Results 16 to 30 of 43
Thread: Metering Question
03-12-2012, 03:33 PM #16TPF Junkie!
- Join Date
- Sep 2007
- Location
- Hell's Kitchen, New York
- Posts
- 3,182
- My Gallery
- (0)
- My Photos Are NOT OK to Edit
- Liked
- 403 times
03-12-2012 03:33 PM # ADS
03-12-2012, 03:34 PM #17TPF Junkie!
- Join Date
- Aug 2006
- Location
- Europe 67.51°N
- Posts
- 14,468
- My Gallery
- (0)
- Liked
- 195 times
03-12-2012, 03:54 PM #18I spend too much of my life on TPF!
- Join Date
- Nov 2010
- Location
- NJ
- Posts
- 661
- My Gallery
- (0)
- My Photos Are OK to Edit
- Liked
- 18 times
03-12-2012, 04:14 PM #19Chief Free Electron Relocator
- Join Date
- Mar 2011
- Location
- Iowa
- Posts
- 11,324
- My Gallery
- (0)
- Liked
- 2700 times
Go forth and actuate!
Your help is requested in (charitably) tossing me off the 345-foot Financial Center.
03-12-2012, 05:45 PM #20TPF Junkie!
- Join Date
- Sep 2007
- Location
- Posts
- 3,182
- My Gallery
- (0)
- Liked
- 403 times
Danny,
I'm not in a rush to get to B&H before it closes any more, so I have time to clear up any doubts you may have about being correct. The intensity of the light does fall off as you get further from the object but as you say, if the size of the image of the object remains the same, and the shutter speed and ISO also stay the same then the f-number stays the same - because the larger size of the aperture (actually the entrance pupil) exactly makes up for the fall-off in light intensity, so the total amount of light that makes up the image does stay the same. There's no need to re-meter.
Is there anything that needs clarification to persuade you that you are correct?
10' to 40' - light intensity falls off to 1/16 (I don't know why Sparky said that it was negligible - maybe he wasn't referring to the intensity);
- focal length must go up to 4x to maintain same image size;
- entrance pupil diameter must also go up 4x to keep same f-number;
- therefore entrance pupil area goes up 4^2 = 16x;
- overall amount of light that makes up the image stays the same (1/16 the intensity, 16 x the area of light collected)
- brightness of image is the same.
This all assumes that the subject illumination stays the same.
03-12-2012, 05:55 PM #21TPF Junkie!
- Join Date
- Jun 2009
- Location
- British Columbia
- Posts
- 2,635
- My Gallery
- (0)
- Liked
- 221 times
It all depends on what the light source is.
If we're talking about direct light from the sun then the inverse square law is irrelevant - 93 million miles is pretty much the same distance as 93 million miles and a few feet.
If we're talking about a light source that is at your reference point in the frame then it makes a big difference.
Of course, real life is never quite so black and white and most likely you have a mixture of light sources due to reflections etc, so the end result will be a combination.
03-12-2012, 06:14 PM #22TPF Junkie!
- Join Date
- Sep 2007
- Location
- Posts
- 3,182
- My Gallery
- (0)
- Liked
- 403 times
Not if the illumination of the subject is constant, which is what Danny asked about.
True for the illumination of the subject, but that is not what this question is about. This question is about how the subject illuminates the sensor or film, and the inverse square law does apply, no matter what the original source of the light is.If we're talking about direct light from the sun then the inverse square law is irrelevant - 93 million miles is pretty much the same distance as 93 million miles and a few feet.
See my previous comments.If we're talking about a light source that is at your reference point in the frame then it makes a big difference.
Apart from being just plain wrong in this case, I think that you are confusing things badly. This has nothing to do with the original light source as long as it is constant.Of course, real life is never quite so black and white and most likely you have a mixture of light sources due to reflections etc, so the end result will be a combination.
03-13-2012, 02:08 AM #23I spend too much of my life on TPF!
- Join Date
- Oct 2007
- Posts
- 728
- My Gallery
- (0)
- Liked
- 45 times
I think someone needs to actually DO this!
Put a flash in a softbox, set it on manual, and then go take photos of it from different distances.
03-13-2012, 05:30 AM #24TPF Junkie!
- Join Date
- Sep 2007
- Location
- Posts
- 3,182
- My Gallery
- (0)
- Liked
- 403 times
You do have to wonder 'Haven't they ever taken any pictures?' when someone says that exposure settings change as you get further away from the subject (apart from the case when the source is on the camera or similar), yet some experienced photographers get confused by this. Somehow the half-understood theory seems to blind people to the observed evidence and strange explanations flower. You can, however, often see how this sort of confusion germinated - in this case about the applicability of the inverse square law and whether or not it even occurs in some cases - and I guess that there are two ways out of the apparent paradox: either allow your curiosity to run free and increase your understanding of the theory until the theory matches the observations, or just abandon any attempt to understand the theory.
03-13-2012, 07:17 AM #25I spend too much of my life on TPF!
- Join Date
- Nov 2010
- Location
- NJ
- Posts
- 661
- My Gallery
- (0)
- Liked
- 18 times
I'm going to do this test tonight. One thing I was thinking about is that in very few situations would you actually be photographing a subject where the light source doesn't change or the subject itself doesn't move. I'm just curious about it. My nature I guess.
Thanks for all the responses on this. It's appreciated.
Danny
03-15-2012, 11:52 AM #26TPF Noob!
- Join Date
- Mar 2012
- Location
- United States
- Posts
- 12
- My Gallery
- (0)
- Liked
- 0 times
It is about reflected light. Think in terms of cones. While you are closer to your subject you are getting more light from every surface. As you move back you are able to take a proportionally less amount of space from the "cone of light" being reflected from your subject. The zoom level is irrelevant as your actual lens is further away.
03-15-2012, 12:21 PM #27TPF Junkie!
- Join Date
- Sep 2007
- Location
- Posts
- 3,182
- My Gallery
- (0)
- Liked
- 403 times
Just to clarify that: as you zoom a lens in at constant f-number, the physical size of the hole may not change, only the size of its image (ie the size of the entrance pupil) as the iris moves in relation to the front elements. The physical size may also change over part or all of the zoom range.
Is there a danger of misleading beginners in referring to the diameter of the front element when talking about the f-number equation? The front element can't be smaller than the entrance pupil, but it may be larger - much larger in some cases - and it is the diameter of the entrance pupil (which is not a physical object) that is used in the calculation of the f-number.This is why a 70-200mm f/2.8 lens is so much bigger than a 70-300 f/5.6. The front element of the 70-300mm lens only needs to be 54mm in diameter for f/5.6. But the 70-200mm lens needs a front element of 71.5mm for f/2.8. That's why it's larger.
The F-number embodies this relationship between physical focal length and physical aperture. ...
I'm just wary about these things because they can be misunderstood, and lead to confusion.Last edited by Helen B; 03-15-2012 at 02:08 PM.
03-16-2012, 08:02 AM #28I spend too much of my life on TPF!
- Join Date
- Nov 2010
- Location
- NJ
- Posts
- 661
- My Gallery
- (0)
- Liked
- 18 times
Thanks Guys! Good stuff!
03-16-2012, 09:45 AM #29Helping photographers learn to fish
- Join Date
- Apr 2009
- Location
- Iowa
- Posts
- 28,780
- My Gallery
- (1)
- Liked
- 2809 times
. . . . . . Keith . . . . . . .How Do I Use My Digital SLR?...
For Sale: Sold! Nikon SC-29 iTTL OCF flash cord w/AF Assist Illuminator
03-16-2012, 02:09 PM #30I spend too much of my life on TPF!
- Join Date
- May 2011
- Location
- elsewhere
- Posts
- 731
- My Gallery
- (6)
- Liked
- 101 times
The amount of reflected light which reaches your lens decreases the further away you are from the subject. This can be easily demonstrated by fitting a manual zoom lens and setting your camera to A priority. Choose a subject, set your aperture and make a note of the calculated shutter speed. Now zoom in and out without changing the aperture and you'll notice that the shutter speeds will be recalculated by the camera's metering system. To keep the shutter speed the same as the original setting, you have to adjust the f-stop.
Similar Threads
Metering question
By SensePhoto in forum Beyond the BasicsReplies: 5Last Post: 01-28-2011, 12:34 PM -
Metering question
By Fox Paw in forum Beyond the BasicsReplies: 6Last Post: 02-06-2009, 11:23 PM -
metering question
By myopia in forum Photography Beginners' ForumReplies: 4Last Post: 01-11-2007, 06:19 AM -
Metering question
By Johnboy2978 in forum Beyond the BasicsReplies: 2Last Post: 03-16-2006, 04:41 AM -
Metering question.
By Ghoste in forum Beyond the BasicsReplies: 7Last Post: 07-13-2005, 12:04 AM
zooming when metering a subject
5Likes
LinkBack URL
About LinkBacks
