Fill Flash off camera flash
Back to Digital Matt
HE said I should try some OFF camera flashes for my portraits instead of the on camera flash.. Direct the light else where.. Fill flash I Guess is what this is called?
WOULD this flash be TO much? IF so I have a Nikon D70... A Flash I can use to bounce off the ceiling would work too.. Do you have any recommendations?
thanks!
Dont wait, just shoot your camera. In the end you will find some great results!
Nikon D70s
07-07-2006 03:05 PM
# ADS
I am Big, I am Mike
Site Moderator
Fill flash and off camera flash are different things. Fill is just a term for light that fills in the shadow areas without being the main light.
Bouncing the flash with a unit like this will be a big improvement over the built-in flash...but unless you move it off the camera...it's still on the camera.
What you need is some way to trigger a flash that is not sitting on your camera. You can do it with cords, with a flash trigger (it goes off at the same time as another flash) or with some sort of wireless radio trigger.
Have a look at this site and read though the lighting 101 section. You don't necessarily need the expensive Pocket Wizard system that he recommends...but there are a lot of good tips and techniques for off camera flash.
Nikon D70s
