Results 1 to 3 of 3
  1. #1
    Join Date
    Dec 2006
    Wisconsin
    Posts
    559
    My Gallery
    (0)
    My Photos Are NOT OK to Edit
    Liked
    4 times
    Battery Checker? For Canon BP-511 and Others
    From B&H Photo:
    The Impact Lithium-Ion Battery Tester, #EC7466 is a neat little accessory to stash in your gear bag, luggage or pocket. This little beauty is like having a battery "doctor" with you all the time.
    Using its fuel gauges, it will conveniently let you know the status of your lithium-ion batteries. It's like having an extra pair of eyes to watch out for your "charge" while you concentrate on shooting.
    • Canon BP-2L12/2L 14
    • Canon BP-511/511A/512/522/535
    • Canon NB-2L/2LH
    • Nikon EN-EL1
    • Nikon EN-EL3/EL3a/EL3e
    • Panasonic CGA-S303E, VW-VBE10
    Just insert your battery into this tester slot, the LEDs on this tester will automatically light up to indicate the power remaining in your battery
    4-Level LED Fuel Gauge
    Battery has 75-100% of power remaining
    Battery has 51-75% of power remaining
    Battery has 26-50% of power remaining
    Battery has 5-25% of power remaining
    Battery has less than 5% of power remaining
    Here's the question. If I have one of these, and I'd like someone who owns one or has experience, and I have six batteries (numbered by the way) and I want to know which are the good batteries and which are going to hold a short charge...
    Does this tester just show "full charge" and then after 9 photos the battery goes dead, or does it show the capacity of the battery?
    I have two new batteries and four older ones, and I'd like to rate them so I can match the second best pair for the grip.
  2. # ADS
    Ads
    Google Advertisement
    Join Date
    Always
    Advertising world
    Posts
    Many
  3. #2
    TPF Junkie!
    Join Date
    Oct 2003
    Brisbane, Australia
    Posts
    9,640
    My Gallery
    (0)
    Liked
    191 times
    Does your camera do this in software by any chance? The D200 and D80s have a tool under the maintenance menu which allows you to check the life of the battery and it gives you an indication if it is time to get them replaced or not.
    In my experience LI batteries make themselves known if they are bad. It's the difference between 500+ photos and only 20 or so. My guess would be if you can make a >15 minute exposure on the fully charged batteries they are fine.
    "I am always satisfied with the best." -Oscar Wilde
    Larger versions always on flickr
    Best photos in my gallery
    Proud Supporter of The Pact
  4. #3
    Join Date
    Dec 2006
    Wisconsin
    Posts
    559
    My Gallery
    (0)
    Liked
    4 times
    Sorry I was out of town, then working and crashing.
    The good or bad, with no in between sounds like what I've had happen. I didn't know that LI batteries went from good to junk like that. Thanks.
    Yes I have some that will go about 200 pictures, one that seems to be good for 9 and another that may take 50, or less. That's why I was looking for some battery life tester. I suppose someone with a a Canon EOS might know, or I can go search for a long time. (or read the manual?)
    But if the tester shows battery life, then I'll order one with my next B&H order. I was hoping someone had one of these or at least knew about them.
    Quote Originally Posted by Garbz View Post
Ads
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Similar Threads
  1. Replies: 5
    Last Post: 08-24-2010, 07:18 PM
  2. Canon 1000D LCD Battery Grip +2x LP-E5 Battery
    By Link Delight Online Shop in forum Linkdelight Photography Accessories
    Last Post: 08-08-2010, 08:45 PM
  3. Canon 580EX II Flash Battery Pack w/ 6 x AA Battery
    Last Post: 06-16-2010, 07:32 PM
  4. Replies: 0
    Last Post: 05-27-2010, 07:19 AM
  5. Replies: 5
    Last Post: 01-26-2010, 09:12 PM
bp511 bad battery life
canon battery bp-511 how to test
canon battery date code
canon battery date codes
canon battery date from code
canon battery tester
canon bp-511 not holding a charge/
canon bp511a battery tester
how to check canon bp511
how to read date code of canon batteries
how to test bp-511
how to test bp-511a battery charge
how to test canon bp511
test bp-511
testing bp-511a
