Results 1 to 8 of 8
10-18-2007, 06:44 PM #1Been spending a lot of time on here!
- Join Date
- Feb 2007
- Location
- TN USA
- Posts
- 225
- My Gallery
- (0)
- My Photos Are NOT OK to Edit
- Liked
- 1 times
Problem with the Nikkor 50mm f1.8 quick question
I just put on my new Nikkor lens for the D80. And when I unlock the aperture ring to anything other than 22 I get and "f EE" reading displayed on the camera and I cannot take a single picture. Maybe I'm overlooking something simple?
Thanks for any info and or advice
10-18-2007 06:44 PM # ADS
10-18-2007, 07:15 PM #2Been spending a lot of time on here!
- Join Date
- May 2007
- Location
- Dallas, TX, USA
- Posts
- 143
- My Gallery
- (0)
- Liked
- 0 times
When you're using a D-type lens on many Nikon DSLRs (and some SLRs) you have to keep the lens set at its minimum aperture (in this case f/22) for the camera to meter properly through it. There should be a little switch on the lens to lock the aperture ring in this position.
Best MO: keep the lens at f/22 and locked in this position. You should still be able to shoot with it in a different position if the camera is in the manual and (perhaps) in the Av mode.Nikon
My photos.
10-18-2007, 07:37 PM #3Been spending a lot of time on here!
- Join Date
- Feb 2007
- Location
- TN USA
- Posts
- 225
- My Gallery
- (0)
- Liked
- 1 times
I've taken a few pics already in f22 because thats all it will let me take with this lens, but what you are saying is leave it at 22 on the lens and just adjust my aperture on the camera itself while in manual and it would give the same effect as if I was to move the ring? I mostly try to shoot in manual anyways but I was just curious......hummm...interesting
10-18-2007, 07:46 PM #4Been spending a lot of time on here!
- Join Date
- Sep 2007
- Location
- Gulfport,Mississippi
- Posts
- 194
- My Gallery
- (5)
- Liked
- 0 times
leave it on f22 and adjust the f stop with the camera, If the 80 is anything like my 50 go by the on switch hold the camera in a regular way hold the +/- button and adjust the f stop that way. and then you can go down to the 1.8 and up to 22.
Hope that helps.http://www.ivanlockert.com ----http://www.myspace.com/ilockert
Nikon D700, Nikon 28-200G, Alien Bee goodies....
10-18-2007, 10:36 PM #5Been spending a lot of time on here!
- Join Date
- May 2007
- Location
- Dallas, TX, USA
- Posts
- 143
- My Gallery
- (0)
- Liked
- 0 times
That's basically right except that the D80 has a second command dial (on the front of the body) like most other SLRs that can be used to adjust aperture. Simply use this to change aperture and use the command dial on the back to control shutter speed in manual/semi-automatic modes.
The camera moves the blades of the aperture automatically for you when the lens is set on f/22 and that lock is set to whatever aperture you want. When you move the ring you are manually moving the blades of the aperture to vary the size of the hole.
If you did what you do to change aperture on the D50/D40/D40x, you would change the exposure compensation values.Nikon
My photos.
10-19-2007, 06:15 AM #6TPF Junkie!
- Join Date
- Jun 2006
- Location
- Durham, UK
- Posts
- 1,918
- My Gallery
- (0)
- Liked
- 1 times
my nikons controls are rear wheel for aperture, front for shutter, but otherwise the advice is correct, lock aperture on the lens and control all functions from the camera. H
10-19-2007, 07:57 AM #7I spend too much of my life on TPF!
- Join Date
- Apr 2006
- Location
- Spring, TX
- Posts
- 421
- My Gallery
- (0)
- Liked
- 0 times
Nikon D70; D300!!
Nikon SB600
2 Nikon SB24's
Gadget Infinity triggers
Nikkor 18-55 f3.5
Nikkor 28mm f2.8
Nikkor 50mm f1.4
Nikkor 85mm f1.8
Nikkor 70-200mm f2.8VR
My Flickr Page
10-19-2007, 09:28 AM #8TPF Junkie!
- Join Date
- Oct 2003
- Location
- Brisbane, Australia
- Posts
- 9,636
- My Gallery
- (0)
- Liked
- 181 times
Similar Threads
Sigma 50mm f1.4 vs. Nikkor 35mm f1.8g - Urgent Question
By DeAd-EyE in forum Photography Beginners' ForumReplies: 16Last Post: 02-15-2011, 08:03 AM -
FS: Nikon D2XS (~9k) + nikkor 18-70mm / nikkor 50mm 1.8 BUNDLE
By Mr. Swindle in forum Buy and SellReplies: 7Last Post: 10-09-2010, 10:01 PM -
50mm Nikkor question.
By Live_free in forum Photography Equipment & ProductsReplies: 4Last Post: 02-09-2010, 11:43 PM -
Quick D5000 and 50mm autofocus question
By Nikon_Dude in forum Photography Beginners' ForumReplies: 32Last Post: 12-26-2009, 01:40 AM -
Quick Question about CS4? (Camera Raw Problem)
By Airforce1akab in forum Graphics Programs and Photo GalleryReplies: 5Last Post: 11-14-2009, 06:47 PM
50mm minimum aperture lock lever
,aputure ring on nikon 50mm f2.8d
,f stop button on nikkor lens stuck
,f1.4d nikkor cannot lock other aperture
,how do i set f stop on a nikon d50
,how to change aperture to 1.8 nikkor 50mm f1.8d
,how to lock aperture on nikkor lens
,nikkor 18-55 unlock
,nikkor 50 f1.8d d80
,nikkor 50mm 1.8 d aperture problem
,nikkor 50mm f1.8d stucked
,nikkor af 50mm f1.8d manual aperture ring
,nikkor issue 50 1.8 button stuck
,nikon 50mm f1.8d minimum aperture lock
,nikon af nikkor 50mm 1.8 stuck at 22
LinkBack URL
About LinkBacks
