
    Does exposing to the right somehow eliminate noise associated with high ISO?If you are at ISO2000 f/2.8 1/100 and have an even meter, upping the ISO to 3200 to expose to the right is only going to introduce even more noise into your shot. Which I do not agree with.
  16. #15
    TPF Junkie!
    Join Date
    Apr 2011
    Vermont
    Posts
    1,923
    My Gallery
    (0)
    Liked
    326 times
    It's relevant when you've already gone as far as you're willing with aperture and shutter. You will have better noise performance by exposing to the right by boosting ISO in analog, than you will be exposing "properly". This is because you collect more digital data, thereby reducing quantization distortion and giving you flexibility with your conversion curves. You can then manipulate the curves to push the shadows and noise down.
    If you expose as you think the final photo should appear (i.e. not pushing the ISO), you will collect less overall digital data and have fewer options for noise reduction in post, since you've not collected sufficient shadow data to be messing around with that region of the curve.
+ Reply to Thread
Sponsors
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Similar Threads
  1. low noise or high megapixels?
    By nojeb96 in forum Digital Discussion & Q&A
    Last Post: 01-07-2012, 10:28 AM
  2. Nikon - Need low-noise at high ISO
    By Rebekah5280 in forum Photography Equipment & Products
    Last Post: 09-16-2011, 02:19 PM
  3. my husband (and ?? about high iso noise)
    By Ajay in forum People Photography
    Last Post: 04-07-2008, 02:22 PM
  4. High ISO Noise Reduction
    By dpot in forum Beyond the Basics
    Last Post: 09-22-2007, 09:10 AM
  5. Noise Reduction in High ISO
    By Peter Dove in forum Graphics Programs and Photo Gallery
    Last Post: 09-19-2004, 01:40 AM
digital photography, high iso, hiding noise
how do i minimize noise in my photographs
how to edit after using a high iso
how to edit high noise photo
how to minimize noise while shooting at a high iso
how to minimize noise with high iso
minimize grain at hight iso
minimize noise high iso
photo forum
photoforum
