Page 1 of 2 1 2 LastLast
Results 1 to 15 of 19
  1. #1
    Join Date
    Feb 2010
    Idaho
    Posts
    174
    My Gallery
    (0)
    My Photos Are OK to Edit
    Liked
    0 times
    Taking HDR in raw
    Should you always shot your hdr shots in raw format? This might be a stupid question but I am new. Please no one be mean.
  2. #2
    Banned
    Join Date
    Feb 2008
    Just outside Toronto Canada
    Posts
    2,804
    My Gallery
    (0)
    Liked
    369 times
    No problem asking a sensible question IDL. You can make what they call a pseudo HDR from a single Raw file. This is good if it can cover the lighting situation and there is lots of movement in the scene like people, traffic, or trees blowing in the wind. Otherwise shooting 3, 5, 7 or 9 shots jpeg is the more acceptable way to do it. Tripod and no movement is preferred. But your dynamic range will pretty well be covered.
  3. #3
    Join Date
    Feb 2010
    Idaho
    Posts
    174
    My Gallery
    (0)
    Liked
    0 times
    oh ok . I just saw provo took 6 raw shots to compile one of his hdr's so i thought i would ask
  4. #4
    ann
    ann is offline
    TPF Junkie!
    Join Date
    May 2007
    Posts
    4,242
    My Gallery
    (0)
    My Photos Are NOT OK to Edit
    Liked
    184 times
    there is always more than one way to do something.
    i only use RAW files, others use jpeg's.
    the RAW files gives one more control of the image with a lot of latitude if an error has been made, but they are more labor intense.
    Try both and see which works best for your workflow
  5. #5
    Banned
    Join Date
    Feb 2008
    Posts
    2,804
    My Gallery
    (0)
    Liked
    369 times
    Quite right Ann. My main camera is a Fuji and it only shoots jpeg so I dont think Raw yet. My Nikon shoots Raw but I dont use it much.
  6. #6
    Join Date
    Oct 2009
    Ex Member
    Posts
    934
    My Gallery
    (1)
    Liked
    20 times
    Below is a comparison between Jpg VS Raw
    JPEGs are:
    • Faster to shoot
    • Faster to Save
    • Smaller in file size, consequently you can save many more panos/images on a drive.
    • Can be opened/edited in just about any graphics program
    • Cross-platform
    • Little or no learning curve
    • Anyone or almost any camera can shoot JPGs
    • 8-bit files (only 256 color per channel)
    • Limited ability to color correct
    • Generally, you need to bracket in ONE f-stop increments.
    • Very limited in overall detail, but especially in highlight and shadow details
    • (in other words darks go black quickly and highlights go completely white quickly)
    • Better for shooting "journalistic" or fast moving/changing scenes, especially with people in them.
    RAW files are:
    • Slower to shoot
    • Slower to save (More bits = bigger file size = more hard drive space needed = less images can be saved to a hard drive)
    • Larger in file size (14-bit RAWs are about 25% larger than 12-bit RAWs)
    • 12-bit files have 4096 colors per channel and 14-bit files have 16,384!
    • Are "proprietary" per camera manufacturer and even within a single manufacturer
    • (i.e.: Canon) they have multiple RAW formats (i.e.: .CR2 and .CRW)
    • Generally, you need to bracket in TWO f-stop increments.
    • Much more exposure latitude, consequently fewer photos to cover a large exposure range. (i.e. 3 RAW files can cover a range that 5 or 6 jpegs would be needed to cover) - This also means less bracketing!
    • Much more ability to change color temperature after its been shot
    • Have to be "processed" in a digital darkroom (i.e.: Adobe Lightroom) and then saved as secondary file such as Tiff, JPG, EXR, etc.
    • Are Non-destructive! At this point, RAW files cannot be saved. Therefore you can always go back to the original and make additional corrections.
    • Are naturally a bit "soft" looking. RAW files are INTENDED to be sharpened, so some photographers have a hard time switching for that reason alone.
    Raw captures more data and more of the dynamic range more information result's in a better image quality for HDR.
    The catch is upon processing you still have to come back down to jpg for printing
    and for posting on the web but you can still see the processing advantage the raw has over jpeg.
    And last I will say this almost 95% of all HDR tutorial's out on the web talk about using Raw the the optimal method of choice.
  7. #7
    Join Date
    Feb 2010
    Idaho
    Posts
    174
    My Gallery
    (0)
    Liked
    0 times
    Alright. Thanks for the info provo. That helped me out a ton. I will go try and HDR when i get home from school tonight. One more question though. If you take 3 shoots in raw and make an hdr out of them, do you lose the detail and color range if you change that into a jpg?
  8. #8
    Banned
    Join Date
    Feb 2008
    Posts
    2,804
    My Gallery
    (0)
    Liked
    369 times
    In a simple word. No.
  9. #9
    Join Date
    Oct 2009
    Ex Member
    Posts
    934
    My Gallery
    (1)
    Liked
    20 times
    IDX to give you a better understanding between raw vs jpg I created this to show you
    Click here to view
  10. #10
    Join Date
    Feb 2010
    Idaho
    Posts
    174
    My Gallery
    (0)
    Liked
    0 times
    Thanks for that. It really helps but personally i liked the jpg picture better.
  11. #11
    Banned
    Join Date
    Feb 2008
    Posts
    2,804
    My Gallery
    (0)
    Liked
    369 times
    The jpg image was made from the Raw image. The jpg is globally darker so the shadows are plugged in.
  12. #12
    Join Date
    Feb 2010
    Idaho
    Posts
    174
    My Gallery
    (0)
    Liked
    0 times
    So the raw on there was the original hdr and the jpg was that same raw image converted into a jpg correct?
  13. #13
    Banned
    Join Date
    Feb 2008
    Posts
    2,804
    My Gallery
    (0)
    Liked
    369 times
    Yup
  14. #14
    Join Date
    Feb 2010
    Idaho
    Posts
    174
    My Gallery
    (0)
    Liked
    0 times
    Ok thanks for clearing that up. I will try a hdr shot in raw and then in jpg and post it up on here tonight
  15. #15
    Join Date
    Oct 2009
    Ex Member
    Posts
    934
    My Gallery
    (1)
    Liked
    20 times
    As a member mentioned on another forum
    A RAW file. It is essentially unedited until you open it (and you can only open it in ACR, not directly in PS). The jpeg file has been edited in-camera according to whatever settings you have made in the camera menu, and it is not unusual that it may appear better than the RAW file before you have made any adjustments to the latter. So, as you suggest, the object is to make edits in ACR so that the image looks just as good (or perhaps better) than the jpeg. The advantage to the RAW file is that you have a great deal more lattitude for making the desired adjustments than you have with the jpeg file.
    LOL for the sake of this thread already just use Raw
Ads
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Similar Threads
  1. taking a job ... need some help.
    By wgp1987 in forum Photography Beginners' Forum
    Last Post: 03-16-2010, 09:56 AM
  2. Taking Me Seriously
    By creative_one in forum General Shop Talk
    Last Post: 09-25-2009, 11:28 PM
  3. Is this taking PP too far?
    By xs400 in forum Graphics Programs and Photo Gallery
    Last Post: 08-20-2009, 06:30 PM
  4. Taking B&W
    By Shooter_Mutter in forum Photography Beginners' Forum
    Last Post: 08-29-2008, 08:43 AM
  5. i took a pic of him taking a pic!
    By missinframe in forum People Photography
    Last Post: 03-21-2008, 08:20 PM
can iphone 4 shoot raw
hdr by taking one photo raw
hdr from jpeg vs raw
hdr jpeg vs raw
hdr jpg vs raw
hdr raw
hdr raw vs bracketing
hdr single jpeg vs raw
hdr vs raw
hdr vs raw still life
hdr with jpeg or raw
iphone 4 hdr raw
jpg vs raw for hdr
jpg vs raw hdr
single raw hdr vs bracketing
