Results 16 to 24 of 24
08-10-2012, 06:13 PM #16No longer a newbie, moving up!
- Join Date
- Dec 2011
- Posts
- 62
- My Gallery
- (0)
- My Photos Are OK to Edit
- Liked
- 2 times
08-10-2012 06:13 PM # ADS
08-10-2012, 06:29 PM #17TPF Junkie!
- Join Date
- Sep 2009
- Location
- Way up North in Michigan
- Posts
- 4,846
- My Gallery
- (0)
- My Photos Are NOT OK to Edit
- Liked
- 1618 times
I see what you mean. With a piece of glass inside the tent, you won't need it elevated, though you could shoot a third light under the glass onto the fabric under it from the front, or still elevate it and shoot it from underneath. Either method will light up that bottom just fine.
Your honest C&C is always welcome and appreciated. For those with such interests: My Gear
"Photography's never been merely about photographing what you could see; it's always been about photographing what you wanted to see." ~ Ctein
Life is like photography... FOCUS on what's important, CAPTURE the good times, DEVELOP from the negatives, and if things don't work out, TAKE ANOTHER SHOT!!!
08-10-2012, 07:20 PM #18Bug Junkie
- Join Date
- Aug 2011
- Location
- Arvada Co
- Posts
- 14,429
- My Gallery
- (0)
- Liked
- 3438 times
You definitely got a WHITE background for the components... with shooting the bottom! The trouble is that there was too much! Need to cut back on the flash power significantly.. try to balance it, so you get white, but not so much it kills the subjects. That is why I said "You would have to play with power levels..."!
Buckster's idea is good also... normally if you are trying to blow out a background, you dont want the subjects too close to the background, as there can be light splash.-------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------
I'm Charlie! Who are you?
Nikon D800 / D7000, R1C1 Macro Flash, SB-900 x2, 14-24 2.8, 24-70 2.8, 70-200 2.8, 85 1.4, 50 1.4, 105 2.8 macro, TC20E 2x TC / TC14E 1.4x TC, Monolights, Pocket Wizards, etc.....
Flickr Images
500px Images
08-10-2012, 08:45 PM #19No longer a newbie, moving up!
- Join Date
- Dec 2011
- Posts
- 62
- My Gallery
- (0)
- Liked
- 2 times
The flash underneath was at its lowest power level, 1/128, but I tried moving the light tent further away from it and that reduced the brightness. I tried both that and also setting the LEDs on a plate of glass I just grabbed out of a picture frame, but the results were not much better than before. I'll try again tomorrow, I guess..
08-10-2012, 09:29 PM #20TPF Junkie!
- Join Date
- May 2006
- Posts
- 7,483
- My Gallery
- (0)
- Liked
- 458 times
power isn't the problem, it's that you're working too close to your subjects. Think bigger.
get a sheet of plexi. Not some 8x10 sheet, more like 4x4 feet.
get some 4 1/2 foot white seamless.
compose the picture
drop seamless in the background..some feet behind the subjects.
nuke the seamless with a flash
by now, you should have a pure white background and a silhouette of the pins.
pump a flash through some sort of diffusion material (such as a reflector panel or softbox)
now your background and subject are lit independently.
That's how you do it:
08-11-2012, 02:33 AM #21TPF Noob!
- Join Date
- Oct 2010
- Location
- Israel
- Posts
- 4
- My Gallery
- (0)
- Liked
- 1 times
try using a white plexiglass as the bottom of the set.
08-11-2012, 06:11 AM #22TPF Junkie!
- Join Date
- Sep 2009
- Location
- Posts
- 4,846
- My Gallery
- (0)
- Liked
- 1618 times
08-11-2012, 02:13 PM #23No longer a newbie, moving up!
- Join Date
- Dec 2011
- Posts
- 62
- My Gallery
- (0)
- Liked
- 2 times
I held the glass probably 10" from the bottom. The flash was still underneath the light tent.
A 4x4' piece of plexiglass?
Could you explain what you mean by "white seamless"?
How would you place the flashes with your setup?
That picture looks great, by the way!
08-11-2012, 09:35 PM #24TPF Junkie!
- Join Date
- May 2006
- Posts
- 7,483
- My Gallery
- (0)
- Liked
- 458 times
You don't have to use plexi..any glass without color would work, it just needs to be durable and completely transparent. And yes, 4 by 4 feet, the bigger, the better, it allows for more than one angle.
Seamless is giant rolls of paper.
if you've got the glass on sawhorses, just put a head or two underneath the glass pointing at the seamless, and another head on the subject. light them independent.
Similar Threads
Product photography and that perfect white background
By Kingdutch in forum Commercial/Product photographyReplies: 12Last Post: 06-12-2012, 02:44 PM -
Antique black and white photography. Need Advice if possible.
By Sibelius19 in forum Photographic DiscussionsReplies: 4Last Post: 01-26-2009, 07:11 PM -
Shooting macro objects on white background
By neonsky in forum Photography Beginners' ForumReplies: 3Last Post: 11-20-2008, 02:52 PM -
Black & White photography tips & advice
By benjyman345 in forum Beyond the BasicsReplies: 8Last Post: 01-07-2007, 12:30 AM -
indoor white background photography (need lots-a-help)
By urameatball in forum Beyond the BasicsReplies: 16Last Post: 08-22-2003, 12:51 PM
cowboystudio macro focusing rail set
,how to get perfect white background in toy photography
,how to make a macro tent
,how to set up a white background for macro photography
,macro photography glass table
,macro photography white background
,macro shooting background white
,photographer who uses white backdrop
,photography how to white background macro
,picture backdrop macro
,what's use or backdrop and table for macro photography
,white backdrops for macro photography
,white background macro photography
,white background photography for macro
,white background with macro photography
LinkBack URL
About LinkBacks
