+ Reply to Thread
Results 1 to 8 of 8
  1. #1
    Join Date
    Jan 2006
    Kent, UK
    Posts
    24
    My Gallery
    (0)
    Liked
    0 times
    Best Film for low light conditions
    I recently took some pictures of a friends birthday. I used a 400ISO and a 200ISO as an experiment. To my horror neither (except a few from the 400) came out to well!
    So my question which I hope people can help me with is this.
    Obviously the higher the ISO to more sensitive to light, does this mean that if I used a higher ISO film in this restaurent at the same shutter speeds I was using the picture is more likely to come to something? In other words, whats the best film for low light conditions!!!
    J
  2. # ADS
  3. #2
    TPF Junkie!
    Join Date
    Mar 2004
    Rochester, NY Velocity: Unknown
    Posts
    4,237
    My Gallery
    (0)
    My Photos Are NOT OK to Edit
    Liked
    0 times
    If you are using flash it won't matter much. If you are using available light, a faster speed film will be more grainy, but it will allow you to use a faster shutter speed. This will stop motion. If you aren't getting motion blur, a faster film won't do anything for you.
    Can you post an example of what you shot?
    Any advice given in the above post comes from a deranged madman. Implement at your own risk.
    My photography: www.markcarpenter.com
    “In the fields of observation, chance favors only the prepared mind." - Louis Pasteur
  4. #3
    Join Date
    Jan 2006
    Kent, UK
    Posts
    24
    My Gallery
    (0)
    Liked
    0 times
    Quote Originally Posted by markc
    Nope none of them came out to well, 10 out of 24 exp and even then there naff! won't scan to well!! It was my fault mainly because i slowed the shutter speed down some but got to much motion (hard to keep people still you see!) Thing is I went to try to get some film but both local chemist and photoshop didn't have any (which I found strange) where would i get some??
    J
  5. #4
    Rob
    Rob is offline
    TPF Junkie!
    Join Date
    Jan 2005
    London
    Posts
    6,217
    My Gallery
    (16)
    Liked
    1 times
    Where in Kent are you? Snappy Snaps is pretty good for film, there should be one in your local town.
    Shooting indoors in a restaurant without flash is going to require a bright lens like a 50mm f1.8. If you're shooting on a high f-number zoom, you're going to have problems with any "normal" ISO - e.g. 100-400.
    What camera and lens are you using, and do you have a flash?
    Rob
  6. #5
    Join Date
    Jan 2006
    Kent, UK
    Posts
    24
    My Gallery
    (0)
    Liked
    0 times
    Quote Originally Posted by Rob
    Rob
    In Maidstone, will have a look for Snappy Snaps, never heard of them but could be good!
    I was using a Canon EOS lens 28-105mm that came with the Canon EOS300V I use. I did use a flash for some pictures but I wanted to try and capture the mood of the evening as the lighting in the restaurent, while low, was good against the table giving it that very "Godfather" kinda look!
  7. #6
    Rob
    Rob is offline
    TPF Junkie!
    Join Date
    Jan 2005
    London
    Posts
    6,217
    My Gallery
    (16)
    Liked
    1 times
    Quote Originally Posted by JayP
    http://www.google.co.uk/local?hl=en&...45996436917035
    Ok, you've got a couple of options, get yourself a standard f1.8 50mm lens (about £90), or up the ISO on the film. To shoot in a low lighting situation, you're going to need to get well above 400 ISO with your current lens.
    Rob
  8. #7
    Join Date
    Oct 2005
    MA and CO
    Posts
    920
    My Gallery
    (0)
    Liked
    0 times
    buy a faster lens (primes are faster than zooms) something like a 50mm f/1.8 or 1.4.
    or try pushing your 400 film to 1600iso .
    or try using 3200 film.
    or use a tripod.
    Signature.
  9. #8
    TPF Junkie!
    Join Date
    Jan 2006
    Tottenville, Staten Island, NYC USA
    Posts
    2,014
    My Gallery
    (0)
    My Photos Are OK to Edit
    Liked
    0 times
    The use of an f1.4 to f2.0 lens is almost mandatory for shots such as you describe. In addition, think a lot about how you can prop the camera to allow slower shutter speeds. Kodak ASA 400 films in either color or B&W will not be too grainy if not push-processed or overly enlarged. At wide open, focus becomes an important issue, too.
Sponsors
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Similar Threads
  1. Focusing in low light conditions
    By Bluepoole in forum Photography Beginners' Forum
    Last Post: 12-01-2009, 01:23 AM
  2. Low Light Conditions
    By Commonman in forum Digital Discussion & Q&A
    Last Post: 06-11-2008, 10:04 PM
  3. shooting action seq. in low light conditions?
    By indyrodeo9 in forum Beyond the Basics
    Last Post: 02-11-2008, 09:27 AM
  4. Shooting a concert in low light conditions
    By m0r in forum Beyond the Basics
    Last Post: 06-20-2007, 12:26 PM
  5. Film types for bright conditions
    By doug1987 in forum Film Discussion and Q & A
    Last Post: 07-03-2006, 07:15 AM
400 film best for what light?
best black and white film for low light
best film for low light situations
best film for what conditions
best film to push in low light conditions
best iso film for low light
best kind of film for low light
best light conditions for 400 film
best low light film
best speed film for low light situations
what film does best in low light
what is the best film for low light
what is the best film for low light photogaphy
