Results 1 to 9 of 9
  1. #1
    Join Date
    Dec 2008
    Windsor, ON. Canada
    Posts
    630
    My Gallery
    (0)
    My Photos Are OK to Edit
    Liked
    0 times
    Crop Sensor vs. Full frame
    I realize this may be a loaded question, but why do so many photogs consider a full frame sensor superior to a crop sensor?
    Other than image size what's the difference?
    The reason I'm asking...
    I have a D90 with several DX lenses and a few full frame lenses. I want to buy some additional glass. If I buy DX lenses and then eventually switch to a full frame body...my DX lenses are garbage...but I had someone tell me that the DX lenses are better quality than the full frame lenses.
    Your thoughts on this would be appreciated...
    Thanks
    Dave
    Dave
    "I know just enough to get into trouble!"
    35mm - Minolta stuff
    Digital - Nikon stuff
    http://www.flickr.com/photos/gaffentphotography/
    http://www.gaffentphotography.blogspot.com/
  2. #2
    Big
    Big is offline
    TPF Junkie!
    Join Date
    Apr 2009
    New Hampshire
    Posts
    1,228
    My Gallery
    (0)
    My Photos Are NOT OK to Edit
    Liked
    0 times
    This may help you. It's a thread I had started a while ago about FF vs CS.
    http://www.thephotoforum.com/forum/p...y-why-not.html
    Canon 50D Gripped
    20-70 2.8L
    70-300mm f/4-5.6
    ~ 100mm f/2.8 macro
    ~ 50mm f/1.4
    ~ Canon Speedlite 430EXII with Lumiquest Ultrasoft
    http://www.coffmanimages.webs.com
  3. #3
    Join Date
    Dec 2009
    Boise Idaho
    Posts
    350
    My Gallery
    (30)
    Liked
    0 times
    You can still use your DX lenses with full frame just less megapixels in the shot.
    Switching from the d300 to the d700 the photos just "look" so much better and require less processing to get to how I like them to look, that is probably just me.
    The FX lenses are wider the DX lenses are longer so there are good points to each.
    I use my d300 for things that are far away and for macro for the deeper depth of field.
    Is use my full frames for all my people pictures and landscapes.
    And the noise issue....the full frame is amazingly better than the crop frames for noise.
    With my d3oo I did not like going over iso 800, 1600 in a pinch.
    With the d700 and d3 I have no issue at all shooting at 1600 in any light and iso 3200 is just amazing if the exposure is correct.
  4. #4
    Join Date
    Dec 2008
    Windsor, ON. Canada
    Posts
    630
    My Gallery
    (0)
    Liked
    0 times
    Excellent information. Thank you
    Dave
  5. #5
    Mr. Rain Cloud
    Join Date
    Jul 2009
    USA
    Posts
    27,656
    My Gallery
    (0)
    Liked
    9262 times
    The FF sensor in 2.5x larger than a Nikon DX sensor, and 2.7x larger than a Canon APS-C sensor. The FF sensor has larger pixels, which do better at elevated ISO settings than smaller pixels. The FF sensor accepts the fiull field of a lens, meaning an 85mm lens can capture an 8.5 foot tall field of view from 20 feet; with APS-C, the camera needs to be 35 feet away to capture the same height--that leads to deeper depth of field with the APS-C body AND it means that it is almost impossible to use an 85mm or 100mm lens indoors--unless "indoors" means a basketball court or the Superdome.
    In short, the FF option leads to better subject/background isolation capabilities for people photography. it also allows you to use lenses like a 70-200 f/2.8 indoors; on APS-C, the lens is of much less use indoors, especially at close ranges.
    Last,almost any lens achieves a higher resolution and better image quality on a larger sensor. Overall picture quality is a blend of lens performance, sensor size, sensor noise levels; in short, a moderately-performing lens used on a sensor 2.7x larger than APS-C yields a better image than a somewhat better lens used on a 1.6x sensor.
  6. #6
    Join Date
    Oct 2009
    Cypress, CA
    Posts
    377
    My Gallery
    (0)
    Liked
    0 times
    Some sensor sizes used by popular DSLR cameras: Type
    Diagonal
    Sensor Size
    Crop Factor
    Olympus, Lumix 4/3
    21.64mm
    17.3mm x 13.0mm
    2.00
    Sigma Foveon
    24.88mm
    20.7mm x 13.8mm
    1.74
    Canon Rebel (APS-C)
    26.82mm
    22.3mm x 14.9mm
    1.61
    Nikon DX (APS-C)
    28.40mm
    23.6mm x 15.8mm
    1.52
    Canon 1Dx (APS-H)
    33.75mm
    28.1mm x 18.7mm
    1.28
    35mm FF
    43.27mm
    36mm x 24mm
    1.00
    The nikon FX sensor is 2.25x larger in area than the Nikon DX sensor. that's because 1.5 x 1.5 = 2.25. To be exact it is 1.52 x 1.52 or 2.3104. Low noise performance is directly proportional to sensor size. So if you do a lot of indoors shots, low light outdoors shots, fast action shots, a FF camera should benefit you. Of course if you want really wide angle shots, again a FF camera will benefit you. The Nikon 14-24mm is the best wide angle zoom lens ever produced and it is designed for a FF camera.
    Yes, Nikon FX bodies can use DX lenses in the crop mode. but that is senseless. There is not a doubt in my mind that eventually all DSLRs will be FF. I know many don't agree, but time will tell. The electronics world is changing rapidly. Things that are unimaginable a few years back are now available to us today. To many the added cost of FF sensors will limit them to high end DSLRs - well I don't believe so. When LCD flat panel monitors started coming out they were far more expensive than their CRT counterparts. Look what is happening now. LCD flat panel monitors are so inexpensive that they actually drove CRT monitors out of business! You can't defy the physics of the better high ISO performance offered by FF sensors. It is only a matter of time before camera companies will settle on the standardization of FF sensors.
  7. #7
    Mr. Rain Cloud
    Join Date
    Jul 2009
    USA
    Posts
    27,656
    My Gallery
    (0)
    Liked
    9262 times
    Here's a comparison of sensor sizes from a public domain (unlimited use, non-copyrighted) chart that I modified by removing the medium format digital sensor sizes, since so few people own MF digital backs.
    The actual area of the FF sensor is substantially larger than many people seem to realize.
  8. #8
    TPF Junkie!
    Join Date
    Oct 2003
    Brisbane, Australia
    Posts
    9,712
    My Gallery
    (0)
    Liked
    204 times
    Yep people always seem to forget the squared button on the calculator. When the photosites are 2.25x larger you get far better signal to noise ratio on the light you capture. And when they are spaced further apart the actual resolution of the lens can be lower. (ok that may work for the D300 to D700 which are both 12mpx, but doesn't work for Canon's uber high mpx sensors)
    "I am always satisfied with the best." -Oscar Wilde
    Larger versions always on flickr
    Best photos in my gallery
    Proud Supporter of The Pact
  9. #9
    Join Date
    Nov 2009
    Reading
    Posts
    My Gallery
    (0)
    Liked
    0 times
    A much less technical answer I know - but I mainly do gig photography - and a year ago I upgraded from Canon 40D to a 5Dmkii - and I have to say the difference in my results is dramatic.
    When I did the upgrade - I justified it to myself (and my wife) by saying I would use both bodies to shoot but with different lenses making dealing with the 3 songs no flash rule easier. But I quickly found I was discarding all the shots taken with the 40d for the full sensor ones from the 5Dmkii - the low light performance is so much better and the argument that you get better zoom out of your lenses with the smaller sensor is only exactly the same as taking a bigger area shot on the full sensor and cropping in (which I'd always rather do as the quality is better).
    I do carry the 40d for weddings etc as backup and it's got me out of trouble before - but I felt uncomfortable using it.
    Adam
    adamreading photography
    http://www.adamreading.com
    http://blog.adamreading.com
Ads
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Similar Threads
  1. very basic Crop vs Full-Frame questions
    By Ronaldo in forum Photography Beginners' Forum
    Last Post: 02-08-2011, 02:37 PM
  2. Give up 2 crop bodies for 1 full frame?
    By Light Artisan in forum Photography Equipment & Products
    Last Post: 12-06-2010, 08:08 AM
  3. Full frame vs Crop sensor (good info)
    By Feezor in forum Photography Beginners' Forum
    Last Post: 07-11-2010, 05:38 PM
  4. Crop Vs. Full frame sensor?
    By FDSA in forum Photography Beginners' Forum
    Last Post: 04-25-2009, 06:13 PM
  5. Focal length and full sensor vrs.crop sensor
    By uplander in forum Beyond the Basics
    Last Post: 03-16-2009, 06:57 AM
35mm vs medium format
aps-c to full frame calculator
full frame vs medium format
full sensor vs crop sensor
medium format vs 35mm
medium format vs full frame
medium format vs full frame sensor size
