Results 1 to 12 of 12
  1. #1
    Join Date
    Aug 2012
    Posts
    4
    My Gallery
    (0)
    My Photos Are NOT OK to Edit
    Liked
    0 times
    product photography help
    Hello everyone!
    I am attempting to learn product photography using basic DYI equipment.
    I have very limited space in my garage and this is the best set up that I can manage
    and the picture turned out looking like this :
    More info:
    For the light bulbs I am using 2 150W sylvania CFL that generates 2600 lumens each.
    Thank you so much in advance and looking forward to your suggestions.
  2. # ADS
    Ads
    Google Advertisement
    Join Date
    Always
    Posts
    Many
  3. #2
    TPF Junkie!
    Join Date
    Feb 2011
    Fulham, London, UK
    Posts
    1,511
    My Gallery
    (52)
    Liked
    307 times
    You've actually done pretty well considering the equipment you have to use. The obvious problem is your white balance. With continuous lights with bulbs like the ones you have, set your white balance either to Tungsten or Auto. Or even better, if your camera is able, shoot in RAW so you can correct the WB afterwards.
    It may just be my eyes and the size of the picture, bt the rim of the hat towards the back is slightly OOF, so perhaps you could dial your aperture down a stop or two.
    But overall, not a bad effort.
  4. #3
    Join Date
    Aug 2012
    Posts
    4
    My Gallery
    (0)
    Liked
    0 times
    Hello Forkie!
    Thank you for your advice.
    Answers to your comments:
    Yes, it is out of focus, I played around with the white balance by setting it to auto and tungsten, but i still seem to have the "yellowness". What additional steps do you recommend?
    Lastly, I have no idea how to work with Raw files, although I do have access to CS5. (still learning that as well) would you please point me in the right direction?
    If it helps, I am using a Cannon Rebel XSI with a manual external flash.
    Thanks again!
  5. #4
    TPF Junkie!
    Join Date
    Jul 2011
    Okinawa, Japan
    Posts
    1,523
    My Gallery
    (2)
    Liked
    392 times
    For the white balance issues, I would get a grey card and set the WB manually. Being that you are in a controlled environment you can take one WB shot and use that in post to get it correct in all of them. I used an XSI and I was always fighting with it to get the WB correct. Another thing that might help is parchment paper. shine the light through the paper to act as a soft box. You can pick up a roll for a couple bucks. Make sure to set the timer or remote shutter release. I've done some of the same set ups as you and had a blast doing it. Best of luck and I hope you have fun doing it.
    Flickr
    Eric
  6. #5
    TPF Junkie!
    Join Date
    Sep 2009
    Way up North in Michigan
    Posts
    4,843
    My Gallery
    (0)
    Liked
    1616 times
    Try this: Set one of the lights further away than the other to give the subject more 3-dimensional definition through the use of light and shadow. For a 1:2 ratio, one light needs to be twice as far away as the other light, per the inverse square law.
    For white balance, until you get a gray card or other white balance tool, try using the white board you're using for your background. Light it with the two lamps, then take a photo of it, then use that photo as a custom white balance reference in your camera. This video should be able to help you:
    Canon EOS 450D Rebel XSi - Setting a Custom White Balance - YouTube
    Refer to your camera manual on how exactly to do this if you have any trouble with it.
    Your honest C&C is always welcome and appreciated. For those with such interests: My Gear
    "Photography's never been merely about photographing what you could see; it's always been about photographing what you wanted to see." ~ Ctein
    Life is like photography... FOCUS on what's important, CAPTURE the good times, DEVELOP from the negatives, and if things don't work out, TAKE ANOTHER SHOT!!!
  7. #6
    TPF Junkie!
    Join Date
    May 2012
    Virginia
    Posts
    3,511
    My Gallery
    (10)
    My Photos Are OK to Edit
    Liked
    1078 times
    Quote Originally Posted by Buckster View Post
    Isn't that a 1:4 ratio?
    Blogging about photography: Photos and Stuff.
    Gear: Gripped Sinar F1, Vivitar 285HV on a Manfrotto rail, and a bunch of lens caps epoxied into a ball.
  8. #7
    TPF Junkie!
    Join Date
    Sep 2009
    Posts
    4,843
    My Gallery
    (0)
    Liked
    1616 times
    Quote Originally Posted by amolitor View Post
    Yes, quite right. Good catch. I stand corrected.
  9. #8
    TPF Junkie!
    Join Date
    May 2012
    Virginia
    Posts
    3,511
    My Gallery
    (10)
    Liked
    1078 times
    I always have to shove my thinking cap on extra hard for those, and then I typo it anyways because I'm thinking of a number halfway through instead of at the end.
  10. #9
    TPF Junkie!
    Join Date
    Oct 2011
    NY
    Posts
    6,763
    My Gallery
    (28)
    Liked
    1380 times
    A light tent would definitely help to soften and bounce your light around.
    Canon FanGirl Extraordinaire
  11. #10
    Join Date
    Aug 2012
    Posts
    4
    My Gallery
    (0)
    Liked
    0 times
    questions:
    What exactly does a remote shutter release do compared to a timer?
    Does it make that big of a difference if i press the button even with a tripod?
    Thank you so much for everyone's advice. Will keep you guys updated!
  12. #11
    Join Date
    Aug 2010
    Portsmouth, NH
    Posts
    295
    My Gallery
    (0)
    Liked
    34 times
    All things considered, not bad. A bit flat, it could benefit from a backlight. The remote release and timer will get you the same results by eliminating shutter shake, but with a remote cable, you won't need to be quite as patient. And yes, if you are on your tripod, having a cable release will still help, pressing the shutter on the camera, even on a tripod will result in some blur.
  13. #12
    Join Date
    Aug 2012
    Posts
    4
    My Gallery
    (0)
    Liked
    0 times
    Here is my second attempt:
    Set up: (I have wax paper and parchment paper lined in front of the pan lights.
    I also attempted the 1:4 ratio but the results were presentable. (perhaps I did it incorrectly)
    but here is the result.
    I also added a LED backlight by the hat's 2 o clock. Not sure if that's the proper way to do it.
Ads
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Similar Threads
  1. 360 product photography
    By photospherix in forum Personal and Professional Photography Websites
    Last Post: 03-18-2013, 01:53 PM
  2. DIY Light box, Product Photography and Clothing Photography help
    By Ballistics in forum Photography Beginners' Forum
    Last Post: 07-30-2011, 06:18 PM
  3. Product Photography Product Exchange
    By tamckee in forum General Shop Talk
    Last Post: 08-11-2010, 02:06 PM
  4. Product photography. Please help!
    By kalleg in forum Commercial/Product photography
    Last Post: 04-06-2010, 01:17 PM
  5. Product Photography?
    By Chriss in forum Photography Beginners' Forum
    Last Post: 01-24-2010, 08:40 PM
360 product photography forum
cap product photography
cfl 2600 lumens photography
