+ Reply to Thread
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 16
  1. #1
    Join Date
    Nov 2011
    Kent, UK
    Posts
    75
    My Gallery
    (0)
    My Photos Are OK to Edit
    Liked
    12 times
    Ilford delta 100 self processing need more contrast!
    Hi all film peeps!
    I have recently started self-processing my medium format film then I scan in the film to get a digital image using a epson V500. My camera is a Rolleicord Vb
    My issue is that all my recent self-dev shots appear to have little dynamic range, well actually, highlights are fine but hardly any blacks or dark greys.
    I added a couple of untampered with scans:
    My process is:
    All liquids at 20 degrees Celsius.
    Developer:Ilford Ilfasol 3, 60ml with 540ml water, 5 mins total with agitation for the 1st 30 secs then 10 seconds at the end of each minute
    Stop: Ilford Ilfostop, 30ml with 570ml of water, 2mins with agitation for the 1st minute.
    Fixer: Ilford rapid fixer, 30ml with 570ml of water, 1 min agitation, leave for 4 mins total.
    I use all these mixes fresh, so no re-using to aid accuracy.
    I know in these example there is a lot of light across the subject, and that this will reduce the contrast.
    All help opinions welcome!
    Thanks
    Paul
  2. # ADS
  3. #2
    ann
    ann is offline
    TPF Junkie!
    Join Date
    May 2007
    Posts
    3,750
    My Gallery
    (0)
    My Photos Are NOT OK to Edit
    Liked
    108 times
    run a test roll and increase development time by 25 %
    try a different roll at an ISO of 50 as i don;t see any detail in the shadows, develop with your nomral times.
    You need to do a bit of testing, which is not so uncommon.
  4. #3
    Join Date
    Nov 2011
    Kent, UK
    Posts
    75
    My Gallery
    (0)
    Liked
    12 times
    Quote Originally Posted by ann View Post
    run a test roll and increase development time by 25 %try a different roll at an ISO of 50 as i don;t see any detail in the shadows, develop with your nomral times. You need to do a bit of testing, which is not so uncommon.
    thanks ann I will try the increase of dev time and will let you know what happens. Can you explain the thinking behind using ISO 50 as I don't understand.Thanks Paul
  5. #4
    ann
    ann is offline
    TPF Junkie!
    Join Date
    May 2007
    Posts
    3,750
    My Gallery
    (0)
    Liked
    108 times
    more exposure, more information. the old saying exposure for the shadows develop for the highlights.
    Most serious film users test their equipment to determine just what is the right EI for them , not what the box says.
  6. #5
    TPF Junkie!
    Join Date
    Mar 2008
    L.A.
    Posts
    1,699
    My Gallery
    (0)
    Liked
    51 times
    Have you gotten satisfactory negs with this camera that were processed by others?
  7. #6
    TPF Junkie!
    Join Date
    Oct 2007
    Greenville, Texas
    Posts
    11,785
    My Gallery
    (4)
    Liked
    578 times
    Quote Originally Posted by thepaulreid View Post
    Fixer & stop bath are fine to reuse... Might save you a little money. Fixer, especially, gets expensive if you don't reuse it.
    -Josh
    Flickr
  8. #7
    Join Date
    Jan 2012
    Chicago
    Posts
    9
    My Gallery
    (0)
    Liked
    2 times
    Both images have a definite dark band along one side. Did you remember to agitate in the developer??
  9. #8
    TPF Junkie!
    Join Date
    Oct 2007
    Greenville, Texas
    Posts
    11,785
    My Gallery
    (4)
    Liked
    578 times
    I think it's probably just under exposed, and it looks like you boosted the shadows/midtones in the scanner, which is contributing to the lack of contrast.
    The rebate should be black. Yours are very light (especially on the first shot), which tells me that the blacks are significantly far from 'black'.
    What scanner settings are you using? Any pre-scan curves adjustments?
    -Josh
    Flickr
  10. #9
    TPF Junkie!
    Join Date
    Jul 2009
    USA
    Posts
    13,254
    My Gallery
    (7)
    Liked
    1935 times
    What about that big band of fogging along the bottom of shot #2??????
    I have a suspicion that your film is fogged...I mean, it looks fogged to me. I think there IS some detail in the shadows, and that the scanner exposure is what is wonky...I pulled the two into PS and did a quick curves adjustment...it's hard to pinpoint, but again, the band of light at the bottom of shot two looks like FOG to me. In home developing that can be an issue when loading the film onto reels. Same with roll-film too...it is more easily fogged than cassette or cartridge loaded film. Something about these images makes me think "fogged film". However, you ARE shooting toward window light in a darkish room, and that looks like maybe from an older 120 rollfilm camera: the "fog" I think I see in shot #1 looks a bit like what is called "veiling glare", in the shadowed areas on her blouse. Is the lens CLEAN, both front and rear elements??? A slight haze or fog on the lens, like vapors from plastics, foams, bellows, leatherette, leather camera bags, etc. can create a thing,thin film over lens elements, whcih will create "veiling glare" when the lens is aimed toward bright light sources. So...fog or lens flare are possibilities.
    5 mins with 30 then 10 seco on the minute development....hmmm. Awfully short time...I'd be tempted to add 2 minutes...your thermometer could be reading "low".
    A couple quick curves adjiustments in PS yielded this from the untouched scans:
    and
    "It's about time people started taking photography seriously, and treating it as a hobby." Elliott Erwitt
  11. #10
    Join Date
    Nov 2011
    Kent, UK
    Posts
    75
    My Gallery
    (0)
    Liked
    12 times
    Quote Originally Posted by compur View Post
    Hi Compur, I have indeed. When the shop processed my first film, the images where much more blacker blacks and whiter whites. So I am thinking it must be something I am doing. However, I cannot be sure that the shop did not tweak the levels during scanning...!?!
  12. #11
    Join Date
    Nov 2011
    Kent, UK
    Posts
    75
    My Gallery
    (0)
    Liked
    12 times
    Hi there, the dark bands are the borders of the film. I do Agitate in the dev. I have a twiddler!
  13. #12
    Join Date
    Nov 2011
    Kent, UK
    Posts
    75
    My Gallery
    (0)
    Liked
    12 times
    it could be under exposed, as I have no light meter. As far as I know these are completely std scans so no boosting... I will have a look when I scan the nxt roll. I like to scan completely natural and then if I have to use lightroom to do any enhancements. ps what is a rebate??
  14. #13
    TPF Junkie!
    Join Date
    Oct 2007
    Greenville, Texas
    Posts
    11,785
    My Gallery
    (4)
    Liked
    578 times
    The non-image areas of the negative. The edges and the space between the frames.
    -Josh
    Flickr
  15. #14
    Join Date
    Nov 2011
    Kent, UK
    Posts
    75
    My Gallery
    (0)
    Liked
    12 times
    Quote Originally Posted by Derrel View Post
    and
    Hi Derrel, thanks for taking the time for such a detailed response you are very kind. I am not sure what fogged means -nor how is is caused/avoided. I am a little suspicious of my scanner. On my last use I scanned the same image twice, and it seemingly came up with 2 completely different exposures!! I am fairly confident I had not changed anything, but cannot explain it by any other means. The camera is circa 1960 but I have checked the taking lens, and it is crystal clear. The 5min dev times are based on Ilfords own recommendations. I think I will try 6 mins for the nxt one and see what the difference is. Curves adjustments look good defo more blacks!
  16. #15
    TPF Junkie!
    Join Date
    Jul 2009
    USA
    Posts
    13,254
    My Gallery
    (7)
    Liked
    1935 times
    "Fogging" means light that is not a part of the shutter's exposure of the film has hit the film--at "some point in time", prior to the actual fixer stage of the film's development...fogging can happen at ANY time, until the film is in the fixer...for example, if a camera has a bellows, and it has a pinhole in it, the tiny amount of light that enters can "fog" the film that is positioned at the film gate. With a roll of rollfilm, if the tail is not wrapped tightly and the sticker (decal/tape/sticky thingy) stuck down, light can work its way inside the black paper and fog the film. Accidentally opening the camera back, even for a few milliseconds, can fog some of the film...loading the film onto a developing reel in the darkroom or temporary darkroom there are MANY hazards to fogging...those glow-in-the-dark numerals on an old-fashioned analog timer??? Potential foggers. Light leaking under the doorway in a temporary darkroom,even an night time??? That can fog the film. A plastic-topped developing tank that has a hairline fracture in the pour spout--that too can fog the film!!!
    On Shot #2--you see that horizontal white-ish patch??? See how that looks a LOT like a film border??? In terms of the height of the line? Say 6 millimeters or so, give or take??? That makes me think the film was fogged. When film is fogged when it is rolled, it's common for the foging to be WORST on the "top side" or "light leak side" of the roll...the fogging will be most severe on the outside wraps of the film, and the light will penetrate less and less as it goes downward and in, toward the core of the film. With rollfilm, it is important to load and unload in subdued light conditions, and to always make SURE that the film tail is wrapped tightly and securely and pasted down using the supplied "sticker". Rollfilm that is allowed to "sit" out, in the light, can get fogging from light...and I think that's what has happened with this roll of film.
Sponsors
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Similar Threads
  1. Questions regarding Ilford Delta 100
    By Victorianeliza in forum Film Discussion and Q & A
    Last Post: 10-17-2009, 07:23 AM
  2. Replies: 9
    Last Post: 08-08-2008, 07:20 AM
  3. Ilford Delta 3200
    By Irminsul in forum Film Discussion and Q & A
    Last Post: 09-17-2006, 04:04 PM
  4. Where to develop Ilford Delta ISO 400?
    By Zeabned in forum Beyond the Basics
    Last Post: 05-28-2006, 04:23 PM
delta 100 film images
developing ilford delta film
fluxuation
how to develop ilford delta 100
ilford delta
ilford delta 100
ilford delta 100 discussion
ilford delta 100 processing
ilford delta 100 processing times
ilford delta 100 reddit
ilford delta 100 underexposure
ilford self processin
over and uner development times ilford delta 100
pulled devloping fogged film
underexposed delta 100
