Results 1 to 15 of 15
  1. #1
    Join Date
    Sep 2009
    UK
    Posts
    5
    My Gallery
    (0)
    Liked
    0 times
    Straight Edges and Barreling
    I'm about to become a first timer at commercial photography. I have to take pics of a number of doors. The doors are maybe 18 inches x 12 inches (0.5 metres x 0.3 metres). The pics will be used on a website.
    I'm planning to take the pics outdoors - it is always cloudy where I live.
    What's bothering me is that I'll be wanting to crop the images to the straight edges of the doors and resize to a standard size. But will I have problems with barreling of the straight edges?
    Would it be better to move the camera away from the object and then use the 3x zoom, or no zoom and get in a bit closer?
    Any thoughts?
  2. # ADS
    Ads
    Google Advertisement
    Join Date
    Always
    Advertising world
    Posts
    Many
  3. #2
    I am Big, I am Mike Site Moderator
    TPF Supporter
    Join Date
    Dec 2003
    Edmonton
    Posts
    32,063
    My Gallery
    (111)
    My Photos Are NOT OK to Edit
    Liked
    1206 times
    Distortion, like barreling, is mostly a product of lens design...so I can't say if it will be a problem for you or not.
    There's no correlation between creativity and equipment ownership. None. Zilch. Nada. Actually, as the artist gets more into his thing, and as he gets more successful, his number of tools tends to go down. He knows what works for him. Expending mental energy on stuff wastes time.
    Hugh Macleod
    Edmonton Wedding Photographer ==>Blog
    Instructor at The Canadian Photography Learning Centre.
  4. #3
    TPF Junkie!
    Join Date
    Aug 2009
    West Palm Beach, Fl
    Posts
    2,448
    My Gallery
    (13)
    Liked
    16 times
    usually barreling is less evident at the zoom side of a lens, so zoom in, step back, and take the picture. see if you like that better.
    Can't we all just
  5. #4
    Join Date
    Sep 2009
    UK
    Posts
    5
    My Gallery
    (0)
    Liked
    0 times
    Thanks, Mike
    I should have mentioned I'll be using a Canon Ixus 70 (SD1000 in America?), if this is any help.
  6. #5
    Join Date
    Sep 2009
    UK
    Posts
    5
    My Gallery
    (0)
    Liked
    0 times
    Quote Originally Posted by robertwsimpson View Post
    Thanks, Robert
    It seems intuitive that it might be better to use the zoom, but I'm really basing that on the geometry of the camera/distance/object. Interesting to see you say the lens itself might make a difference.
    Two reasons, then, to step back?
  7. #6
    TPF Junkie!
    Join Date
    Aug 2009
    West Palm Beach, Fl
    Posts
    2,448
    My Gallery
    (13)
    Liked
    16 times
    there are sites that analyze lenses for barreling, vignetting, etc, and then post it online, so search for your lens and I'll bet you can find something.
    Can't we all just
  8. #7
    TPF Supporter
    Join Date
    Dec 2003
    Edmonton
    Posts
    32,063
    My Gallery
    (111)
    Liked
    1206 times
    I don't know if they will be able to find the exactly characteristics of their lens...seeing as it's built into their P&S digi-cam. Those sites usually concentrate on interchangeable lenses.
    Another option, if the distortion is too much for you, is just to correct it (as best you can) with software.
    Hugh Macleod
  9. #8
    TPF Junkie!
    Join Date
    Aug 2009
    West Palm Beach, Fl
    Posts
    2,448
    My Gallery
    (13)
    Liked
    16 times
    oh I assumed we were talking about an SLR here... I shall now take my leave.
    Can't we all just
  10. #9
    KmH
    KmH is online now
    Helping photographers learn to fish
    TPF Supporter
    Join Date
    Apr 2009
    Iowa
    Posts
    28,759
    My Gallery
    (1)
    My Photos Are OK to Edit
    Liked
    2802 times
    Shoot fat. Leave plenty of room in the frame between the door edges and the sides of the picture. Then crop to the final image size.
  11. #10
    TPF Junkie!
    Join Date
    Mar 2009
    Key West FL
    Posts
    1,261
    My Gallery
    (11)
    Liked
    0 times
    Quote Originally Posted by MonkeyChewTobacco View Post
    Thanks, Mike
    Do some tests.
    Most of the modern zooms found on P&S cameras and the kit zooms on DSLRs exhibit a fair amount of rectilinear distortion (straight lines don't stay straight). The amount and type (barrel where the center bows outward and pincushion where the center bows inward) generally varies a good deal with the selected focal length.
    The most common pattern is barrel distortion at the wide end and pincushion at the long end. Often there is a sweet spot where rectilinear distortion is very small. This sweet spot is most often a focal length toward the longer end. Take a series of test shots at different focal length ("zoom") settings, varying your shooting distance as necessary, and review the shots to see where the distortion is the least. Then use that zoom setting for your final shots.
    Be very very carefult to shoot straight into the door. Any small amount off angle will cause a different type of distortion where the sides of the door, while straight, are not parallel. While this error is fairly easy to correct in Photoshop, its better to get it right in camera.
    Dwig
    happythursday.com
  12. #11
    KmH
    KmH is online now
    TPF Supporter
    Join Date
    Apr 2009
    Iowa
    Posts
    28,759
    My Gallery
    (1)
    Liked
    2802 times
    Quote Originally Posted by Dwig View Post
    This known as perspective distortion.
  13. #12
    Join Date
    Sep 2009
    UK
    Posts
    5
    My Gallery
    (0)
    Liked
    0 times
    Thanks everyone for your advice.
    In the end, things went pretty well. Barrelling/pincushioning proved not to be an issue. I had the camera on a tripod about 6ft (2metres) from the doors with the zoom about two thirds of the way out (sorry - not sure of terminology!).
    I processed the images in Paint Shop Pro and found that they were half a degree off level and, on some of the doors, minimally perspective distorted. I could correct these problems easily enough.
    An unexpected problem was the variation in the lighting - it was cloudy but the cloud was obviously quite variable in density.
    The hardest thing was separating the doors from their background (a white sheet). This needed quite a bit of faffing about with the magic wand tool, the clone tool and the crop tool. But the end product is easily good enough for purpose.
  14. #13
    TPF Junkie!
    Join Date
    Aug 2009
    West Palm Beach, Fl
    Posts
    2,448
    My Gallery
    (13)
    Liked
    16 times
    post the results!
    Can't we all just
  15. #14
    Join Date
    Sep 2009
    UK
    Posts
    5
    My Gallery
    (0)
    Liked
    0 times
    Low-res, cos they're for the web, but enough detail for the purpose I think.
  16. #15
    Join Date
    Aug 2007
    Clearwater, FL
    Posts
    115
    My Gallery
    (0)
    Liked
    0 times
    Ohh, CABINET doors. I was wondering what tiny little houses these doors went on.
Ads
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Similar Threads
  1. Rounded Edges
    By Bampson in forum Graphics Programs and Photo Gallery
    Last Post: 09-22-2010, 03:10 PM
  2. Grasping edges
    By sarahashleyphotos in forum General Gallery
    Last Post: 04-29-2009, 06:44 AM
  3. EDGES
    By timethief in forum General Gallery
    Last Post: 03-26-2009, 04:34 PM
  4. How to soften edges in CS2?
    By crystal_lynn in forum Graphics Programs and Photo Gallery
    Last Post: 03-06-2008, 05:38 AM
  5. Urban Edges
    By bburton in forum General Gallery
    Last Post: 03-04-2006, 05:56 PM
barreling photography
Tags for this Thread
