+ Reply to Thread
Page 1 of 22 1 2 3 11 ... LastLast
Results 1 to 15 of 320
Like Tree47Likes
Thread: Larger sensor just a luxury?
  1. #1
    TPF Junkie!
    Join Date
    Aug 2011
    Malaysia
    Posts
    1,497
    My Gallery
    (0)
    My Photos Are OK to Edit
    Liked
    53 times
    Isn't a larger sensor just a luxury? I can only name a larger sensor's benefit - more resolution. A different perspective is debatable - whether it's better or not. Depth of field and low light ability is almost the same, given that the lens is the same size and sensor design is the same (same megapixels). Almost all camera companies only put professional features in their larger cameras now. Is there other benefit for a larger sensor?
    Call me Michael.
    Nikon D5100 | AF-S Nikkor 18-55mm 1:3.5-5.6G DX | AF-S NIKKOR 55-200mm 1:4-5.6G ED DX | AF-S NIKKOR 50mm 1:1.8G
  2. # ADS
  3. #2
    TPF Junkie!
    Join Date
    Apr 2010
    DFW
    Posts
    2,314
    My Gallery
    (0)
    Liked
    506 times
    It's one of those cases where if you have to ask, then it shouldn't matter to you.
    Either way, you missed one of the primary advantages; lower noise.
    The best of all things is to learn. Money can be lost or stolen, health or strength may fail, but what you have committed to your mind is yours forever.
    --George
  4. #3
    TPF Junkie!
    TPF Supporter
    Join Date
    Nov 2011
    Nashville, TN
    Posts
    1,337
    My Gallery
    (0)
    My Photos Are NOT OK to Edit
    Liked
    256 times
    Generally speaking larger sensors mean larger pixels on the sensor, which generally means that the signal strength of each pixel on the sensor has a higher signal to noise ratio. This translates, roughly, to larger sensors means lower noise. Given the exceptionally good noise rejection performance that some manufacturers are getting from smaller, high-density sensors these days, and the fact that even the full-format sensors are getting much higher densities, the line between the two is getting blurred though.
    Scott Craig - Nashville, TN - Nikon D7000, D90, D60
    Photography Pages on My Web Site and My Under Construction Site
  5. #4
    Keeper of the Padlocks Site Moderator
    TPF Supporter
    Join Date
    May 2008
    UK - England
    Posts
    15,056
    My Gallery
    (0)
    Liked
    887 times
    A large sensor gives a different angle of view when using the same lenses and comparing to a crop sensor. This can be a big difference when you're working indoors and want to use something like a 50mm for portrait work, rather than having to use a 35mm and suffer distortion problems (parts of the shot closer to the camera being enlarged).
    You also get depth of field advantages - around one stop less is possible with the fullframe as compared to the 1.5/6 crop sensor camera bodies.
    Points have also been made regarding the pixels size and density and advantages with cleaner high ISOs.
    Also remember the whole of the DSLR is a luxury. Heck the ownership of a camera in itself isn't a necessity
    Postman158 likes this.
    How to get critique and feedback on your photography!
    Photo of the month April Voting now open
    The Mentor Scheme mentoring on TPF all are welcome to read and apply
    Best photos on the net!
    well at least I like to think so - sometimes
  6. #5
    TPF Junkie!
    Join Date
    Aug 2009
    I'm a Mainer.
    Posts
    5,904
    My Gallery
    (0)
    Liked
    1306 times
    Quote Originally Posted by EchoingWhisper View Post
    At longer focal lengths you also have more background control with a full frame camera.
    If you frame a shot with a full frame camera at 135mm @ f/2 you'll have a DoF of .79 feet, if you were to frame the shot EXACTLY the same with an APS-C camera you would need to move away from the subject farther. Thus increasing the DoF at the same aperture/focal length giving you (to my eyes) a noticeable difference in background control.
    This is an extreme example, but if you think about it, sense will make itself.
    Trever1t and nmoody like this.
    Facebook
    http://tylerdrummphoto.com/ (COMING SOON)
    Girl, I like that you don't have AIDS, and that you covered the rent when I don't get paid. The dinner that you simmer-sauté'd made it so I haven't been to Taco Bell in like DAYS.
  7. #6
    TPF Junkie!
    TPF Supporter
    Join Date
    Nov 2011
    Nashville, TN
    Posts
    1,337
    My Gallery
    (0)
    Liked
    256 times
    Quote Originally Posted by Overread View Post
    A large sensor gives a different angle of view when using the same lenses and comparing to a crop sensor. This can be a big difference when you're working indoors and want to use something like a 50mm for portrait work, rather than having to use a 35mm and suffer distortion problems (parts of the shot closer to the camera being enlarged). ...
    Agreed, however that same logic can be viewed as a deficit in other areas of photography. For example, when shooting birds the effective focal length increase of 150% is a big benefit.
  8. #7
    TPF Supporter
    Join Date
    May 2008
    UK - England
    Posts
    15,056
    My Gallery
    (0)
    Liked
    887 times
    Quote Originally Posted by SCraig View Post
    Exactly - which is partly why I love my 7D (along with its fantastic AF).
    Although I should point out that the 7D also has a luxury sensor in it, big and expensive if I compared it to a bridge camera.
  9. #8
    TPF Junkie!
    Join Date
    Aug 2011
    Malaysia
    Posts
    1,497
    My Gallery
    (0)
    Liked
    53 times
    I think you guys missed my point at my fourth sentence. Given that the lens is the same size (not including VR and AF), you get the same amount of light no matter how large of a sensor it hits as long as they have the same amount of pixels. A f/2.8 APS-C lens is smaller than a f/2.8 full frame lens. A f/2.0 APS-C lens will provide about the amount of light as a f/2.8 full frame lens. (APS-C is about 1 time smaller than a full frame sensor, so it gets 1 time less light at the same f stop). So the SNR of *should* be the same. I said should cause' I don't know if a larger sensor will have better SNR even if they get the same amount of light.
    And depth of field should also be the same. At the same focal length, you get to get about 1 time closer to the subject using a full frame camera compared to APS-C cameras, which gives you about 1 stop less depth of field. But that depth of field difference could be removed if both the full frame lens and APS-C lens are the same size since the APS-C lens is f/2.0, you get back your 1 stop loss of depth of field by using a larger aperture.
    The only difference I see from a full frame compared to APS-C other than resolution is depth of field distribution, distortion and foreground size in relative to background size (perspective).
    Please correct me if you find me wrong.
    Call me Michael.
  10. #9
    TPF Junkie!
    TPF Supporter
    Join Date
    Nov 2011
    Nashville, TN
    Posts
    1,337
    My Gallery
    (0)
    Liked
    256 times
    Not true. A full-frame sensor is 36mm x 24mm in size, or 864 square mm. An APS-C sensor is 25.1mm x 16.7mm or 419.7 square mm (varies with manufacturer). Assuming that both sensors have, for example, 10 megapixels it's obvious that each pixel on the APS-C sensor is going to be physically smaller by about 50%. Since each pixel is a light sensor, the larger each individual pixel the more photons will hit it during the exposure. More photons hitting the pixel means a higher voltage for that particular pixel when compared to the same pixel of an APS-C sensor. It we make the assumption that the electronic noise level will be consistent between the two sensors (I don't know whether that's a valid assumption or not) then the voltage for each pixel on the FX sensor is going to be higher than the voltage of each pixel of the APS-C sensor yielding a higher signal to noise ratio. That ratio is what's important since the higher the ratio the easier it is to filter out the noise.
  11. #10
    TPF Junkie!
    Join Date
    Aug 2011
    Malaysia
    Posts
    1,497
    My Gallery
    (0)
    Liked
    53 times
    Given that both of the lens are the same size, both will get. Since APS-C sensors' pixel are denser, the light that falls on it is also denser, given that the lens are the same size as full frame. Light in the lens in full frame is spread out more so photons will be more spread out and less dense. Not sure if I'm right too.
    If I am right, full frame cameras' only benefit is resolution. A larger sensor also mean a more expensive sensor and also a larger body and a more expensive body. Whether a larger body is good or not, I'd say bodies larger than the current full frame camera bodies are too big to be comfortable, at least for me.
    Call me Michael.
  12. #11
    TPF Junkie!
    TPF Supporter
    Join Date
    Nov 2011
    Nashville, TN
    Posts
    1,337
    My Gallery
    (0)
    Liked
    256 times
    I'm sure you have seen the diagrams that show a full-frame sensor with a crop-sensor indicated inside it (if not look Here). The full-frame sensor effectively receives ALL of the light from the lens however the crop-sensor does not. The crop-sensor camera only receives the middle 50% to 60% of the light transmitted through the lens.
  13. #12
    TPF Junkie!
    Join Date
    Aug 2011
    Malaysia
    Posts
    1,497
    My Gallery
    (0)
    Liked
    53 times
    That only applies if both are the same lens. If the APS-C lens is made to transmit the same amount of light as the full frame lens while covering only APS-C will be 1 f stop higher than the full frame sensor even though that they get the same amount of light.
    Call me Michael.
  14. #13
    Join Date
    Jan 2012
    Ne US
    Posts
    279
    My Gallery
    (0)
    Liked
    24 times
    Depends on what your doing with it?
    If you make big prints, go with a big sensor. (In general.)
    Nowadays 'almost' all cams can take a decent photo for viewing on the 'puter.
    Here is a shot taken with a cheap Walmart $75 PS Kodak cam... shot at a measly mp setting of 1.1mp.
  15. #14
    TPF Junkie!
    Join Date
    Jun 2010
    minnesota
    Posts
    1,965
    My Gallery
    (0)
    Liked
    266 times
    You say large sensor, yet your talking about 35mm. When I hear large sensor I think medium format and large format. I'm not sure about the advantages, but I can tell you what I personally like about portraits produced with medium/large format sensors. You get a wider FOV, with longer focal lengths. People look their best at longer focal lengths, and with medium/large format you can use very long focal lengths in smaller spaces.
  16. #15
    TPF Junkie!
    Join Date
    Sep 2007
    Hell's Kitchen, New York
    Posts
    2,584
    My Gallery
    (0)
    Liked
    174 times
    Quote Originally Posted by jake337 View Post
    I always thought that it was the camera-subject distance that mattered with portraits, not the focal length of the lens itself.
+ Reply to Thread
Sponsors
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Similar Threads
  1. Replies: 8
    Last Post: 08-24-2011, 02:47 PM
  2. Why is a larger sensor better?
    By dmatsui in forum Photography Beginners' Forum
    Last Post: 08-27-2008, 04:45 PM
  3. Want Larger Grain (the larger the better)
    By SamIam.Life in forum Beyond the Basics
    Last Post: 02-01-2008, 11:08 AM
atlanta craigslist
do i need a large sensor camera if i don't print
flash someone
i wish the x-pro1 was full-frame
instagram login
large sensor means
pana leica 25mm f.1.4 m43
priceangels
small sensor vs large sensor
what's next in large sensor cameras
