Results 1 to 7 of 7
07-26-2007, 09:09 AM #1Been spending a lot of time on here!
- Join Date
- Jun 2007
- Location
- Staffordshire, UK
- Posts
- 164
- My Gallery
- (0)
- My Photos Are OK to Edit
- Liked
- 0 times
Dripping tap and fast shutter speed
I've had a go at freezing the motion of water droplets out of a tap, as I love those kinds of shots! Used the camera on full manual, they are a bit dark but thought that added to the effect. Taken using my Canon EOS 300D and 50mm f1.8 lens.
Taken at a fairly fast shutter speed (1/640, ISO 100, f1.8), though not quite frozen the water!
Taken at a slightly faster shutter speed than the previous picture (1/800, ISO 100, f1.8) has very nearly frozen the water droplets!
Looking for more C&C on these, any comments on how I could improve! Perhaps I could have increased the ISO to 200 or 400 to get a faster shutter speed to really freeze the droplets?
My Flickr pictures!
Weapons of choice/reasons for overdraft:Canon 300D/Digital RebelEF-S 18-55mm - EF 28-90mm - EF 80-200mm f/4.5-5.6 II - EF 50mm f/1.8 II (Nifty Fifty!
)1 & 2 Gb CompactFlash cards
Panasonic Lumix TZ3
Canon PowerShot S30
"All it takes for evil to flourish is for good men to do nothing" - Edmund Burke
07-26-2007 09:09 AM # ADS
07-26-2007, 10:03 AM #2alter ego: Analog Matt
- Join Date
- Jan 2004
- Location
- Santa Barbara, CA
- Posts
- 5,346
- My Gallery
- (0)
- My Photos Are NOT OK to Edit
- Liked
- 2 times
Use a flash to freeze the movement of the water. You'll never achieve sharp results at f/1.8. You need some depth of field to get all of the water in focus. You'll also get a better exposure. These are dull and underexposed. Give yourself a plain background. If you can, hang a sheet or towel behind to give some contrast.
07-26-2007, 11:16 AM #3Been spending a lot of time on here!
- Join Date
- Jun 2007
- Location
- Staffordshire, UK
- Posts
- 164
- My Gallery
- (0)
- Liked
- 0 times
Cheers for the feedback Matt! I did try to compose the shot so that those two out of focus jugs kind of framed the shot, not sure if it worked though!
I didn't use the flash as I didn't think you could use the flash effectively at higher shutter speeds (except for effect), I think the fastest shutter speed I can get with my 300D with the flash is something like 1/125. I only currently have the small pop-up flash currently sadly!
Will have another go probably tomorrow using the flash and will try at f4 or somewhere thereabouts and see what I come up with, though I may have to increase the ISO to get the fast shutter speeds. I'll see if I can drape something behind the shot too.
My Flickr pictures!
Panasonic Lumix TZ3
Canon PowerShot S30
07-26-2007, 11:22 AM #4Been spending a lot of time on here!
- Join Date
- Feb 2007
- Location
- TN USA
- Posts
- 225
- My Gallery
- (0)
- Liked
- 1 times
07-26-2007, 11:25 AM #5alter ego: Analog Matt
- Join Date
- Jan 2004
- Location
- Santa Barbara, CA
- Posts
- 5,346
- My Gallery
- (0)
- Liked
- 2 times
You don't need a fast shutter speed with a flash. The flash duration is so short that it will freeze the action.
07-26-2007, 12:43 PM #6TPF Junkie!
- Join Date
- May 2007
- Location
- Canada
- Posts
- 4,697
- My Gallery
- (39)
- Liked
- 138 times
I would use a flash too and as Matt said it freezes the action but I would also use velvet in the background since it does not reflect light. I went to a materials store and picked up a good sized piece of black velvet to use as a background.
skieur
07-26-2007, 01:14 PM #7TPF Junkie!
- Join Date
- Feb 2007
- Location
- Atlanta, GA
- Posts
- 1,527
- My Gallery
- (0)
- Liked
- 3 times
Yeah I found if I set my tabletop fan to the highest setting and used my XT's built-in flash, the blades would freeze with flash even at 1/15 (very slight ghosting) everything above 1/60 was tack sharp, and to get the same results without flash I turned on REALLY bright lights and got the shutter speed to 1/2000
KEEP THIS IN MIND IF I CRITIQUE YOUR PHOTO
This was an open minded opinion and I tried to make it more meaningful than just tearing the photo apart. I simply highlight what I find to be a strength or a weakness that enhances or degrades the quality of an image. I want it to be clear that I respect your right to agree or disagree with my viewpoints, but hope that they may have given you some insight or further understanding when you compared and contrasted my views with your own.
Similar Threads
Fast shutter speed
By radioman in forum Photography Beginners' ForumReplies: 10Last Post: 04-27-2009, 02:58 PM -
Fast shutter speed led to dark pictures?
By a1157814a in forum Photography Beginners' ForumReplies: 6Last Post: 12-02-2008, 07:50 AM -
Very fast shutter speed
By Jrmdb3 in forum General GalleryReplies: 10Last Post: 06-19-2008, 02:58 PM -
Really Fast shutter speed with flash, first time using manual controls with success!!
By tehbuffalo in forum General GalleryReplies: 19Last Post: 06-19-2006, 01:08 PM -
High film speed, or low shutter speed (digital still life)
By Garbz in forum Beyond the BasicsReplies: 4Last Post: 12-04-2003, 06:34 AM
best shutter speed for dripping water
,fast shutter speed
,fast shutter speed water
,fast shutter speed water droplets
,fast speeds (800 iso)
,faster shutter speed photos
,ideal shutter speed for dripping tap
,image taken using fast shutter speed
,shutter speed for dripping water
,slow shutter speed for dripping water
,slow shutter speed photos of running tap
,water and shutter speed
,what shutter speed for dripping water
LinkBack URL
About LinkBacks
