+ Reply to Thread
Results 1 to 3 of 3
  1. #1
    Join Date
    Aug 2005
    Posts
    11
    My Gallery
    (0)
    Liked
    0 times
    Question Cheap options for quality long focus lenses
    Hi,
    I am looking for recommendations for cheaper ways to get a large quality focal length lens, say around 1000mm or more.
    I have a Nikon D70.
    I've seen two suggestions. 1 is to use a Nikon Fieldscope (800mm), which is recommended at $2289 with ED glass, with a Nikon Digital SLR Attachment. This equates to 1000mm approx. Eyepieces are attached to the fieldscope to change the zoom factor. You can go with fixed length of 20x, 40x, 60x or a zoom with 20x-45x. Has anyone used this, and what did they think? Is the quality as good as a camera lens of the same focal length. Apparently you can only focus in manual which may be a problem for me. Would an SB-800 flash reach the same length?
    The second suggestion was to attach a long focal length lens then, using a reversing ring, attach a shorter focal length lens? Does anyone have any more specific information on this idea? If I was to use a 70-300mm lens and attach a 18-70mm with the reverse ring, what this actually equate to?
    Thanks in advance
    Jason
  2. # ADS
  3. #2
    Join Date
    Jul 2003
    Kalispell, MT.
    Posts
    581
    My Gallery
    (0)
    My Photos Are OK to Edit
    Liked
    0 times
    I have done somthing like it with a point and shot and just holding the camera at the eyepiece. well I did not but one of my customers came in and we tryed it out. he was loking for a camera and did not want to spend a ton of $$$. I must say it was better then I thought it would be but I would not print or post one of the shots. it was more of a snap shot look to it.
    Once you start down the DSLR path, forever will it dominate your destiny! Consume your bank account, it will!
    40D 24-105mm, 100mm 2.8 macro, 10-22mm
    Nikkormat, N90s, D70, Rollei Magic, 28mm f2, 55mm f1.2, 50mm f1.8, 105 f1.2, 28-70mm f2.8, 70-200mm f2.8, 2X
  4. #3
    Join Date
    Jul 2005
    Garden State
    Posts
    372
    My Gallery
    (0)
    Liked
    0 times
    Cheaper way? Go eBay. You do have a Nikon which is a plus for several reasons. #1 - It is the most popular slr ever which means more used equipment on the market for a fraction of what new cost. #2 - Nikon maintains backwards compatibility which means you can use lenses on your "F" mount from as far back as 1977 on your D70.
    Your SB-800 flash is only good for a focal length of around 105mm so you will have to rethink that one. ......Good luck!
    Life is short! Take More pictures ;^)
Sponsors
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Similar Threads
  1. Focus & DOF options.
    By Ron Evers in forum Photography Beginners' Forum
    Last Post: 05-21-2010, 08:47 AM
  2. Best print options/price/quality
    By HeY iTs ScOTtY in forum General Shop Talk
    Last Post: 07-27-2009, 08:56 PM
  3. D40 Lenses Options
    By AnthonyCorbo in forum Photography Beginners' Forum
    Last Post: 12-03-2008, 06:24 PM
  4. What are my long glass options
    By tirediron in forum Beyond the Basics
    Last Post: 12-01-2008, 07:32 PM
  5. Quality printer/scanner options?
    By jrgoresko in forum Photography Equipment & Products
    Last Post: 09-18-2006, 01:08 AM
