+ Reply to Thread
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 16
  1. #1
    Join Date
    Jul 2005
    Ontario
    Posts
    22
    My Gallery
    (0)
    Liked
    0 times
    color vision monitor calibration.
    I was looking for something rather inexpensive to calibrate my monitor so I could start printing some of my work. I came across a colorvision product for 89$ american and was wondering if anyone had experiance with this particular model or knows someone who has, and what they thought about it ?
    Any help would be greatly appreciated and here is the link http://www.colorvision.com/profis/pr...iew.jsp?id=281
    "People say photographs don't lie, mine do" - David Lachapelle.
    www.mattfox.blogspot.com
  2. # ADS
  3. #2
    TPF Junkie!
    Join Date
    Nov 2004
    Where am I now?
    Posts
    16,725
    My Gallery
    (2)
    Liked
    0 times
    You need to calibrate your monitor and your printer. If you don't, what you get won't look like it does on the screen.
    Don't just say nothing - say 'bokeh'!
  4. #3
    Join Date
    Nov 2005
    new jersey
    Posts
    35
    My Gallery
    (0)
    Liked
    0 times
  5. #4
    Join Date
    Oct 2005
    Posts
    314
    My Gallery
    (0)
    My Photos Are NOT OK to Edit
    Liked
    0 times
    I have the Spyder 2 Plus from ColorVision, it will create printer profiles in addition to calibrating your monitor. It did wonders for both the way my monitor looks and how my prints match my screen. It's a bit more, though, $250.
    You'll need a scanner to do the printer profile, though.
  6. #5
    Just Punked Himself
    Join Date
    May 2004
    England! w000t!
    Posts
    5,313
    My Gallery
    (0)
    Liked
    0 times
    Is there any free way to do this?
    I like to comply with TPF rules!
  7. #6
    TPF Supporter
    Join Date
    Jun 2005
    Irvine, Orange County, CA
    Posts
    349
    My Gallery
    (0)
    My Photos Are OK to Edit
    Liked
    0 times
    What if you tend to print your stuff out at photolabs? I often use costco or target (both have given me great prints). Do I need to do something other then calibrate my monitor?
  8. #7
    Join Date
    Jul 2005
    Ontario
    Posts
    22
    My Gallery
    (0)
    Liked
    0 times
    I planned on calibrating my monitor so that I could then print it at a pro lab. With the same colour space, and its a pro lab so Im sure they have RGB colour setting or the proper colour ?
  9. #8
    TPF Junkie!
    Join Date
    Nov 2004
    Where am I now?
    Posts
    16,725
    My Gallery
    (2)
    Liked
    0 times
    You should still see about calibrating your printer so you can do proofs.
    RGB colour is for monitors.
    When printing you use CMYK.
    But if you are going to be using a lab then try talking to them to see what they recommend. You want your monitor to match their output.
  10. #9
    Join Date
    Jul 2005
    Ontario
    Posts
    22
    My Gallery
    (0)
    Liked
    0 times
    excellent, thank you !!
    this product seems like it will do the trick, you can do any LCD correct ?
  11. #10
    Join Date
    Oct 2005
    Posts
    314
    My Gallery
    (0)
    Liked
    0 times
    Quote Originally Posted by foxXx
    Do you mean the Spyder 2? Yes, that does LCD.
  12. #11
    alter ego: Analog Matt
    Join Date
    Jan 2004
    Santa Barbara, CA
    Posts
    5,346
    My Gallery
    (0)
    Liked
    0 times
    Check out the Monaco Optix.
    http://www.xritephoto.com/
  13. #12
    ort
    ort is offline
    Join Date
    Dec 2005
    Austin
    Posts
    15
    My Gallery
    (0)
    Liked
    0 times
    The spyder is good but LCD's are very consistant. Normally if you assign the graphic card and the OS the monitors canned profile, then you'll see little change after running the spyder, (or the Monico). My printers are epsons and the P.I.M.II is dead on to what my monitor displays. Don't be cheap! Use the inks and paper recomended by the printer and you can save money on a reflective scanner.
  14. #13
    Join Date
    Oct 2005
    Posts
    314
    My Gallery
    (0)
    Liked
    0 times
    Quote Originally Posted by ort
    I saw a major change after running the Spyder on both my LCD and my sister's laptop.
  15. #14
    TPF Junkie!
    Join Date
    Nov 2005
    Hemel, UK!
    Posts
    3,383
    My Gallery
    (0)
    Liked
    0 times
    spyder is the best out there i bleive it hasnt got anything less than 4 and 1/2 stars...
  16. #15
    ort
    ort is offline
    Join Date
    Dec 2005
    Austin
    Posts
    15
    My Gallery
    (0)
    Liked
    0 times
    Quote Originally Posted by dsp921
    There are many varables involved. I was saying that after I downloaded the canned profile for my LCD. assigned it to the OS and then to the graphics card and then ran the Spyder, I saw little or no difference. If the graphics card has not been assigned the profile or if you create a profile from a profile then yes, major changes can be seen. If a generic profile is used then a change can be seen. Most people forget their graphic cards. I do use my spyder as I require presion in my prints. The difference I get is neutral gray drops from 20% to 18%. Not much if your posting to the web but critical if your work is going to be published on newsprint
    Far better results can be obtained by not playing the profile game in the first place. Everytime you convert the profile, the gamet is altered and can never be reclaimed. I will use PS as my example. Digital cameras shoot and assigns a profile to the image. PS offeres to convert this profile to the current workspace,(don't do it). The monitor has a profile and this doesn't convert the image's profile but if the monitors profile isn't the same as the images then what you see on the monitor is not the images profile, thus it isn't correct. PS will then convert the profile to the printers profile and if your printers not set to ICM then the printer converts the profile too.
    For consistant results, Download the LCD's profile, assign it to the OS and the Graphis card. Run the spider. It will assign the profile to the OS but most of the time, you will need to assign the new profile to the graphics card. If your camera has the ability to use different profiles the choose the one with the widest gamet and assign this to PS as the workspace. The printer is always a problem but if you use the same profile accross the workflow then your results will be easier to reproduce.
Sponsors
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Similar Threads
  1. monitor calibration
    By MACollum in forum Photography Equipment & Products
    Last Post: 05-23-2008, 04:36 PM
  2. Monitor calibration ???
    By Evo in forum Digital Discussion & Q&A
    Last Post: 04-26-2008, 11:34 PM
  3. monitor calibration
    By bill04 in forum Photography Equipment & Products
    Last Post: 04-13-2008, 07:02 AM
  4. Monitor Calibration SW
    By cumi in forum Beyond the Basics
    Last Post: 01-25-2006, 09:13 AM
  5. Monitor calibration for MAC
    By mygrain in forum Graphics Programs and Photo Gallery
    Last Post: 10-30-2004, 01:55 PM
color visior monitor
colour vision print calibrator
using colour vision to calibrate monitor
