Wide Angle Or Ultra Wide for Grand Canyon?
I am just getting into photography as a hobby and purchased the Canon 60D with 18-135mm lens. I will be going to the Grand Canyon and would like a 2nd lens. I'm assuming a wide angle is the way to go, and also something I'll use a lot since I travel often.
Any advice on whether I should invest in a Canon wide angle (any suggestions welcome) or Canon ultra wide zoom (EF 17-40 or EF-S 10-22)?
I've already purchased a tripod, bag, extra battery, and UV/polarizing filters for the current lens. Any other equipment that I should consider prior to the Grand Canyon trip?
Thanks for your expertise and suggestions!
05-24-2011 11:53 PM
# ADS
Chief Free Electron Relocator
I wouldn't recommend jumping to an ultra-wide right off the bat. They're generally pricier anyway. Maybe you could rent a lens for the trip just to 'take one for a spin'.
Another option might be pano stitching software.
My toys: Nikon D60 & gripped D7000: Nikkor 10.5 fisheye, 10-24, 18-105, 70-300, 105 Micro: Tokina 500: Sigma 600: Celestron 2000: auto macro tube set: SB600: Manfrotto 055XB/390RC2 & 560B-1: Gossen Starlite: Easy-Up AP1500: 40' WonderPole
Your general purpose lens 18-135mm already cover the wide angle focal range. (The lower end range 18mm - )
So the 17-40mm lens only gives you 1 extra mm (you may not even notice the difference as far as the wide angle field of view goes). However, I expect better image quality from the 17-40mm lens. The 17-40mm lens is ultra wide when used with a 35mm film camera or camera with a full size sensor. With your 60D, it is considered as wide angle due to the cropped image (smaller sensor).
Ultra wide angle lens for your camera, you have few to choose from.
Canon EF-S 10-22mm
Sigma 10-20mm (there are 2 versions, one with variable max aperture and the other one is a fix max aperture)
Tokina 11-16mm (This one is quite popular)
Take a look at following link for a comparision.
Juza Nature Photography
I am Big, I am Mike
Site Moderator
I'd say yes to the Ultra Wide Angle lens...something that starts around 10mm.
I have the Canon 10-22mm and I love it. Although, the other lenses mentioned above are said to be pretty good as well, but may be cheaper.
take a look at the tokina 12-24 F4!
Keeper of the Padlocks
Site Moderator
Sigma also have the 8-16mm ultra wide angle lens - gets some very good reviews and has a strong optical quality.
you might also find this review of a help, it compares a wide range of the wide angle lenses on the market (it excludes the 8-16mm because it was not on the market at the time of writing):
Im gonna be heading to the Grand Canyon in the next few weeks. I was needing help as well with lens suggestions. I currently have a D200 and the 50mm 1.8 as my only lens. Im on a budget however and can only spend a couple hundred dollars on a lens. Currently Im looking at the 18-55mm DX or the 28-200mm G. Can anyone help me out and let me know if these are good for the scope of the Grand Canyon and the budget I have?
I recently purchased the 14mm 2.8 lens and it is incredible... then again so is the price.
Originally Posted by
thundercatz888
18mm on a DX frame isn't all that wide, really. It's the same as a 27m on a 35mm film camera. If you want to take in the whole Grand Canyon view, you'll either need a wider lens or stitching software.
Yah as Sparky mentioned, stitching software will do the trick...
Cameras - Canon 350D, 5D
Lenses - Canon 18-55mm, 75-300mm, 50mm f/1.8, 24-105L, 24-70L
Flashes - Canon 430EX II, Yongnuo YN460 II, YN468
RF-602 transmitter and 2 receivers
Neither, panoramic tripod head and motorised control, and a 300mm telephoto lens will do the trick. You'll be shooting gigapixel pictures in no time.
On a more serious note it is trivial to shoot panoramas of landscapes handheld. I typically set my lens around the standard range of 35mm-50mm, lock the settings in manual and start firing away. Stitching software is so damn good these days you'll not only get a good looking result, but you'll get it at resolutions where you could quite easily blow the image up to take half the wall. Heck just last week I shot this 174mpxl image of my city using a standard tripod and a 200mm lens. Auer & Garbz Photography
No "special" equipment needed, just some decent stitching software like AutoPano Pro. If it wasn't dark I could have done this handheld too.
"I am always satisfied with the best." -Oscar Wilde
Larger versions always on flickr
Best photos in my gallery
Proud Supporter of The Pact
Still a newbie, can't move up!
nah..... no need a fancy tripod head. Hand held stitching FTW! I will use my 35(or longer) and stitch them. I can sell a print as big as the largest wall at anyone's house.
Im gonna be going to the south rim, were going the first week of April so the North Rim is a no go unfortunately. So if I was to focus more on doing just on pano's/hdr should i even bother with a new lens or will the 50mm be sufficient?
Or, what about the 35mm prime?
