01-06-2010 10:36 PM
# ADS
Fluorescent lighting, cyclical color variations due to electrical current's AC cycling rate is my guess.
Originally Posted by
Derrel
Interesting. Now and days it seems that fluorescent lighting is the standard, as incandescent bulbs are inefficient, so I will have to try to find an incandescent source and take outdoor shots as well tomorrow. Lets say that this is the issue, is this common with all cameras and is it something I will have to live with? I have never noticed this before with previous cameras. That would stink to know that I might end up with crappy, unusable photos anytime I shot indoors under fluorescents.
Have you had this issue before?
Canon 5DMII
17-40mm f/4
100mm f/2.8 macro
70-200mm f/2.8
my flickr
Shoot a white wall or piece of foamcore outside away from any fluorescents and see if you get the same thing.
Make sure your WB is set for Fluorescent lighting.
Keith Lambert
I set my white balance manually with a piece of computer paper for accuracy.
Canon 5DMII
17-40mm f/4
100mm f/2.8 macro
70-200mm f/2.8
my flickr
You may want to consider going to your menu and returning to default settings on WB, then taking a shot with the T1i in Creative mode (Av priority) with the WB on Florescent, no flash. See if you get the same results?.
Keith Lambert
I will try that. Thanks for the info everyone
I will let you know what I found out tonight.
Canon 5DMII
17-40mm f/4
100mm f/2.8 macro
70-200mm f/2.8
my flickr
Keith Lambert
WB is a picture wide setting. Whatever colour temperature / tint the camera chooses would affect the image in an overall sense. A change of the white balance setting won't fix this issue unless there is something fundamentally wrong with the way the camera is processing images.
"I am always satisfied with the best." -Oscar Wilde
Larger versions always on flickr
Best photos in my gallery
Proud Supporter of The Pact
Well folks, it seems as though derrel nailed it. I have not been able to reproduce that effect, even in the same lighting. Must have been a temporary issue. Now I won't freak out when this happens again
Thanks for the help everyone
Canon 5DMII
17-40mm f/4
100mm f/2.8 macro
70-200mm f/2.8
my flickr
Try to take the photo with (shutter priority) 1/60, 1/120 and 1/180 shutter speed and see if you see any issue. Then try it with 1/30 and see if the problem comes back. (with fluorescent light as the light source)
Edit: Since US AC frequency is 60Hz, for other countries, it could be 50Hz, so choose the shutter speed close to 1/(freq x N where N is an integer other than 0) so that the light can complete the cycle.
Derrel is the Man!
Thanks Beatles for posting to let us know what the deal was. It helped all of learn.
Reason: Accidently didnt make a thread
