Help with Kodak Anaston shutter disassembly
This is a discussion on Help with Kodak Anaston shutter disassembly within the Collector's Corner forums, part of the Film Photography category; So I bought a cheapie Kodak Tourist for $6. I was trying to disassemble it to clean it thoroughly. The problem arose while trying to ...
Go Back   The Photo Forum - Photography Discussion Forum > Film Photography > Collector's Corner
Collector's Corner A place to discuss the collection of classic cameras and related equipment.
Reply
LinkBack Thread Tools Display Modes
Old 11-18-2009, 08:15 AM   #1
My Photos Are NOT OK to Edit
My Gallery: (0)
So I bought a cheapie Kodak Tourist for $6. I was trying to disassemble it to clean it thoroughly. The problem arose while trying to remove the shutter mechanism. Where does it fall? Not on the soft carpet. Not on my soft bed. No. Onto the small 5-inch wide section between the two that's just hardwood floor. Now the shutter is jammed. Sad day!
Anyone know how to disassemble this? All the other shutters I've looked at have three screws in the front. This one has none, which has me very lost.
Here's a reference picture so you can see what the shutter mechanism looks like:
If I can't get it fixed, then no biggie. I paid only $6 for the camera after all.
Cojaro is offline   Reply With Quote
Sponsored Links
ThePhotoForum.com is the premier Photography Forum & Digital Camera Resource! Registered Users do not see the above ads. Please Register - It's Free!
Old 11-18-2009, 05:47 PM   #2
Dwig's Avatar
My Gallery: (10)
Preface:
1. This is not an "Anaston" shutter. Anaston is the lens type. The shutter is a "Flash Kodamatic"
2. Its been 47 years since I've disassembled and repaired one of these. It was the first shutter I repaired. It was also jammed as the result of being dropped.
That said, if memory serves you need to first remove the font lens cell. This requires that you remove the infinity stop (the pin on the lens cell probably unscrews) and carefully unscrew the front focusing portion of the lens. Take very careful note of where the infinity mark is when the lens separates from the shutter. There may be more than one lead in the thread and if so you must start at the right position to get the lens back in place.
Once the lens is removed it should expose a ring nut surrounding the center of the shutter opening. There may be a stop screw preventing it from turning that must be removed. Simply unscrew this ring and you can then remove the flat plate that has the shutter speed and f/stop markings. Be careful to hold the outer shutter speed ring in place. This ring will have several slotted cams that affect the engagement of the various escapements in the shutter. This can be lifted off carefully, though its best done at a shutter speed that places as many of the escapements in their most relaxed position.
You should now have full access to the internal workings of the shutter. If you know your way around other leaf shutters you should have no real difficulty with this one.
__________________
Dwig
happythursday.com
Dwig is offline   Reply With Quote
Old 11-18-2009, 05:59 PM   #3
TPF Junkie!
Derrel's Avatar
My Photos Are OK to Edit
My Gallery: (7)
For a bit more info, you might check these links.
The Classic Camera Repair Forum: Kodamatic Cleaning & Happy Halloween to All
Here is Dan Mitchell's page on old camera repair--you might be able to pick some tips up there.
Camera Collecting and Restoration
years ago, my brother bought a Kodak 35 RF shown in one of Dan's articles,and he payed $7 for the camera. I ended up disassembling that camera's shutter when I was about 12 years old....it didn't go well.
Shutter Repair Manuals
Here you can buy a 56 page manual devoted to this type of shutter, for $20.
Derrel is offline   Reply With Quote
Old 11-18-2009, 06:34 PM   #4
My Gallery: (0)
Quote: Originally Posted by Dwig View Post
Preface:
I've got the focus lens off, but I'm at another standstill. The pin that stops the infinity focus (or whatever it's called. The pin right below the "25" second shutter speed mark) won't come out. I suppose that's the stop screw you mentioned. I've unscrewed it, but it doesn't want to come out. There seems to be a small washer on the inside preventing it.
Old 11-19-2009, 02:29 PM   #5
My Gallery: (0)
Augh! So close! The danged stop screw is making things very difficult! It looks like there's a washer on the stop screw that's preventing it from coming out. I'm not sure. It's hard to make things out with what I can see through the small opening shutter engagement thing.
I don't know what to do. I got to this point last time I worked on it (a few months back) and I just can't get any further.
I want to get it working again! :'(
Reply
Lower Navigation
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Sponsored Links
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.3.2
Celebrity Gossip - United States Message Board - Parrot Forum - Honda Motorcycle - iPhone Forum - Motorola Droid Forum - Nintendo Wii Forum - Apple iPad Forum
