Results 1 to 14 of 14
08-02-2012, 12:09 PM #1
Should I change Exposure when using a 2x Tele Converter
Hi
I have an old Minolta SRT-100b film camera and a f3.8 70-150mm Vivitar lens, I also have a 2x Tele Converter. The built in through the lens light meter no longer works so I need to use a hand held light meter.
I know that using the 2x Tele Converter will affect light to the camera but I don't know by how much, or how to compensate.
I have been told that it will affect it by 2 stops, so as long as I don't use the first to stops on the lens then the picture will be exposed correctly. So I don't need to compensate at all apart from not using the first two stops, is this true?
Thanks,
Ben
08-02-2012 12:09 PM # ADS
08-02-2012, 12:20 PM #2Bug Junkie
- Join Date
- Aug 2011
- Location
- Arvada Co
- Posts
- 14,429
- My Gallery
- (0)
- My Photos Are OK to Edit
- Liked
- 3438 times
A 2x TC can kill anywhere from 2 to 3 stops of light, on average. Try adding one, two and three stops of light... same subject same light, and see what you think when they are developed. Looks at the density / exposure of the film, rather than a print...
I'm Charlie! Who are you?
Nikon D800 / D7000, R1C1 Macro Flash, SB-900 x2, 14-24 2.8, 24-70 2.8, 70-200 2.8, 85 1.4, 50 1.4, 105 2.8 macro, TC20E 2x TC / TC14E 1.4x TC, Monolights, Pocket Wizards, etc.....
Flickr Images
500px Images
08-02-2012, 12:33 PM #3TPF Junkie!
- Join Date
- May 2012
- Location
- Virginia
- Posts
- 3,590
- My Gallery
- (10)
- Liked
- 1107 times
Essentially what a 2x teleconverter is doing is making your lens twice as long, right? But it generally doesn't do anything to the aperture blades, so the size of the opening is remaining the same. Given that aperture is focal length divided by the diameter of the aperture, your actual aperture expressed will be twice as big as indicated.
Say you have a 200mm lens, set to f/5.6. The actual diameter of the aperture opening is: 35.7mm (200mm / 35.7 = 5.6).
Now add on a 2x teleconverter. The lens is now 400mm long. The aperture, set to the 5.6 reading on the lens, is still 35.7mm across, right?
400mm/35.7 = 11.2
So mathematically it's two stops, exactly as Charlie indicated, and I'm pretty sure that there are some other losses that can occur in a TC so 2-3 stops in the right number, for sure.
Now you should be able to do it for a 1.4x TC or anything!Blogging about photography: Photos and Stuff. No pictures there, just writing. For pictures, see my Gallery link here.
Gear: Gripped Sinar F1, Vivitar 285HV on a Manfrotto rail, and a bunch of lens caps epoxied into a ball.
08-02-2012, 01:50 PM #4
08-02-2012, 01:58 PM #5Bug Junkie
- Join Date
- Aug 2011
- Location
- Arvada Co
- Posts
- 14,429
- My Gallery
- (0)
- Liked
- 3438 times
Does your hand held light meter know about the TC???? If not, there is no way it would automatically adjust for it right? You need to overexpose two stops based on what the meter is telling you. That should put you in the ball park! The TC would cause you to be two stops underexposed (approximately)... so you need to correct for it.
Flickr Images
500px Images
08-02-2012, 01:58 PM #6Bug Junkie
- Join Date
- Aug 2011
- Location
- Arvada Co
- Posts
- 14,429
- My Gallery
- (0)
- Liked
- 3438 times
Flickr Images
500px Images
08-02-2012, 02:02 PM #7
Can the EV compensation on the meter do this for me? ie. is changing the compensation to +2 EV the same as overexposing two stops? (or should that be -2?)
08-02-2012, 02:04 PM #8Bug Junkie
- Join Date
- Aug 2011
- Location
- Arvada Co
- Posts
- 14,429
- My Gallery
- (0)
- Liked
- 3438 times
Flickr Images
500px Images
08-02-2012, 02:07 PM #9Helping photographers learn to fish
- Join Date
- Apr 2009
- Location
- Iowa
- Posts
- 28,775
- My Gallery
- (1)
- Liked
- 2807 times
Yes, in so far that 1 EV = 1 stop.
. . . . . . Keith . . . . . . .How Do I Use My Digital SLR?...
For Sale: Sold! Nikon SC-29 iTTL OCF flash cord w/AF Assist Illuminator
08-02-2012, 02:09 PM #10I spend too much of my life on TPF!
- Join Date
- Jan 2012
- Location
- Buffalo, NY
- Posts
- 793
- My Gallery
- (0)
- Liked
- 110 times
What I would like to know is where to learn this type of information. Is there a reference book or an online website. I can tell you I don't believe it's in the owners manual for the d7k.
Originally Posted by amolitor
John
I'm gone from TPF for the majority of the summer.
<work> <ugh!>
Me on flickr
One of my attempts at a timelapse(mediocre)
08-02-2012, 02:13 PM #11TPF Junkie!
- Join Date
- May 2012
- Location
- Virginia
- Posts
- 3,590
- My Gallery
- (10)
- Liked
- 1107 times
benjj6, you should set the entire lens assembly to f/11 in that case.
The reading ON the lens will read f/5.6 at that point. When you've got the lens itself set to one f-number, the whole lens setup is ACTUALLY at twice that number.
Your meter tells you what ACTUAL f-number you should be using with your shutter speed and ISO. So set the lens+TC setup so that it's ACTUAL number is f/11, which means that the reading on the lens itself has to be 5.6.
Does that make any sense?Blogging about photography: Photos and Stuff. No pictures there, just writing. For pictures, see my Gallery link here.
08-02-2012, 03:21 PM #12
I did a quick test to see if this worked, so I took a reading and then set my light meter compensation to +2 and measured the same spot, given that the shutter speed and ISO were the same the aperture changed from f/5.6 to f/11 when EV was set to +2. This has confused me since you said that I need to overexpose by two stops to compensate, but if +2 EV is causing the aperture to change from 5.6 to 11 then that seems to be underexposing the picture by 2 stops, am I right?
08-02-2012, 05:40 PM #13
08-02-2012, 06:17 PM #14TPF Junkie!
- Join Date
- Sep 2007
- Location
- Hell's Kitchen, New York
- Posts
- 3,182
- My Gallery
- (0)
- My Photos Are NOT OK to Edit
- Liked
- 403 times
You seem to have got it, though it isn't really 'overexposure'. As amolitor explained, the f-number marked on the lens is no longer correct when a TC is placed behind the lens (it can be correct for TCs designed to go in front of the lens). Just as the focal length is changed (in this case doubled), so is the f-number. Double the focal length marked on the lens, double the f-number marked on the lens.
Once you understand that f-number = focal length/diameter of the entrance pupil* it all falls into place logically. A TC placed behind the lens cannot affect the diameter of the entrance pupil. A TC placed in front of the lens can alter the diameter of the entrance pupil.
*The entrance pupil is the hole in the aperture blades that you see when you look into the lens - ie it is the image of the aperture blades as formed by the lens elements in front of the aperture.
Similar Threads
Canon EOS Auto Focus C-AF 1.4x Tele-Converter Tele-Extender
By Link Delight Online Shop in forum Linkdelight Photography AccessoriesReplies: 0Last Post: 06-10-2011, 01:33 AM -
Tele Extender vs. Tele Converter
By CaptainJackOC in forum Photography Equipment & ProductsReplies: 2Last Post: 06-30-2010, 08:05 AM -
Tele-extender / tele-converter tips
By tacomadm18 in forum Beyond the BasicsReplies: 6Last Post: 05-04-2010, 10:57 AM -
Which Tele-Converter??
By Sinister_kid in forum Photography Equipment & ProductsReplies: 7Last Post: 10-23-2009, 01:05 PM -
Tele Converter - Is this possible?
By 250Gimp in forum Beyond the BasicsReplies: 6Last Post: 04-30-2008, 07:52 PM
2x lens converter compensation
,adjust flash for 2x converter
,appateur and exposure with 2x convertors
,camera overexposes using 2x extender
,decreasing light exposure with 2x extender
,f stop change with 2x tele extender
,how does using a 2x converter change my camera settings
,how to expose when using tele extenders
,how to set aperture using a teleconverter
,light meter tele converter 2x
,needing to adjust exposure with teleconverter
,photos taken with minolta srt with teleconverter
,what does a 2x converter do to exposure?
,what settings shoul i use with a 2x teleconvertor?
,what speed should i use with a 2x convertor/?
LinkBack URL
About LinkBacks
