class 6 20MB/s vs class 10 22MB/s SDHC cards
i recently bought a pansonic gold class 10 SDHC card, its max transfer rate is 22MB/s, i already have a core micro class 6 SDHC card with a max transfer rate of 20MB/s, my question is, will the extra 2mb make a big difference? ideally i want longer video, and more shots per burst, i have a nikon D5000 if that helps.
09-26-2010 06:09 PM
# ADS
That 'more shots per burst' thing is called your processing buffer/shooting buffer/buffer zone/buffer thing, and is dictated by your camera, not the card. The card speed can affect how quickly new images are written to it, but not how many can be queued for processing/saving.
I hope that helps.
thank you that does help, although i'm still confused about the extra 2MB/s the class 10 gives, will it have any significant effect on my shooting and all that? what are the benefits of getting a class 10 rather than class 6? i already have a class 6 so i'm not sure if i really need the class 10
Let's say a photo is 6MB in size... 6/20=.3, meaning it would take .3 seconds to save that file. 6/2=~.27, so ~.27 seconds to save that image. If you're a sports photographer and and take massive high-fps strings of shots, it might prove to be useful. .27*15=4.05 seconds to save all of those images. .3*15=4.5 seconds to save those files. It saves a little under half a second if you take a string of 15 photos, of say a defender closing on on a ball carrier for a tackle. In a high-speed game where your shots count for more than just your photostream, it's probably worth it. If that's the case you probably don't even have to worry about it though because you already have the best, and you probably didn't pay for it.
In short, no, that speed difference does not make a practical difference to 99.8% of photographers while shooting. It is a 10% increase in speed of something that is already very fast.
It would however make a larger difference when transferring those files from your card to your computer.
(500 images * 6MB each)/20MB/s = 150s to transfer all 500 images.
(500 images * 6MB each)/22MB/s = ~136.36s to transfer all 500 images.
Is it worth saving 20 seconds? Not really....
Would it be worth it for a hobbyist videographer shooting HD video? Possibly.
All of this pertains to the SPEED ONLY. I have no idea what other differences there may be between a Class 6 and Class 10.
thank you, you are very helpful, i was doing some research, and in the manual it states while using the sandisk extreme 3 (30MB/s) {renamed to class 10} it has a buffer capacity of 11 shots on RAW, with a normal class 6 card (20MB/s) {i have a core micro card} it can take 9 RAW shots, and with "long exposure noise reduction" turned on the number falls to 6 RAW shots
so i may be wrong but it seems under ideal conditions, the 10MB/s difference amounts to 2 extra pictures before the camera needs to buffer
so i guess to answer my own question as far as the difference between the 20MB/s class 6 and the 22MB/s class 10, you can add half a RAW image onto the buffer
if my calculations or the whole theory is wrong please let me know
however i did find a big difference between the cards as far as JPEG is concerned
in case anyone is interested in other formats such as just JPEG (fine, normal, basic) + (large, medium, small) i compared what my class 6 (20MB/s) can do under ideal conditions vs. the 30MB/s sandisk (specs found in nikon D5000 manual pg. 215)
(all the JPEG+RAW, large, medium, small are the same for both cards, 7 shots within the buffer)
JPEG fine
large - 13 vs. 63, medium - 19 vs. 100, small - 33 vs. 100
JPEG normal
large - 21 vs. 100, medium - 33 vs. 100, small - 61 vs. 100
JPEG basic
large - 33 vs. 100, medium - 61 vs. 100, small - 99 vs. 100
as a side note regarding video, the information i gathered from photo stores, is that the better the MB/s the less choppy the video will be, however having a class 6 myself i can safely say that at 20MB/s the video looks perfectly fine and smooth, but i'm sure in some way or another the video might be smoother at 22MB/s and 30MB/s but i'm not convinced it will be anything drastic or noticeable
i personally know how hard it is to find the information you need so i hope as far as class 6 vs. class 10 all this helps
