Results 1 to 14 of 14
  1. #1
    Join Date
    Aug 2008
    Middletown, NY
    Posts
    16
    My Gallery
    (0)
    My Photos Are NOT OK to Edit
    Liked
    0 times
    Product Photography-Floor Reflections?
    I've found this to be a common thing in a lot of product photography... this light reflection of the object in the floor. Is it really a semi-reflective surface that they're shooting on, or is it done in post processing?
    I've added a couple pics to illustrate what I mean... the pennies one is a little harder to see, but you get the point.
    Either way, could somehow tell me or point me in the direction of how to accomplish this? Thanks!
  2. # ADS
    Ads
    Google Advertisement
    Join Date
    Always
    Advertising world
    Posts
    Many
  3. #2
    I am Big, I am Mike Site Moderator
    TPF Supporter
    Join Date
    Dec 2003
    Edmonton
    Posts
    32,045
    My Gallery
    (111)
    Liked
    1202 times
    It's common to use plexiglass (or actual glass) over the white backdrop, to get this effect.
    There's no correlation between creativity and equipment ownership. None. Zilch. Nada. Actually, as the artist gets more into his thing, and as he gets more successful, his number of tools tends to go down. He knows what works for him. Expending mental energy on stuff wastes time.
    Hugh Macleod
    Edmonton Wedding Photographer ==>Blog
    Instructor at The Canadian Photography Learning Centre.
  4. #3
    Join Date
    Jan 2009
    Detroit, MI
    Posts
    My Gallery
    (0)
    Liked
    0 times
    acrylic works great for that effect but it all comes down to how you are lighting your subject. you can go with a milk acrylic and just be careful with your background light I usually use a single key light with a foam core reflector. you can also pull this off with clear acrylic as well which is nice because you can get no reflection or alot of reflection depending on how you direct your background light. The milk acrylic is the easiest way to go and can be fun to mess around with. hope that helped a little
  5. #4
    Join Date
    Mar 2009
    Posts
    31
    My Gallery
    (0)
    Liked
    0 times
    sometimes shooting portrait would use the same effect
  6. #5
    Join Date
    May 2009
    Chicago
    Posts
    56
    My Gallery
    (0)
    Liked
    1 times
    I use acrylic. Need to be careful because it scratches easily.
  7. #6
    Join Date
    Jun 2008
    Beech Grove, Indiana
    Posts
    76
    My Gallery
    (0)
    My Photos Are OK to Edit
    Liked
    4 times
    Take a look in the reflection. The wine spill is below the glass, that way the doggie doesn't mess up the spill
    I use glass or cellophane, the cellophane keeps from making the dreaded double reflection. It only works on non moving objects though.
  8. #7
    TPF Junkie!
    Join Date
    May 2009
    Glasgow
    Posts
    1,717
    My Gallery
    (0)
    Liked
    2 times
    Quote Originally Posted by photospherix View Post
    Good eye :P
    Gear|Canon 450D + 20D|18-55mm f3.5-5.6|75-300mm USM f4.5-5.6|50mm II f1.8|Opteka 500-1000mm mirror|85mm USM f1.8|Canon 580EX II flash|
    Accessories|Manfrotto 680B Monopod|484RC2 Ball head|EOS 450D camera armor|4x4gb SDcard|3x UV filter|Macro filter|Extension Tubes|Rocket blower|3x mini tripods|BG-E5 Battery grip + remote control|Konig KN-Tripod35|Giottos Vitruvian tripod|Arctic butterfly SL724 brite vue|2x Reflectors 5in1|
  9. #8
    Join Date
    Jul 2009
    San Francisco's North Bay
    Posts
    51
    My Gallery
    (0)
    Liked
    1 times
    I use tile board. Highly reflective and semi resistant to scratching.
  10. #9
    Join Date
    Jul 2008
    Houston
    Posts
    221
    My Gallery
    (0)
    Liked
    1 times
    Great thread, I always thought that was done post processing...but makes sense.
  11. #10
    KmH
    KmH is offline
    Helping photographers learn to fish
    TPF Supporter
    Join Date
    Apr 2009
    Iowa
    Posts
    28,727
    My Gallery
    (1)
    Liked
    2795 times
    Quote Originally Posted by CygnusStudios View Post
    +1 in 4x8 sheets from the hardware store. At least 2 sheets, put the rear edge of the front sheet on top of the front edge of the rear sheet (slight overlap) so you don't have to photoshop an edge that shows.
  12. #11
    Join Date
    Aug 2008
    Atlanta
    Posts
    9
    My Gallery
    (0)
    Liked
    0 times
    So would a photo like this be done the same way with a reflective surface, or is it on a light table? We've been trying to take pics like this, even without the reflective floor - using white poster board in a light box but they just seem to come out flat and grayish yellow. Any ideas?
    Thanks,
    JJ
  13. #12
    Join Date
    Jun 2008
    Posts
    76
    My Gallery
    (0)
    Liked
    4 times
    If you want a reflection but you want it muted. Another option is to use a piece of frosted plexiglass. This way it still has little shine, but not a full reflection. Another place I use this option is when i still want a shadow, but I want the background all gone. It helps to bring out the shadow.
  14. #13
    TPF Junkie!
    Join Date
    Mar 2009
    Key West FL
    Posts
    1,261
    My Gallery
    (11)
    Liked
    0 times
    Quote Originally Posted by bradracino View Post
    ... Is it really a semi-reflective surface that they're shooting on, or is it done in post processing?...
    Yes.
    Its done both ways. Shooting it as part of the original image requires skill and control. Adding it in PP requires less skill, but it likely to get your work posted on this site:
    PhotoshopDisasters
    check out the reflection of the purple box in this post:
    PhotoshopDisasters: Adobe: Wet Floors Are Dangerous
    BTW, one way of eliminating, or at least obscuring, the dreaded second reflection when using glass or plastic with a distinct thickness is to treat the lower surface with a dulling spray. The other way is to use an opaque plastic.
    Dwig
    happythursday.com
  15. #14
    Join Date
    Aug 2009
    Grand Rapids, Michigan
    Posts
    112
    My Gallery
    (0)
    Liked
    0 times
    Quote Originally Posted by Dwig View Post
    Yes.
    PhotoshopDisasters
    it's amazing some of the things you miss when you aren't looking
    "Don't make rules, make art"
    Model Mayhem
    F
    licker
    B
    log
Ads
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Similar Threads
  1. product photography
    By jazzodin in forum Commercial/Product photography
    Last Post: 04-25-2012, 07:58 PM
  2. Product Photography Product Exchange
    By tamckee in forum General Shop Talk
    Last Post: 08-11-2010, 02:06 PM
  3. Product photography C&C
    By flameshots in forum Photography Beginners' Forum
    Last Post: 06-23-2010, 01:54 PM
  4. HELP HELP HELP! product photography
    By third_shift|studios in forum General Gallery
    Last Post: 11-24-2008, 10:41 PM
  5. Indoor Wedding Photography/Dance Floor Question
    By bradracino in forum Beyond the Basics
    Last Post: 08-30-2008, 06:58 PM
acrylic flooring for photography
acrylic flooring for studio photography
acrylic perspex photography studio floor
floor reflection in photoshoots
floor reflections in photography
how to get a nice reflection ahooting products
how to get a reflective floors in photography shoot
how to use acrylic for floor photogrsphy
photographers trick to getting glassy looking floors
photography reflector floors
photography set mirror floor
product photography reflection
refelction product photography
reflections in product photography
reflective floor photography
Tags for this Thread
