Results 1 to 6 of 6
  1. #1
    Join Date
    Sep 2011
    Malta
    Posts
    15
    My Gallery
    (0)
    My Photos Are OK to Edit
    Liked
    0 times
    AstroPhotography - Milkyway?
    Yesterday i tried shooting some pics of the milky way but the best i got was this.
    Milkyway | Flickr - Photo Sharing!
    I used a canon 550d with stock lens 18-55mm. This pic was taken at around 20 seconds exposure time , f3.5 with an iso of 1600 .
    Is there a way to get more details?
    Thanks
  2. #2
    Join Date
    Dec 2011
    South Africa
    Posts
    181
    My Gallery
    (0)
    Liked
    50 times
    I found a really great site that has some great tutorials on astro photography:
    How to Photograph the Milky Way the Easy Way
    They've got some very useful and easy to follow information
  3. #3
    KmH
    KmH is offline
    Helping photographers learn to fish
    TPF Supporter
    Join Date
    Apr 2009
    Iowa
    Posts
    33,550
    My Gallery
    (1)
    Liked
    3913 times
    Yes, by lowering the ISO, making multiple exposures, and then stacking them. http://keithwiley.com/astroPhotograp...Stacking.shtml
    http://www.instructables.com/id/Astr...hoto-Stacking/
    A dark site (less light pollution) would also help.
    . . . . . . Keith . . . . . . .How Do I Use My Digital SLR?...
    Effort equals results - Roger Penske
  4. #4
    TPF Junkie!
    Join Date
    Jul 2010
    Canada
    Posts
    4,588
    My Gallery
    (0)
    Liked
    2054 times
    Between you and the stars, is a lot of air. Good thing for us, otherwise we wouldn't be here to admire the stars. But the air has stuff in it (clouds, dust, various aerosols), and varying density, which tends to distort the light we do see, and reflect light from the ground and the moon, causing the apparent sky background to be much brighter than it would be if we were in space. So the first lesson in taking sky pictures at night, is to find a location which is as free from light pollution, and as high above the bulk of the atmosphere, as possible - that's why all the major telescopes are found in remote areas on top of high mountains, in locations where the air flow is "smooth". Now, if your ancestors did not have the presence of mind to choose to live in such an area, you'll just have to find the darkest spot within reasonable distance from where you live.
    Next, it helps to NOT have the moon shining brightly - all that light bounces off the dust in the air and reduces the sky contrast. So shooting when the moon is close to new would be good.
    Next, you deal with the earth's rotation, that makes the stars move in the sky. Earth moves at 15 arc-seconds each minute. If you are using a stationary tripod, depending on the focal length you use and the crop factor, this means that you can record about 1 minute with a 24mm lens on a crop camera, and less than 10 seconds with a 200mm before the stars start to trail. If you have a way of countering the rotation of the earth, say with an equatorial drive, then you can expose for many minutes without worrying about stars trailing.
    Assuming you don't have access to an equatorial drive, the way to get good images is to have relatively short exposures, which are then stacked, as Keith (KmH) noted above. The stacking is a well-known technique which allows the random noise to be reduced, and the signal to be amplified.
    Try using ISO 800, the widest aperture you have on your lens, the shortest focal length, and a shutter speed of about 20 seconds. Take a shot, then check the image, blowing it up to see if any images are trailing. If so, reduce your shutter speed. Once you have a good shutter speed, take a series of 10-30 frames, import them into the computer, and do some preliminary processing on them. If your software has the sliders for dark point, light point, and mid-point, move the midpoint over towards the dark point, which effectively boosts the background to lighter values. Stop before the noise becomes very visible. Once you have this setting, repeat the exact same setting for the rest of the frames. Now import them into the stacking software and register them. Depending on the software, you may have a variety of options to help you carry out this registration/stacking exercise. At the end, you should have a much better result than if you had only the individual frames.
    Photographic bon-mot:
    Put the important things in important places
    Compose to minimize dead space and things that distract from the center of interest - the important things
    Process to minimize faults and maximize good points.
    by Lew Lorton, aka The_Traveller.
    My (non-photographic) work: http://consulting.prsroofing.ca
  5. #5
    Join Date
    Nov 2010
    Posts
    845
    My Gallery
    (0)
    Liked
    72 times
    Cameras - Canon 350D, 5D
    Lenses - Canon 18-55mm, 75-300mm, 50mm f/1.8, 24-105L, 24-70L
    Flashes - Canon 430EX II, Yongnuo YN460 II, YN468
    RF-602 transmitter and 2 receivers
  6. #6
    Join Date
    Nov 2011
    Norman, OK
    Posts
    82
    My Gallery
    (0)
    Liked
    10 times
    Great sharing edsport, I basically loved that article/post!
    Stian Ulriksen | www.stianulriksen.com | 500px.com | flickr
    Camera: Canon EOS 5D Mark II
    Lenses: Canon EF 50mm f/1.4 USM + Canon EF 24-105mm f/4 L IS USM
Ads
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Similar Threads
  1. astrophotography
    By rdking647 in forum General Gallery
    Last Post: 04-04-2011, 07:12 PM
  2. astrophotography
    Last Post: 03-26-2011, 12:18 AM
  3. Milkyway
    By Badebolden in forum General Gallery
    Last Post: 09-20-2010, 01:12 PM
  4. [GORIO] - CASARORO MILKYWAY
    By gregie27 in forum Landscape & Cityscape
    Last Post: 12-10-2009, 05:19 PM
  5. Milkyway
    By Sky of the Plains in forum Nature & Wildlife
    Last Post: 10-02-2008, 08:01 PM
18-55mm milky way
astro settings with a 55mm lens
astrophotography milky way
canon 18-55mm milky way
f3.5 18mm milky way
how to take milky way photo sharing
milky way astrophotography
milky way with 18-55mm
Tags for this Thread
