Page 1 of 2 1 2 LastLast
Results 1 to 15 of 23
Like Tree1Likes
Thread: Expose?
  1. #1
    TPF Junkie!
    Join Date
    Aug 2011
    Malaysia
    Posts
    1,553
    My Gallery
    (0)
    My Photos Are OK to Edit
    Liked
    54 times
    Expose?
    Where should I expose for portraits? Should I expose for the shadow or highlights of the faces?
    azaleephoto likes this.
    Call me Michael.
    Nikon D5100 | AF-S Nikkor 18-55mm 1:3.5-5.6G DX | AF-S NIKKOR 55-200mm 1:4-5.6G ED DX | AF-S NIKKOR 50mm 1:1.8G
  2. # ADS
    Ads
    Google Advertisement
    Join Date
    Always
    Advertising world
    Posts
    Many
  3. #2
    Keeper of the Padlocks Site Moderator
    TPF Supporter
    Join Date
    May 2008
    UK - England
    Posts
    17,865
    My Gallery
    (0)
    Liked
    1710 times
    The "rule" I've always heard for digital is when in doubt expose for the highlights* and capture as much light data as possible. Then in editing you can pull back the exposure to the effect you want. This being better than pushing the photo up from the shadows and thus generating/revealing more noise. That's at least the basic idea of expose to the right method.
    * saying that I probably mean more expose for the brights as opposed to highlights - since things like bright eye highlights would easily have the rest of the shot very underexposed by virtue of their much brighter light - and their size makes them unnoticeable even when overexposed)
  4. #3
    TPF Junkie!
    Join Date
    Aug 2011
    Malaysia
    Posts
    1,553
    My Gallery
    (0)
    Liked
    54 times
    Quote Originally Posted by Overread View Post
    I do understand what you're trying to say. I'm already using this technique. But what I'm asking is that for the end product, which part of the face should be correctly exposed?
    Call me Michael.
  5. #4
    TPF Junkie!
    Join Date
    Nov 2008
    Posts
    1,375
    My Gallery
    (0)
    My Photos Are NOT OK to Edit
    Liked
    317 times
    Well that depends on if you want to under or over expose and if the lighting on the face is even, not to mention skin tone of the person. I use either the forehead or the cheeks with spot metering. For studio, I use a light meter.
    James
    "Photography is the art of exclusion"
    Nikon D80, D600, D7000, D800.
    Nikkor AFS 24-70mm f2.8, AFS 70-200mm VR2 f/2.8, AF 35-70mm f/2.8D, AFS 105mm VR2 f2.8 Macro, AF 10.5mm f2.8, 50mm f1.8D, 35mm f1.8G, 35mm f1.4G, 85mm f1.8G.
    SB 800's, SB 600's, YN560's, Sekonic L358, Pocket Wizard Plus III's
    , Color Checker Passport, colored gels, softboxes, shoot through umbrellas, reflective umbrellas
    All I need now is a great imagination.
  6. #5
    TPF Junkie!
    Join Date
    Aug 2011
    Malaysia
    Posts
    1,553
    My Gallery
    (0)
    Liked
    54 times
    I find that even gray cards aren't useful enough. It depends on the direction the gray card is facing. I thought of this, in low light, the highlights should be exposed, in day light, the shadows should be exposed. I'm still not sure if that would work though. I'm now struggling with selecting which part of the face to expose. I tried to expose shadows if most of the face is in shadow, and vice versa, but that didn't work. It turned out very unprofessional, because the exposure of each scene isn't the same. The easiest thing to do is to use a reflector, but that doesn't work in all conditions. Any ideas?
    Call me Michael.
  7. #6
    KmH
    KmH is offline
    Helping photographers learn to fish
    TPF Supporter
    Join Date
    Apr 2009
    Iowa
    Posts
    28,775
    My Gallery
    (1)
    Liked
    2807 times
    Caucasian skin highlights should be between 235 and 240 in the red channel.
    The darkest skin areas should be between 12 and 32. Less than 12 is under exposed.
    For people that don't have 'pink' skin it's a little different lighting wise.
    We still need the 240 in the highlights, but dark skinned people should be lit so the light reflections show the form and contours of the face, instead of using shadows to model the facial mask. A dark shadow on dark skin will not show form and contour.
  8. #7
    TPF Junkie!
    Join Date
    Aug 2011
    Malaysia
    Posts
    1,553
    My Gallery
    (0)
    Liked
    54 times
    I'm still confused. For the end product, which part of the skin should have correct brightness?
    Call me Michael.
  9. #8
    KmH
    KmH is offline
    TPF Supporter
    Join Date
    Apr 2009
    Iowa
    Posts
    28,775
    My Gallery
    (1)
    Liked
    2807 times
    THE HIGHLIGHTS & don't block the shadows unless you're going for a high degree of drama with the lighting!
  10. #9
    TPF Junkie!
    Join Date
    Aug 2011
    Malaysia
    Posts
    1,553
    My Gallery
    (0)
    Liked
    54 times
    Which means I have to find a middle point for both the highlights and the shadows. Don't seem like an easy thing to do.
    Call me Michael.
  11. #10
    TPF Junkie!
    Join Date
    Oct 2008
    Chesterfield UK
    Posts
    10,499
    My Gallery
    (0)
    Liked
    1244 times
    Quote Originally Posted by EchoingWhisper View Post
    Should be you have a Nikon
  12. #11
    TPF Junkie!
    TPF Supporter
    Join Date
    Oct 2011
    Posts
    1,708
    My Gallery
    (0)
    Liked
    253 times
    It's not lol. I drive myself nuts still. That's where spot metering comes in. I haven't tried it in the sun or with flash yet lol. I'm still trying to learn it without. I'm talking a huge difference though. Like a person with darker skin wearing a white shirt. I'll learn it though.
  13. #12
    TPF Junkie!
    Join Date
    Aug 2011
    Malaysia
    Posts
    1,553
    My Gallery
    (0)
    Liked
    54 times
    Quote Originally Posted by gsgary View Post
    lol, it's not Nikon's problem, more like my problem. I do use my friends' Canons quite often. Canon have the same problem, so most likely I'm just nitpicky.
    Call me Michael.
  14. #13
    TPF Junkie!
    Join Date
    Aug 2011
    Malaysia
    Posts
    1,553
    My Gallery
    (0)
    Liked
    54 times
    Quote Originally Posted by Mach0 View Post
    My spot meter covers too much to be useful. In many cases, it's just too large. Really hope that I could select the spot size.
    Call me Michael.
  15. #14
    TPF Junkie!
    Join Date
    Oct 2008
    Chesterfield UK
    Posts
    10,499
    My Gallery
    (0)
    Liked
    1244 times
    Not in my hands they don't
  16. #15
    TPF Junkie!
    TPF Supporter
    Join Date
    Oct 2011
    Posts
    1,708
    My Gallery
    (0)
    Liked
    253 times
    I am not sure if I'm doing it right to be honest. But I take a reading off of both and choose something in between. If highlights are still blown, then I adjust and try it again. I know it will take me a little while. I have to read up on it again. I don't know much about the zones yet but setting the camera's highlight warning helps a lot.
Ads
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Similar Threads
  1. Expose for the Sky
    By NateS in forum Graphics Programs and Photo Gallery
    Last Post: 05-26-2008, 08:15 PM
  2. Over Expose Under Develop?
    By Commonman in forum Photography Beginners' Forum
    Last Post: 10-25-2007, 11:38 AM
  3. Erase and Expose
    By PNA in forum Graphics Programs and Photo Gallery
    Last Post: 09-20-2006, 06:55 AM
  4. Expose to the Right
    By Mohain in forum Beyond the Basics
    Last Post: 02-17-2006, 10:52 AM
  5. What to neg. to expose for?
    By Solarize in forum The Darkroom
    Last Post: 05-07-2004, 10:17 AM
#exposepage
blinkies nikon d5100
blinkies on nikon d5100
expose page
exposepage twitter
how to fix blinkies on the d5100
how to fix the blinies
nikkor af-s 55mm - 200mm 1:4-5.6g ed
nikon d5100 under exposing
over expose under develop canon photo
photography expose for dark skin
