Results 1 to 6 of 6
  1. #1
    Join Date
    Aug 2008
    Posts
    19
    My Gallery
    (0)
    My Photos Are NOT OK to Edit
    Liked
    0 times
    Shoe Mount Flash
    ...I have a Canon EOS Rebel T2 and do not have a shoe mounted flash; in fact, I have never used one...what are the advantages and what would I have to pay for a decent external flash?...
    Thanks
  2. # ADS
    Ads
    Google Advertisement
    Join Date
    Always
    Posts
    Many
  3. #2
    Join Date
    Aug 2008
    Posts
    19
    My Gallery
    (0)
    Liked
    0 times
    ....anyone?....
  4. #3
    Join Date
    Feb 2008
    Posts
    156
    My Gallery
    (5)
    Liked
    0 times
    If you have to ask, you don't need one. If you want to learn why you do, read http://www.strobist.com.
    My Equipment:
    Nikon D40
    18-55mm f/2.5-5.6
    18-135mm f/3.5-5.6
    Tamron 70-200 f/2.8
    Nikon 28mm f/3.5
    3 Cheap Quantaray Flashes
    Vivitar 285HV
    Tripod, filters, lightstands, umbrellas, etc..
  5. #4
    I am Big, I am Mike Site Moderator
    TPF Supporter
    Join Date
    Dec 2003
    Edmonton
    Posts
    32,084
    My Gallery
    (111)
    Liked
    1216 times
    If you use the pop-up flash at all...then you need a hot-shoe flash.
    The advantages are that it will probably have a lot more power than the pop-up. It gets the light higher away from the lens, reducing red-eye. Best of all, a good hot-shoe flash will tilt & swivel, allowing you to bounce the flash. That alone will improve your flash photography dramatically.
    The Canon 430EX is around $300 (I think).
    You can go with a cheaper model that doesn't communicate with the camera for automatic flash metering (E-TTL)...but you would have to learn how to use it. A dedicated flash like the 430EX is pretty easy to use.
    There's no correlation between creativity and equipment ownership. None. Zilch. Nada. Actually, as the artist gets more into his thing, and as he gets more successful, his number of tools tends to go down. He knows what works for him. Expending mental energy on stuff wastes time.
    Hugh Macleod
    Edmonton Wedding Photographer ==>Blog
    Instructor at The Canadian Photography Learning Centre.
  6. #5
    Join Date
    Aug 2008
    Posts
    19
    My Gallery
    (0)
    Liked
    0 times
    ....thanks....
  7. #6
    Join Date
    Aug 2008
    Kentucky
    Posts
    27
    My Gallery
    (0)
    My Photos Are OK to Edit
    Liked
    0 times
    I have the Canon 420EX which it fully automatic (I can adjust the power output a little using controls built into the 10D body). It tilts and rotates, and I've taken some wonderful photographs using it.
    Your camera has E-TTL II which is more advanced technology. If you really want to get the most out of your camera than you'll need to get the 430EX or 430EX II. Both are compatible with E-TTL II. I'd stay away from the 580EX II as it is only E-TTL compatible.
    Mike
    Photographers are record keepers for the world.
Ads
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Similar Threads
  1. shoe mount flash help
    By boonbear in forum Photography Beginners' Forum
    Last Post: 12-14-2010, 08:41 AM
  2. Flash Holder Light Swivel Mount + Hot Shoe Adapter
    By Link Delight Online Shop in forum Linkdelight Photography Accessories
    Last Post: 10-05-2010, 07:52 PM
  3. Blazzeo Flash Hot Shoe Trigger + 3x Receiver + 3x Holder Mount
    Last Post: 09-02-2010, 07:48 PM
  4. Shoe mount flash
    By cletusjermal in forum Photography Beginners' Forum
    Last Post: 04-02-2010, 04:34 PM
  5. Shoe-mount flash for portrait lighting?
    By kafene in forum Beyond the Basics
    Last Post: 10-14-2003, 10:16 AM
advantages of shoe mount flash over pop up
benefit of shoe mount flash
benefits of mounted flash
benefits of using a mounted flash
benifits of a shoe mount flash
external flash benefits
how to use a shoe mount flash
how to use a shoe ount flash
how to use a shoemount flash
shoe mounted flash photography how to
using a shoe mount flash
using shoe mounted flash in photography
what are the benifits of having a shoe mount flash
what is the use of a shoe mount flash
when to use a shoe mount flash
