Results 1 to 5 of 5
  1. #1
    Join Date
    May 2012
    Cape Girardeau
    Posts
    18
    My Gallery
    (0)
    My Photos Are OK to Edit
    Liked
    0 times
    Neutral Density Filter for EF 50mm f1.4 USM lens
    Sometimes I find my pictures are over exposed by bright sunlight, when I shoot in small f stops. Will a ND filter solve this problem? Thanks in advance.
  2. # ADS
    Ads
    Google Advertisement
    Join Date
    Always
    Advertising world
    Posts
    Many
  3. #2
    TPF Junkie!
    Join Date
    Oct 2008
    Chesterfield UK
    Posts
    10,494
    My Gallery
    (0)
    Liked
    1243 times
    Quote Originally Posted by toughsamurai View Post
    Only if your camera does not have a fast enough shutter speed to compensate
  4. #3
    TPF Junkie!
    Join Date
    Mar 2012
    Dearborn, MI
    Posts
    1,235
    My Gallery
    (0)
    Liked
    499 times
    In bright sunlight, drop the ISO back to 100, then pick a shutter speed & f-stop combination that yield a proper exposure (e.g. f/16 & 1/100th... or f/2.8 and 1/2000th, etc.)
    A neutral density filter allows you to change your shooting conditions. Suppose you want a very slow shutter speed to deliberately blur and "imply motion" in your images... and even at ISO 100 and f/22, the slowest you can shoot is 1/50th is still too fast. You could use a ND filters to drop the light down enough use a slow shutter.
    Tim Campbell
  5. #4
    Join Date
    Jul 2010
    MCB Quantico
    Posts
    864
    My Gallery
    (0)
    Liked
    68 times
    Yes, a 2 or 3 stop ND filter will allow you to shoot at f/1.4 in bright sunlight without going over the maximum shutter speed of your camera (which should be 1/8000s).
    Sent from my Transformer Prime TF201
    Canon EOS 5D Mark III with BG-E11 Grip | EF 17-40mm f/4L USM | EF 70-200mm f/2.8L IS II USM | Speedlite 580EX II | Extender EF 2x III
    flickr
    and My Portfolio on 500px
  6. #5
    Join Date
    May 2012
    Cape Girardeau
    Posts
    18
    My Gallery
    (0)
    Liked
    0 times
    Thank you very much for your suggetions.
Ads
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Similar Threads
  1. (52~77) mm Lens Neutral Density ND2/ ND4 / ND8 Resin Filter
    By Link Delight Online Shop in forum Linkdelight Photography Accessories
    Last Post: 01-26-2011, 07:21 PM
  2. (52~77) mm Lens Neutral Density ND4 Resin Filter
    Last Post: 11-29-2010, 07:01 PM
  3. (52~77) mm Lens Neutral Density ND2 Resin Filter
    Last Post: 11-29-2010, 06:58 PM
  4. (52~77) mm Lens Neutral Density ND8 Resin Filter
    Last Post: 11-25-2010, 06:42 PM
b800 50mm 1.4 nd filter
canon 50mm 1.4 nd filter
canon 50mm f1.4 neutral density filters
f1.4 what nd filter to use
nd filter canon 50mm 1.4
nd filter for 50mm 1.4
nd filter for canon 50mm 1.4
nd filter for canon 50mm f1.4
nd filter for f1.4 lens
nd filter on f1.4 lens
nd filters for canon 50mm 1.4
neutral density filter 50mm
neutral density filter 50mm lens
neutral density filter for canon 50mm 1.4
zeiss 50mm 1.4 nd filter
