+ Reply to Thread
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 20
  1. #1
    Join Date
    Feb 2011
    Posts
    8
    My Gallery
    (0)
    Liked
    0 times
    Minolta x700 film-speed ring problem!!!
    Hey, I am new to this forum and I got this little problem that need some advices on.
    I just bought this Minolta x700 on ebay. All other stuffs work fine, the shutter, lens, rewind handle, etc... But this film-speed ring doesn't works. It is loose. When I lift it up and turn it, it is very sluggish and hard to turn since it is loose. And the number indicator does not moves when I turn the ring. It stays at 400.
    What is the problem?
    Does this thing need expert's repair or could I repair it myself?
    Does this thing is just an external problem or internal as well.
    Let say, if I am not going to fix it, does it affects alot on my photo shooting? I know it control the ISO of the film so but I still have the shutter speed and the aperture.
    I have the video recording myself trying to turn it. Please take a look!
    Link:
  2. # ADS
  3. #2
    Join Date
    Feb 2011
    Posts
    42
    My Gallery
    (0)
    Liked
    1 times
    What happens if you turn the whole assembly clockwise, a few turns - does it tighten-up?
  4. #3
    Join Date
    Feb 2011
    Posts
    8
    My Gallery
    (0)
    Liked
    0 times
    You mean just lift the ring up and turn it, if so it just keep turning it for a while and it stuck but if I do it again, it will keep turning. But if you mean when I push down the button and turn it, it does stop.
  5. #4
    TPF Junkie!
    Join Date
    Dec 2008
    Toronto, Ontario, Canada
    Posts
    3,132
    My Gallery
    (0)
    My Photos Are OK to Edit
    Liked
    145 times
    Lift the ring and turn it (do not press the button) ... does it turn the internal ISO ring ?
    Minolta Maxxum 9000/Sony Alpha SLT-A55/Ricoh Diacord/Voigtlander Bessa 46
    The best photographs make it look like the "photography" is secondary.
    ... sometimes our responses may incite riots, but it's your decision to join the mob.
    My Website
    MIR
  6. #5
    Join Date
    Feb 2011
    Posts
    8
    My Gallery
    (0)
    Liked
    0 times
    you mean does the number change if I just lift and turn it, then no. The numbers does not change. It stuck at 400.
  7. #6
    TPF Junkie!
    Join Date
    Dec 2008
    Posts
    3,132
    My Gallery
    (0)
    Liked
    145 times
    How is the Rewind mechanism ??
    My Website
    MIR
  8. #7
    Join Date
    Feb 2011
    Posts
    8
    My Gallery
    (0)
    Liked
    0 times
    The rewind handle is works just fine. I don't have the film inside but I open the back, it does spin inside when I spin it. Oh, and one more thing, the exposure-adjustment control work somewhat, but it still very sluggish when I push the button and turn it. Basically, the whole ring is pretty sluggish. I am not sure if it works when I put the actual film in it, it just the mechanism of it that work. I haven't try film on it yet.
  9. #8
    Join Date
    Feb 2011
    Posts
    42
    My Gallery
    (0)
    Liked
    1 times
    I thought maybe the silver ring beneath should be tight against the top panel of the cam. Grip both the selector ring and the silver ring beneath it and turn it clockwise a few. does the whole assembly tighten up.
    also,,have you tried it with a film cannister inserted?
  10. #9
    TPF Junkie!
    Join Date
    Dec 2008
    Posts
    3,132
    My Gallery
    (0)
    Liked
    145 times
    Ok.
    If you do not have experience with camera dissassembly ... then don't.
    The light meter works ?
    If you set + or - 2 exposure compensation ... does it do anything to the meter reading ?
    My Website
    MIR
  11. #10
    Join Date
    Feb 2011
    Posts
    8
    My Gallery
    (0)
    Liked
    0 times
    the light meter, do you mean the +/- red light when you look into the viewfinder, then yeah it works. If I turn it to -2,-1 or +2, +1 it flashing, and at 0 it stop flashing.
  12. #11
    TPF Junkie!
    Join Date
    Dec 2008
    Posts
    3,132
    My Gallery
    (0)
    Liked
    145 times
    OK. Then you have some capability of adjusting film speed.
    As the ISO is stuck at 400 ... you will need to use the Exposure Comp to adjust for the actual speed of the film.
    ie 100 ISO = +2, 200 ISO = +1, 400 = 0, 800 =-1 and 1600 = -2
    My Website
    MIR
  13. #12
    Join Date
    Nov 2010
    Texas
    Posts
    310
    My Gallery
    (0)
    Liked
    5 times
    Seems like the plastic lock that move ISO speed is broke, prolly
    from someone forcing it without lifting it.
    Gear: Canon AE-1, A-1, T-70, AE-1P, CHINON CP-7M, Canon EOS 350D/XT/Kiss
    Lens: Canon 50mm 1:1.8, Tamron 28-200mm 1:3.8-5.6, Vivitar 28mm 1:2.8,
    Canon 70-180mm F4.5 Zoom, Canon Macro Lens Extension Tube FD50
    Canon EF 28-80mm 3.5-5.6 II, Canon EF 75-300 4-5.6, Bower adapter EOS/FD, and more.
    Flash: Canon Speedlite 155A, Achiever 115A.
    Misc: Tripod, Sync cord, Shutter release cable, Spot light.
  14. #13
    Join Date
    Feb 2011
    Posts
    8
    My Gallery
    (0)
    Liked
    0 times
    so basically, this thing could only be fixed by professionals. So do you guys know how much to repair this? I bought this for $38 total.
    Oh, and god I just have another problem. This time it's the film advance lever. It worked like a charm just a moment ago but now it acting weird. So usually after you fire a shot the lever would be neutral again right, the next time you turn the lever you would feel some tension to it. But mine is just no tension at all, I fired my shutter release and nothing happen. The film indicator is at S. The battery is still new. I still see the light through the viewfinder.
    Here is the video:
  15. #14
    Join Date
    Nov 2010
    Texas
    Posts
    310
    My Gallery
    (0)
    Liked
    5 times
    Sounds like its failing quickly. Might cost more than its worth.
    Some of those old cams use plastic parts that move other mechanical
    components and if the plastic is old or components too tight and need
    lube, the plastic notches will shear off.
  16. #15
    Join Date
    Feb 2011
    Posts
    8
    My Gallery
    (0)
    Liked
    0 times
    Never mind, I found the problem for the film advance lever, it turn out the motor drive is jammed, so I turn the thing on the bottom with a coin, and it worked. sweet. Now, the only problem left is the film-speed ring.
Sponsors
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Similar Threads
  1. lens for MINOLTA MD 70-210 zoom 52mm f4.5 X700
    By dmorgan924 in forum Buy and Sell
    Last Post: 04-24-2010, 06:31 PM
  2. Minolta SRT 101 Film Problem...
    By xxx_jpk_xxx in forum Digital Discussion & Q&A
    Last Post: 02-24-2009, 10:24 PM
  3. Problem with Minolta 400si film SLR
    By bchase in forum Photography Beginners' Forum
    Last Post: 11-21-2007, 11:42 AM
  4. Looking for fisheye lens for minolta x700
    By JungleGuts in forum Photography Beginners' Forum
    Last Post: 07-21-2007, 04:10 PM
  5. minolta x700 shutter
    By panocho in forum Beyond the Basics
    Last Post: 02-22-2005, 05:26 PM
iso minolta x 700
minilota x700 film
minolta x 700 how to change iso
minolta x-700 change iso
minolta x-700 film advance adjustment
minolta x-700 motor drive jammed
minolta x-700 shutter-speed selector popped off
minolta x700
minolta x700 change iso
minolta x700 film advance lever no tension
minolta x700 iso
problem to look for in minolta x700
stuck iso selector slr, minolta
will the advance work on miolta x700
x700 iso
