Results 1 to 8 of 8
  1. #1
    Join Date
    Feb 2012
    Arlington VA
    Posts
    14
    My Gallery
    (0)
    Liked
    0 times
    HDR Using a T2i/550D
    Hello everyone! Please do not bash me as I am still a beginner but learning quickly. Does anyone know of a step by step guide on how to achieve HDR Photos with a T2i. I know the T2i doesn't have this feature built in but I have heard that with the correct exposure and software you can get some decent looking photos. Thanks Muah!
    -Steph
  2. #2
    Join Date
    Sep 2011
    South England
    Posts
    160
    My Gallery
    (0)
    My Photos Are OK to Edit
    Liked
    13 times
    To achieve a good quality HDR image you shoot a range of images using a tripod, exposing the darkest area of a scene to the lightest. Using Photoshop (file> automate> merge to HDR) or other HDR software it will merge the images into one, then you can play with the exposure, contrast etc.. My Photography teacher taught me the difference in quality from using a few bracketed images and using a tripod with 10-20 images. If your software has HDR processing, look up on youtube step by step guides.
  3. #3
    Join Date
    Feb 2012
    Homestead, Florida
    Posts
    14
    My Gallery
    (0)
    My Photos Are NOT OK to Edit
    Liked
    2 times
    I also have the T2i/550D and have no problems taking shots to be used for HDR. The key is to bracket your photos based on the Histogram. Usually -2,0,+2 is sufficient to gather all of the data between the bright and dark ends of the histogram. Sometimes very bright lights or contrast in your photo will require an additional shot to capture the mising information that is outside the histogram, usually requiring additional underexposure. In the menu of the T2i is an option for bracketing so that the camera automatically takes the prior stated exposure ranges in succesive shots. You can either manual hit the shutter button or set to multiple shot mode and hold the button down.
    You almost always have to use a tripod to make sure the subject matter in the photo will remain aligned for each shot. Although I have sucessfully taken a few handheld HDR shots when I did not have a tripod with me, the number of keepers is very low.
    After you have taken the images the next step is to process the photos with software specifically made for HDR. This requires stacking the three or more photos and combining the information from all three to illiminate or minimize the dark spots and blowouts. Photoshop has this option but I have not been thrilled with photoshops HDR results. It leans toward a more natural look which is not how most people envision HDR shots when taken. Photoshops option is under the automate function. My favorite HDR software is Photomatix. I have been very pleased with the results I have gotten from this software. After processing with your software of choice you can then further process the final product with photoshop or other program to polish the final product.
    Here is a shot I took a few weeks ago while hiking out in the everglades. Without HDR the skies would have been white and blown out. Also, it enhances the sun glowing through the bromeliad leaves. This shot was processed using the painterly setting in Photomatix which produces an extreme result and different look.
    Everglades, Big Cypress and Florida Keys Photography www.stephenshelleyphotography.com
  4. #4
    TPF Junkie!
    Join Date
    Nov 2011
    United States
    Posts
    3,787
    My Gallery
    (0)
    Liked
    1299 times
    Take 3+ shots at different exposures (-1, 0, 1 for example), and then use a program that will combine the image into a composite that includes the complete tonal range. Then you use tonemapping (which usually opens up automatically with the software) to get it to look less flat, because when the program combines the photo it usually has low contrast and washed out shadows. Tonemapping "brings it back to life" so to speak.
    Photoshop does give a more natural look, Photomatix is more stylized.
    (To the poster above, HDR was not originally intended to make the viewers eyes explode with unreal and fantastic colors. It's original purpose was to make scenes MORE realistic by making them more similar to what our eyes see. I'm not a big fan of images that are blatantly HDR. Just a personal opinion)
    "I have approximate knowledge of many things."
    http://www.davevaughn.com
  5. #5
    KmH
    KmH is online now
    Helping photographers learn to fish
    TPF Supporter
    Join Date
    Apr 2009
    Iowa
    Posts
    33,802
    My Gallery
    (1)
    Liked
    4021 times
    Done right it's a fairly technical process. The following is just some basics to get the exposures and doesn't delve into merging the exposures or doing any of the post processing.
    Put the camera in the spot metering and manual shooting mode. Set the lens aperture to f/8 to f/11
    Meter the darkest and lighest parts of the scene to determine the total dynamic range of the scene.
    You also have to evaluate if the dynamic range distributuion is fairly even, but that is more of a judgement thing than something you can measure. If the distribution is unbalanced, you would also need to unbalance your exposure brackets.
    Yout T2i can capture a dynamic range of 11.5 EV. If the total dynamic range is 11.5 EV or less, it is not a good candidate for the HDR technique.
    If the scene is 13 EV. You would then need to bracket at -1, 0, and +1 EV.
    If the scene is between 13 EV and 15 EV you would bracket at -2, 0, +2 EV.
    If the scene is more than 15 EV you would need to do more than 3 brackets.
    . . . . . . Keith . . . . . . .How Do I Use My Digital SLR?...
    * * * * * * * * * * A photograph is a roughly approximate 2-D interpretation of a 3-D reality. * * * * * * * * * *
  6. #6
    TPF Junkie!
    Join Date
    Mar 2011
    Houston
    Posts
    4,548
    My Gallery
    (0)
    Liked
    526 times
    Sony A580 and Sony A200 DSLR + grip
    Sigma 10-20 f3.5; Sigma 17-50mm f2.8; Sigma: 70-210mmF2.8 APO;
    Minolta 50mm F1.7
    Sony HVL-42AM Flash
    My Flickr
  7. #7
    KmH
    KmH is online now
    TPF Supporter
    Join Date
    Apr 2009
    Iowa
    Posts
    33,802
    My Gallery
    (1)
    Liked
    4021 times
    Wow! An online infomercial/tutorial.
  8. #8
    Join Date
    Feb 2012
    Arlington VA
    Posts
    14
    My Gallery
    (0)
    Liked
    0 times
    THANK YOU GUYS SO MUCH! This is very clear and useful information. I plan on taking my camera out with me tomorrow to play around with it a bit. Wish me luck. I will post my results in here. Thanks again!!
    Canon T2i
    --Follow me on Twitter
    --Add me on Facebook
Ads
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Similar Threads
  1. 50D and 550D
    By jaomul in forum Canon
    Last Post: 10-07-2011, 12:29 PM
  2. Help with 550d
    By mit2011 in forum Photography Equipment & Products
    Last Post: 03-07-2011, 12:20 PM
  3. 550D T2i vs 7D. Looking for input
    By dustin0479 in forum Photography Beginners' Forum
    Last Post: 10-13-2010, 08:10 AM
  4. 550D or 60D or 7D?
    By jcg356 in forum Photography Equipment & Products
    Last Post: 09-20-2010, 09:44 PM
  5. Is my new EOS 550D faulty?
    By Desrio in forum Photography Equipment & Products
    Last Post: 07-12-2010, 06:16 AM
5 seperate shots for hdr rebel t2i
canon 550d hdr
canon t2i hdr
canon t2i hdr mode
canon t2i hdr settings
hdr on t2i
hdr photography canon t2i
hdr t2i
