Results 1 to 7 of 7
  1. #1
    Join Date
    Nov 2010
    North Carolina
    Posts
    66
    My Gallery
    (0)
    My Photos Are OK to Edit
    Liked
    0 times
    Sharpening in Capture NX vs. Lightroom 3
    I have a Nikon D7000 and I shoot in 14-bit NEF (raw). I値l develop the photos in both Nikon Capture NX 2.2.6 and Adobe Photoshop Lightroom 3.3. After doing any post-processing in NX2 or LR3, I値l save the photo for use on the web as a downsized JPEG (1024 pixels wide).
    I知 consistently getting sharper results in the resulting JPEG files using Nikon Capture NX2 than using Adobe Lightroom 3.
    With NX2, I値l do minor capture sharpening, resize the image to 1024, and then use an UnSharp Mask for output sharpening. I get great results.
    With LR3, I値l use the Details tab to do capture sharpening, and then export to JPEG, which resizes the photo. In the export settings, I have output sharpening turned on for Screen and amount set to either Standard or High. However, the downsized JPEGs generated by LR3 look less sharp and focused.
    Is there any way to have more control over the output sharpening in Lightroom 3?
    Any suggestions?
    Nikon D7000, Nikkor 10-24, 16-85 VR, 70-300 VR, 35mm f/1.8G, Manfrotto 055CXPRO3 carbon fiber tripod, Really Right Stuff BH-40
  2. # ADS
    Ads
    Google Advertisement
    Join Date
    Always
    Advertising world
    Posts
    Many
  3. #2
    KmH
    KmH is offline
    Helping photographers learn to fish
    TPF Supporter
    Join Date
    Apr 2009
    Iowa
    Posts
    28,771
    My Gallery
    (1)
    Liked
    2804 times
    Real World Image Sharpening with Adobe Photoshop, Camera Raw and Lightroom by Bruce Frazer & Jeff Schewe
    will tell you everything you need to know about image sharpening, and the other side of that same coin, noise reduction.
  4. #3
    TPF Junkie!
    Join Date
    Oct 2003
    Brisbane, Australia
    Posts
    9,639
    My Gallery
    (0)
    My Photos Are NOT OK to Edit
    Liked
    190 times
    Ultimately the problem is one of sharpening being done for the 100% preview rather than for the resized variant. If you can't get a decent result playing with the "Sharpen For" settings in the export dialogue then you may need to pre-sharpen with a different settings which may at the time look quite bad. There's really no other way around it for Lightroom (which may I add I can get perfectly sharp photos out of so I'm not quite sure what you're after, can you post examples?)
    One way is to presharpen with larger radius. Set the radius to 2-3 pixels rather than the 1 default. It may look bad in the 100% preview, but once scaled down the picture looks quite different. The only other option if you don't like that is to open the exported file and sharpen after, but again why you can't get a sharp picture out I don't understand.
    "I am always satisfied with the best." -Oscar Wilde
    Larger versions always on flickr
    Best photos in my gallery
    Proud Supporter of The Pact
  5. #4
    Join Date
    Nov 2010
    North Carolina
    Posts
    66
    My Gallery
    (0)
    Liked
    0 times
    Quote Originally Posted by Garbz View Post
    This is the same photo taken with a Nikon D7000 using a 16-85mm lens. I processed the 14-bit NEF/raw file with both programs.
    The first JPEG was created with Nikon Capture NX.
    TrainStationNX2 by DVC Mike, on Flickr
    The second JPEG was created with Adobe Lightroom 3.
    TrainStationLR3 by DVC Mike, on Flickr
  6. #5
    KmH
    KmH is offline
    TPF Supporter
    Join Date
    Apr 2009
    Iowa
    Posts
    28,771
    My Gallery
    (1)
    Liked
    2804 times
    I would venture the difference isn't the sharpening, but rather differences in the algorithms used for mid-tone contrast.
    All Raw converters will render images somewhat differently because of differences in the algorithms.
  7. #6
    Join Date
    Nov 2010
    North Carolina
    Posts
    66
    My Gallery
    (0)
    Liked
    0 times
    Quote Originally Posted by KmH View Post
    Thanks for the feedback!
    I was actually hoping to switch to LR3 from NX2, but since I'm not getting the results I want - maybe not.
    Here's two more samples. For both, I just applied the camera and lens profiles, without doing any additional processing (no WB, tone/contrast, etc.) except for sharpening.
    I still want the LR3 JPEG to be just a bit sharper.
    Lightroom 3.3
    EpcotLR3 by DVC Mike, on Flickr
    Capture NX2
    EpcotNX2 by DVC Mike, on Flickr
  8. #7
    TPF Junkie!
    Join Date
    Feb 2010
    New York
    Posts
    2,680
    My Gallery
    (0)
    Liked
    0 times
    I know that from one person's screen to another there are differences.
    From my screen, I think you may have a tonal/contrast issue as Keith mentioned.
    Cameras/LR3/NX2 do not have exactly the same treatments of the image.
    You may want to set a download to add a little contrast/tonal treatment upon download to LR3 and see if that works for you. Try it on a few images, instead of a whole download, tweeking it until you are satisfied. You can change these for different cameras/lenses.
    Just some of my thoughts...
    Pierre
Ads
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Similar Threads
  1. Capture NX2 vs Lightroom 3
    By edouble in forum Photography Equipment & Products
    Last Post: 06-29-2010, 05:51 AM
  2. capture NX2 vs lightroom feedback - budget for PP software
    By pokopelo in forum Photography Beginners' Forum
    Last Post: 08-06-2009, 09:55 PM
  3. Capture NX, Photoshop, Lightroom
    By kdabbagh in forum Beyond the Basics
    Last Post: 12-16-2008, 11:28 AM
  4. Lightroom sharpening issue
    By sincere in forum Digital Discussion & Q&A
    Last Post: 12-24-2007, 08:40 PM
  5. Capture NX function -> Lightroom equivalent
    By OmlessWanderer in forum Digital Discussion & Q&A
    Last Post: 06-25-2007, 11:38 AM
adobe lightroom 3 verses nikon capturenx
can i downsample with capture nx2
capture nx resizing web
capture nx vs lightroom
d7000 raw sharpening
d7000 sharpening setting capture nx2
how to sharpen images on nikon d7000
how to sharpen in capture nx
photo taken with nikon d7000 in australia
sharpening in capture nx
sharpening of bw digital photos with capture nx2
sharpening settings nx2 photoshop
sharpening techniques for capture nx2
sharpening with capture nx2
usm capture nx2 settings equivalent
